Need a replacement 8.4 V 6400 mAh batery and charger recommendation
Prairie Path Commuter
Bikes: Marin Palisades Trail
I was using this Cree light setup:
https://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
and got 5 commutes out of it. I am not sure what happened but during recharging after the 5th commute both the charger and the battery died. I like light and would like to replace both the battery and the 8.4 V 6400 mAh lithium battery pack. I am soliciting recommendations for this. So far this is what I have found.
For the battery apparently this fits the plug on the light well.
https://www.amazon.com/dp/B00AOF51FK/...I3EYE7YEH9H5TW
This is what I found for a charger.
https://www.action-led-lights.com/col...gemini-charger
Any other thoughts?
Any other thoughts?
Either one or the other died, or you have a bad connection somewhere. If you have a multimeter, which I assume you don't based on the questions, you could trace where the point of failure is and then maybe fix it yourself.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
I bet just the protection circuit on the battery died or there's a bad connection. This would make it unable to deliver power or take a charge.
I'd peel that battery pack open and check for bad connections, it's likely the only thing wrong is a loose wire that needs to be resoldered.
All that said, the battery and charger should be fine though you can never tell if the connectors will fit correctly.
I bet the charger is fine too. You could try just replacing the battery first, if you're not in a hurry to get it going again.
Work: the 8 hours that separates bike rides.
Well you guys got my hopes up but I peeled pack the shrink wrap and I did not see any sign of a loose connection.
It could be anywhere. Are there springs that contact the battery? Is there a lead from the battery to the light? Does the charger put out juice? All things to check, and then some.
vol
9
10-25-15 11:08 PM
Spld cyclist
3
11-28-11 04:10 PM
Marc7200
2
10-18-11 08:00 AM
Don in Austin
13
12-13-09 11:53 AM
