Spoke tension?
Spoke tension?
I have purchased spoke tension meter, i set tension and tool shows around "25" i have 2.0mm straight gauge spokes, so its about 49 KGF according to chart?
Is acceptable tension range for 2.0mm spoke 49-160 KGF, whats the recommended KGF tension for single walled 700c rim and single walled 24" rim?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Depends on the rim but I'd want to see 80-100 kgf.
Likes For cxwrench:
There's no way there's published specs on a cheap single wall rim like that, but I'd probably bring it up to about 80-90KGF ideally. Quality rims to whatever the rated max is, if unknown usually I do about 120kgf.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I have never found any “published specs” for any rim. Ranges, yes. Actual values, no. And those ranges tend to be a single number for all of the rims that the manufacturer makes. Velocity, for example, gives a single range for their 15 different models of rims even though the rims have a wide variety of profiles and widths. They have more information on the width of tire for each rim than they do for spoke tension.
110 to 120 kgf is probably a good guess but it is only a guess.
Stuart Black
Stuart Black
Quoted: 1088 Post(s)
Liked 1,025 Times
I would agree with those who say 80-100 for a singlewall rim, which would suggest your spoke tension is too low. However, you may want to verify that the tensiometer is actually correct, having a known good wheel with proper tension will tell you if it is in the ballpark though unless you know what its actually at won't give you precise accuracy. Even Parktool meters have been known to be inaccurate from the factory since they just spec a spring and make the charts based on the expected results from that spring type, springs of course vary. This is why Wheelsmith meters the chart was based of the tool's actual reading of a tensioned spoke with a known reading. Its also why the wheelsmiths were expected to be sent in every few years depending on number of wheels built and have a new chart made to reflect the actual results of the tool. Test the tool before presuming the wheel is that far off. Also, the big advantage of the tool isn't its perfect accuracy to spoke tension but its ability to tell you how accurate the spokes are in relation to each other, having a wheel with tension that isn't perfect but all the same is still a better build then spokes with wildly varied tensions.
I should have mentioned i don't want super tense spokes (e.g. like mountain bicycle with active suspension), i use single wall rims intentionally because they flex better to make ride softer. Coming from that what tension is minimal, provided i adjust it often so its not a problem to make adjustment once a month or so.
Picture is from the internet i antique single walled aluminum rims.
if you want a softer ride let some air out of your tyres or run a wider tyre, single/double wall rims with loose or tight spokes will make little to no difference to perceivable ride quality.
Likes For headasunder:
Quoted: 2483 Post(s)
Liked 2,955 Times
Wider tires can increase shock absorption; using single-wall or double-wall rims makes no difference to rider comfort..
Likes For Trakhak:
Bigger tires with lower pressure is option, but it affects speed too much IMO.
When i press down single walled rim down with my body weight it actually flex somewhat, double walled rim does not, somehow i believe this flexing can absorb some or the small road vibrations.
If we are talking about cruising / city bicycle i want to give it a try.
Bikes: lots
Liked 2,932 Times
Fact it being single wall rim dont make it worse its just different design.
Likes For cxwrench:
With too low spoke tension you will feel the wheel wobble under load. Go for 100kG tension and lower the tire pressure. I am guessing with the tires shown you could go a 30PSI depending on the vehicle weight. There are sites that help with tire pressure on the web.
Liked 2,955 Times
Quote from this page:
"If the wheel is strong enough for its intended use then its stiffness is more than adequate.
Since the stiffness of the frame, pedal-cranks and especially the tires is much lower than the wheel stiffness, the rider cannot possibly feel the minute differences in stiffness among different wheels. The "liveliness" attributed to "stiff" wheels is an acoustic phenomenon that results largely from light tires with high pressure and to a lesser degree on tight spokes. This mechanical resonance can be heard, and possibly felt, in the handlebars and is not related to wheel stiffness. Liveliness may have some merit but it does not result from certain spoke patterns and has nothing to do with wheel stiffness.
In summary, stiffness is generally not an issue to consider. A wheel that is strong enough to withstand the loads of its intended use, with a reasonable margin of safety, is stiff enough."
Likes For Trakhak:
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
You're obviously talking about pressing down on a free-standing rim that hasn't been built into a tensioned wheel. Try that again with a fully tensioned built wheel. The spoke tension prevents any flexing of the rim, regardless of whether it's double-walled or single-walled. The late Jobst Brandt, a former Porsche engineer who wrote "The Bicycle Wheel," the first, definitive work on the forces at work in the structure of a bike wheel, determined that bike wheels will dent before they flex to any significant degree.
Likes For LV2TNDM:
i tighten the derailleur side spokes til the wrench almost starts to round off the nipples.
don't blame me, that's what ken spears told us to do in the wheel building class at Bicycle Outfitter in Los Altos.
Liked 2,955 Times
Yes. My pet peeve: the dimensions of spoke nipples for bicycles were established many decades ago, long before high-strength stainless steel spokes became ubiquitous on the market. Rounding off of spoke nipples, a.k.a. the old mechanic's joking universal instruction to "tighten the bolt until it breaks and then back off a quarter-turn," would become a thing of the past if the width of spoke nipple faces were increased just a few thousandths of an inch.
Quoted: 279 Post(s)
Liked 207 Times
Oh, and isn't it nice that this method is no longer necessary, tongue in cheek or not? A proper spoke wrench, brass nipples and proper lubrication will ensure 120kgf is reached without a rounded nipple to be found! Heck, even alloy nipples as well. I've been perfectly happy with them living and riding in the Bay Area. No issues yet, except the once-a-decade rock impact that pops one.
https://cdn.bike24.net/i/mb/0b/b9/4b...00-d-15231.jpg
what most folks neglect (wilful ignorance) is to get the proper lube for the job at the eyelets-nipples contacts and also in the spoke threads.
https://www.klueber.com/my/en/produc...icating-waxes/
Lubricating waxes are not solid lubricants in the proper sense. They form a dry-to-the-touch layer on the surface of the prepared part to ensure reliable lubrication while reducing boundary and mixed lubrication friction. They consist of high-molecular synthetic hydrocarbons, additives and oil (mineral oil, synthetic hydrocarbon).
first of all... if you don't prevent metal to metal contact then microcracks will develop and then stress corrosion will be more of a problem.
and then... if you ever use spokes that are thin they'll be more vulnerable to torsion if proper lube is not present. more friction - more torque on the spoke, more torsional stress and strain on the spoke.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
If that is a front wheel in the photo above, you are taking the tension reading on the non disc, or low tension side. if this is correct, 100 KGF is likely way too high.
Take your tension readings on the high tension side, drive side rear, disc side front. Centre the rim and the low tension side will be what it is.
Likes For Dan Burkhart:
Forget to ask where i supposed to check the tension closer to the rim as on the photo in the first post (random picture from internet) or closer tot he axle?
I don't have disks regular linear pull brakes on mine.
Front wheel i have equal tension both sides around 100kgf
What do you mean?
Rear wheel i currently set 120kgf freewheel side and 70kgf other side.
What do you mean?
Really Old Senior Member
Because it is what it is when the DS is 120kgf.
I measure with tension meter each sides multiple times all around while i true the wheel until i get equal reading for every spoke on each side took like 3 hours...
It's a ratio between Center To Flange dimensions.
Center (rim) to Right Flange/Center to Left Flange. (hub flanges)
Download Spocalc.
It shows what % of DS/NDS is.
https://www.sheldonbrown.com/rinard/spocalc.htm
Likes For Bill Kapaun:
