replace studs
Quoted: 5224 Post(s)
Liked 3,581 Times
replace studs
had to replace 6 studs
after the work I put everything back the way it came. hope I can find this when I need them again
box-o-studs
guess I never wondered what they looked like before
the tip of the tool. you put the stud in, face in. it sits in there a little loose
thought there were only 1 or 2 to be replaced but it was 6! all in the rear tire, if that has any significance
it looks like all the rest
was not difficult. you just push & wiggle. the more I did the better I got
box-o-studs
Nice job.
When I first started cycling in the snow and ice, I had purchased a pair or Continental Spike Claw 120s. They had studs only on the edges of the treads. When I kept on slipping, I purchased spare studs from BikeStuds and converted my 120s into Spike Claw 240s. After you get the hang of it, it was easy. But after inserting 10 studs, you really need to give your hand a break. Overall, I think the time you need to reserve for this kind of work would be around 30s per stud.
Then last spring, I noticed that my rear tire had a gash in it. So I purchased one Schwalbe studden winter tire. Works great. I still have the old tire planning to see if I can remove all those studs and save them for future use.
Likes For Daniel4:
Liked 3,581 Times
Quoted: 4227 Post(s)
Liked 2,488 Times
Loosing 6 studs is a lot, especially on new tires. It's a good idea to do about a 30 mile ride on bare pavement to set the stud in before venturing out on snow and ice.
I bought my Bontrager Gnarwhal tire studless and fully populated the pockets with studs salvaged from worn out marathon winter tires. Hard on the hands.
Likes For gecho:
Likes For Daniel4:
Bikes: Trek Émonda SL 5, Trek Checkpoint SL 5, Giant Trance X 2, Trek Farley
Quoted: 75 Post(s)
Liked 94 Times
I just put 504 studs into my 27.5" Dillinger 5s that I removed from my 26" Dillinger 5s. Once you have the hang of it, you can do quite a few in a short time. My hand was pretty sore afterward, though. This is the tool I used.
Likes For UnCruel:
Liked 3,581 Times
The tool you use to insert them does fine to remove them as well. Just pry them out sideways. They come out easier than they go in.
that is a lot of work!
Old guy & bikes
Thanks for all of your advice. I haven’t lost many studs, but this shows me my options.
Quoted: 7348 Post(s)
Liked 2,470 Times
The guy who calls himself Shifter says he rides (in Calgary) with a studded front tire and a regular rear tire. Would anyone else do that? If it can only be one tire, sure, it should be the front, but I think I also want good traction in the rear.
Likes For noglider:
Old guy & bikes
It’s easy enough for your rear wheel to go out sideways, especially on rutted packed snow. I would never ride with one studded tire. At my age (71), my bones break easier and take longer to heal.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
This has been relatively common for me, as one of the tire stages as conditions evolve. A bit of sliding in the rear, when the conditions are not yet overwhelming, is just a nuisance, not a major issue. Aside from going intermediate on the tires, an important restructuring of handling winter traction issues was in rewiring the instincts and letting the bike go without clinging to it when a recovery is not possible anymore. The need for studs is then just generally reduced.
I went to put the studded tires on my mountain bike today and noticed the one I had been using in the rear is in rough shape. The rubber has worn down enough that the studs take a real beating from the pavement. The aluminum base probably started making contact with pavement and wore quickly allowing the carbide insert to break off / fall out. There is still what I would call a lot of tread left, but once enough is gone that the studs stick too far out its game over (at least as a rear tire). I used up the last of my harvested studs to fill in the gaps and will use the tire in the front until I replace it. With much less weight on the front wheel it should be good for quite a while.
Likes For gecho:
Liked 3,581 Times
took the same bike/tires out for a good 2 hr ride in a nearby forest a cpl days ago. rode over wonderful hard compacted snow & ice. got in a about 3 miles on pavement riding to & from the forest, about 10 miles total. lost 2 more studs on the rear. on the front tire, the only casualty was this one that got turned sideways. fixed all three up, easy peasy w/ the tool
Liked 2,470 Times
