New addition -> Norco Avanti
Just got a Norco Avanti 24 spd from a friend who left it behind when he moved out west. From what I can find it looks like a 2002 Model.
Needed some TLC, a good cleaning and a new chain. It is on the big side at 22 inches but I can make it work for me.
I have a 2017 Norco Malahat that was made in Cambodia. The chrome handle bar always rust and need polishing and I had to re spoke from 15 gauge to 14 gauge on the real wheel. I just got tired of broken spokes.
The Avanti has similar geometry but much better components and a polished aluminum handle bar. Should be a better bike.
Can't wait to put some miles on it!
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
It's hard to beat a free bike! Is this the bike? https://www.bikepedia.com/QuickBike/...spx?item=37206
It looks like a nice-riding hybrid bike. I think the Nexave components sometimes were incompatible with other groups, though I wouldn't swear to it. It's just something to watch for (and maybe confirm that I'm wrong) if you do eventually start to upgrade or replace components.
First ride on it today. I put a new chain on it and encountered a lot of skipping. I will replace cassette and hope that clears it. Derailers needed adjusting.
Loved the geometry of the bike but took a while to get used to shifters. Will probably change seat.
The Nexave shifters have a button on the top on both sides for lower gears and lever below for higher gears.
Not used to button for lower gears on the right and a lever to go up to a higher gear.
Not a real problem but different.
Liked 762 Times
I would start with a new chain and then replace the cassette if it still skips. The chain usually wears faster than the cassette...most people will get two or three chains to a cassette so, if the drivetrain is skipping, replacing the chain is a good first step. If the cassette is that worn, it's likely to need a new chain also anyway. You can certainly measure the chain to check for wear. Measure along the top length of chain when it's pulled taut. Each link is exactly 1/2" long. Put the ruler's 0 mark on one pin and look at the 12" mark -- it should be exactly on the 24th pin from the 0 mark. If the 12" mark is slightly short of the pin, that means the chain has enough wear in the links and pins that it's effectively elongated; that's a good objective measurement of wear.
Also, check that the skipping you're feeling isn't really "ghost shifting". It could be that the rear derailleur's indexing is off just a little bit, and the chain tries to jump to the next larger or smaller sprocket under load because it's not exactly centered on the desired one.
