Opinion on Dodgy Head Tube Cut
#52
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
decided to dig a bit deeper into this type of frame... it seems they have some history surrounding the thin head tubes and Cracks..... and one of the best in frame repairs passed on doing a repair.....
https://www.roadbikereview.com/threa...-repair.25047/
Likes For maddog34:
#53
Quoted: 2338 Post(s)
Liked 2,824 Times
here.. buy this... it's a bargain.
https://seattle.craigslist.org/see/b...588233891.html
Likes For squirtdad:
#54
Quoted: 18378 Post(s)
Liked 4,512 Times
It looks to me like the front of the head tube has been hogged out some.
I like the idea above about milling the tube down to the bottom of the crack which should help clean up the seat for the headset.
A couple of years ago the Colnago Dream frames were significantly less than either the steel or carbon fiber frames. Whew, prices seem to have bounced up quite a bit.
Before you purchase, look at Colnago forks. I can't tell if it is 1" or 1 1/8".
Colnago frequently used black (carbon) or silver (chrome steel) forks on their frames.
That may be a Colnago Flash fork (black carbon fork + steel steer tube, I think), but verify steer tube size.
If I was purchasing the frame, I'd give myself an allowance of $200 for the missing fork.
So, you get:
$495 + $60 shipping + $200 fork = $755. Plus the cost of repairs. So, consider you're into it about $800 or so.
So, you get:
Likes For CliffordK:
#55
Member’s Member
Likes For CW Zing:
Likes For maddog34:
#57
Quoted: 3513 Post(s)
Liked 2,926 Times
#58
Liked 739 Times
So, you get:
So, you get:
#59
Quoted: 4408 Post(s)
Liked 1,562 Times
Obviously, the cut was ACROSS the top of the head tube. And doesn't go deep enough to cut through a race. If one was cutting out a race (highly unlikely, unless you're an incompetent home mechanic who saws stuff out of your bike), you would cut the race vertically, to relieve the entire length of the race.
I think what you're missing is that the top race would have to be cut where it sits on top of the head tube and down inside. Done properly you'd have to cut level and straight down and you wouldn't have much of mark on either surface, but clearly someone wasn't paying attention, probably as they transitioned between the two. I would bet that what we can't see is that the cut is slightly lower inside the tube than out.
#60
Liked 1,562 Times
#61
Quoted: 5789 Post(s)
Liked 2,581 Times
Under normal circumstances, angled cuts, accross a tube (like this one)would be HIGHER on the inside so the sloping blade clears the opposite side.
The only ways for it to be lower on the inside would be if one used a keyhole saw and limited himself to 1" strokes, OR ran a hack saw blade through the tube and cut front the inside out. In that case, there would be a long shallow angle cut extending down the ID for a half inch or so.
Too bad we weren't betting, I would have enjoyed the beer.
(Didn't BF used to have a beers emoji?)
#62
Liked 1,562 Times
I'd take that bet.
The only way for.it to be lower on the inside would be if one used a keyhole saw and limited himself to 1" strokes.
Or has ever used a Dremel 1" disc cutter? Or a Sawzall?
I have the most bizarre conversations with so-called mechanics on this forum. Mind numbing.
Likes For Kontact:
#63
Liked 2,581 Times
So, either a shallow.down angle with short strokes, or a long angle.
As I said, I would have taken the bet.
#66
Liked 1,562 Times
#67
Liked 2,926 Times
#68
Liked 4,512 Times
If I had to hit steep hills regularly, it would be on the lightest bike I could find.
I've commuted over a pretty decent hill in the past. It wasn't that long of a ride, but 1/4 mile into the ride, straight up a hill. And done on the old Colnago road bike.
#69
Liked 2,824 Times
#70
Member’s Member
Likes For CW Zing:
#71
Liked 2,581 Times
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
#73
Liked 1,562 Times
Likes For Kontact:
#74
Liked 2,926 Times
#75
Liked 1,562 Times
Even the cut’s location doesn’t support your “theory.” Who would cut out the headset from directly in front of the top tube? You don’t think that position would be just a little awkward and difficult to do?
In any case, it is much easier to cut toward the frame because you can stabilize the frame with your off hand or knees, which you can't do if you stand in front of the headtube.
Have you used tools like this much? Have you ever had to cut something out of bike using a workstand? Ever worked as a mechanic? Ever used a Sawzall? Dremel? Ever cut out a seat post? Do any piping or metal fabrication?
Yeah, I didn't think so.
