Front Derailleur with more range why not?
#51
Quoted: 7652 Post(s)
Liked 3,478 Times
When I say "In Fact" I am not speaking rhetorically. You can actually See the derailleur move and you can see that in the "low" position it is indeed closer to the BB and farther away from the BB in two planes -- it both higher and further outboard---and this is VISIBLE. You can see it. You can measure the relationship between the BB and derailleur cage in each position.
VISIBLY, he front derailleur both lifts the chain vertically and pushes the chain horizontally.
Again I say, the line "Who your going to believe, me or your lying eyes" was meant as a Joke.
#52
Quoted: 3511 Post(s)
Liked 2,926 Times
This is prima facie wrong. Go shift and watch the motion of the derailleur cage. The derailleur does not only push from side to side, it also swings up and down. Up. and Down. "One way of another" implies there is only one plane .... in fact the derailleur moves in an arc through space, in both the horizontal and vertical directions.
I am actually starting to believe a lot of people here have no idea what they're talking about.
#53
Liked 3,478 Times
I guess the derailleurs on my bikes---and I have owned several dozen---were all different than all the rest of the derailleurs in the world.
Cool.
#54
Liked 2,926 Times
How do you explain how old FDs, like Simplexes work--where the FD literally just moved side-to-side, with zero upward movement? Those must baffle you.
#55
Quoted: 3952 Post(s)
Liked 7,298 Times
Likes For tomato coupe:
#56
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
25-622 Drive wheel.
34t Chainring for hill climbing and 70t chainring for a speed of 90km/h (56mph) at 110 cadence.
The vehicle should be able to go around 70mph.
https://www.gear-calculator.com/?GR=...N=KMH&DV=teeth
But that's beside the point.
Speed ranges for 11-40! and 34/70! Ha, two more shifts above 30 mph. Charts clipped from Mike Sherman's Gear Calculator
At typical road bike cadences:
At very low cadences, note the graph stops at 40 mph here.
12-25 and 34/70! No overlap at all between the two chainrings. That's really annoying. Needs electric shifting, the front rings will be shifted often, and the rear will go two or three clicks at a time.
#57
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,900 Times
While this is certainly true of those FDs where the cage is made up of two flat plates, more modern derailleurs often incorporate some kind of shaping of the inner cage, which looks kind of like a ledge. Now, I will grant you that the bulk of what shifts to the big ring is the chain simply being shoved into it and then lifted by the pins and ramps on the inside of the big ring. But IIRC, Shimano made claims BITD that their derailleurs actually lifted the chain to enhance shifting. And as we all know, no bike company would EVER make hyperbolic claims that don't really comport with reality!
#58
Liked 11,900 Times
I'm trying to imagine what you'd have to put on the inside of the big ring to lift the chain from 34 to 70 teeth.
#59
Liked 7,298 Times
#60
Quoted: 2483 Post(s)
Liked 2,955 Times
Some of us told him that it wasn't the gearing that was the problem, it was aerodynamic drag. He was sure we were wrong. I even provided the famous Robert Forstmann toaster video to show that there were track cyclists with big legs but that even they wouldn't be able to hit 50 mph riding alone, regardless of the gear. He wasn't dissuaded.
#61
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
On an unfaired upright bike. That's not what's being contemplated here.
I also don't think anyone would expect him to hit 70 mph. I think the experiment of how fast it could go is interesting.
#62
Tragically Ignorant
Liked 9,098 Times
I'm not sure he was just BSing. It appeared from what tellmethetruth wrote that he saw a lot of skinny guys riding around in packs and genuinely concluded that a guy with actual muscle could ride much faster than they could. Apparently he was built more or less like a linebacker.
https://youtu.be/S4O5voOCqAQ
https://www.bikeforums.net/20845741-post96.html
He claimed without proof that he was able to sustain 40+ mph in the flat, no wind assist. for 5 minutes using a 53x11 gear combination. He then refused to answer anything about faring
Likes For livedarklions:
#63
Liked 2,955 Times
Here's the post that made me convinced he was just lying about everything:
There were some exchanges in the thread about the test run conditions: would it be captured on video? Would an independent witness---preferably someone already known on Bike Forums who lived in his area---be present? His replies began to be a bit vaguer and more intermittent right around then.
I, too, am sorry that he disappeared from his own thread. I also miss the posts from his "Anyone can be a winner!!" boosters.
#64
Tragically Ignorant
Liked 9,098 Times
Yes, I forgot about that post. Wonder how he came up with the 40+ mph, since he apparently didn't have a bike computer---he decided to order one after his thread gained momentum so that he could prove it to us doubters when he hit 50 mph.
He wouldn't post a picture of his bike because the computer didn't work! At that point, someone knows they are busted.
He didn't just disappear from the thread. He hasn't posted anything since.
I think the entire thing was a piece of fiction.
#65
Liked 11,900 Times
#66
Tragically Ignorant
Liked 9,098 Times
A reasonable assumption, but an assumption nonetheless, given that the OP has not been especially forthcoming about it.
I didn't pull that number outta my ass, you know. It was mentioned above and determining the power you'd need under the best circumstances on an unfaired upright bike to achieve that seemed like it might be of interest. You're welcome to be uninterested. That's what the scroll wheel's for.
He mentioned that he will be doing something to reduce drag, I'm assuming that's fairing. My impression is that he's just starting on this, and is at the "thinking out loud" stage. He did throw out the 70 mph number, and it's almost certainly improbable.
I like big gears and I will not lie. I hope he builds it. Don't know how fast he could go, but I'd like to find out.
#67
Liked 2,926 Times
A simple question that cannot be answered by people who think front derailleurs somehow "lift" the chain upwards (and presumably also "pull" it downwards in the other direction) because they can "see it" move up and down. A simple question asking why front derailleurs that move side-to-side on a horizontal shaft can somehow shift a chain "up" cannot be answered. Or, more likely, is simply ignored because it does not comport with their false understanding about how they think front derailleurs work.
Charlatans.
The fact that some cyclists, even those who bikes, cannot grasp how a front derailleur functions is simply astounding. They claim such things like or
I bet even a lesson from the late great Sheldon Brown can't convince them.
https://www.sheldonbrown.com/front-derailers.html
#68
Quoted: 2604 Post(s)
Liked 1,933 Times
For a grin, think of the possibility for massive chain suck and jams on a rig like that!
Likes For pdlamb:
#69
Tragically Ignorant
Liked 9,098 Times
Just as I expected: Crickets.
Charlatans.
The fact that some cyclists, even those who bikes, cannot grasp how a front derailleur functions is simply astounding. They claim such things like or when, in fact, they have no real understanding of exactly how the part works to begin with. If you cannot understand how probably the simplest of bike components works, and when it is explained to you call it "wrong" or "not correct," then you have lost all credibility.
Charlatans.
It's a word quibble that really is a red herring and I wasn't going to waste any more time on it, but since you have this little class, I'll go ahead. At best, your statement that all that the derailleur is doing is pushing the chain back and forth is grossly over-simplified. It's accomplishing the lift by precisely squeezing the chain against the chain ring such that the lift is caused. FDs' role in this is not passive. You want to say the ring is causing the lift, and I want to say that it's the coordination between the derailleur and the ring that's causing the lift. Either way, the way you described it is grossly incomplete if you don't note that there has to be fairly precise coordination between the FD and the chain ring, and that switching to a much larger chain ring makes that more complicated.
I get that your justification for making a sarcastic comment to the OP is that you think you're the smartest guy in the room, but again my main point was that you were acting like a jerk when you said it to him. If it makes you feel better if I say that technically, at an absurd level of abstraction, you were "correct", fine. I apologize for not recognizing your complete mechanical genius. You still were acting like a jerk and you should apologize to the OP.
#70
Liked 2,926 Times
I get that your justification for making a sarcastic comment to the OP is that you think you're the smartest guy in the room, but again my main point was that you were acting like a jerk when you said it to him. If it makes you feel better if I say that technically, at an absurd level of abstraction, you were not "wrong", fine. I apologize for not recognizing your complete mechanical genius. You still were acting like a jerk and you should apologize to the OP.
#71
Liked 7,298 Times
#72
Tragically Ignorant
Liked 9,098 Times
#73
Liked 2,926 Times
#74
Liked 2,926 Times
#75
Tragically Ignorant
Liked 9,098 Times
Considering I have frequently described myself as the world's worst mechanic, I honestly don't care if he takes the trophy. He had no business in talking to the OP like that. Now he's pretending it was supposed to be helpful?
