Show your Trek Multitrack!
#251
Go, CroMo, go!
Bikes: Custom Bantam AdventureBike,93 Bontrager Race mtb, 07 Lemond Poprad disc cyclocross, Black Mountain Cycle Road, 86 Bridgestone Mile 112, 89 Bridgestone MB-2, 93 Trek 750, 90 Trek 750, 90 Trek 930, 90 Diamondback Ascent.
Liked 19 Times
My 93 Trek 750
hanging in the basement for several years. Finally built it up with parts I already had lying around. This is a 93 - Wisconsin-made frame and the last year these were lugged.
build list:
Paul Cantilever brakes
no-name pink levers from free pile
Nitto Albatross Bars and Technomic stem
Nitto M12 front rack with Wild 137 basket and Swift Sugarloaf bag
Suntour XC seatpost
old Brooks B17 saddle
XT front and rear derailleurs
Sugino XD2 triple crankset
VP Bice platform pedals
Likes For rseeker:
#253
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I've been riding my steel bikes more often lately, including my 750. I put the butterfly handlebar back on it and I'm friction shifting with Microshift thumb shifters. I have one layer of inner tube wrap on the bar, plus a layer of Serfas cork handlebar tape. The diameter is healthy (about 40mm) and it's very comfortable. With that rear roller clutch, there's no freehub clicking when you coast, and the ride is nearly completely silent...it's a very peaceful ride.
#254
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,529 Times
I found a ('94?) 950 on eBay; it should be here Tuesday and I'm all excited. I'm hoping the paint is as bad as it looks, as I'm desperate to have a green bike, and my other two vintage steel steeds have gorgeous paint jobs too pretty to powdercoat.
#255
Quoted: 1163 Post(s)
Liked 442 Times
Here is my Multitrack that was rescued from the trash. I want to say it is a 770? It was originally silver/geaphite fade.
As as you can see, it is undergoing a drop bar conversion. Since it is a hybrid frame, I’m finding that I need to use a shorter stem than I anticipated to match up with its longer top tube.
I’m also at a stalemate with regard to pre-tensioning my SunTour XC rear cantilever. On one side there is a tensioning nut on the backside that is supposed to allow you to match the spring tension with the other side by backing off the nut against the wro
Likes For masi61:
#256
Liked 442 Times
Continued from #255 above:
...by backing off he nut against the spring. Unfortunately the canti post appears to be too long, maybe it is incompatible with this particular canti brake. Maybe someone has worked with these. It looks like I might need a spacer or a few washers to allow sufficient clamping force of the post bolt. Right now the caliper is flopping around under no spring tension.
I’m real excited about the wheelset. These are HED Belgium Plus Rims. I have a Challenge Paris-Roubaix tire mounted in the rear with a latex tube. The hubs are new old stock WTB Momentum Greaseguard with an IRD 10 speed cassette. Right now I have a Dura Ace 7800 GS mid-cage touring derailleur on there but I might change this out.
#257
Liked 762 Times
The roller clutch hub was not very popular on most bikes, though they have some unique advantages. They're completely silent, so no click-click-click as you coast along. For that reason, I understand they were common on police bicycles. They were also fitted to 750 only (at least in 1997). 730 and below had regular ratchet-and-pawl freehubs or freewheels. Another advantage is engagement is nearly instantaneous regardless of the position of your pedals. You don't have to pedal forward to engage one of the ratcheting pawls; the roller clutch is "on" nearly immediately when the freehub body moves forward.
It's Shimano FH-R050. I think it was an Acera or Alivio level component back in the day. I'm not sure if any modern hubs like it, though I'm sure there are niche ones out there.
Likes For hokiefyd:
#258
Virgo
Mine is a ‘94 or ‘95 (can’t remember) 700 with the blue to purple fade. Currently set up for my new (short!) work commute:
#259
Retro-nerd
Built it up gave it to my GF...she broke up with me and kept the bike.
Would you like a dream with that?
#260
Bummer. Double heartbreak. Time heals all wounds. Good luck
Likes For Wharf Rat:
#261
Happy banana slug
Liked 1,529 Times
My new (to me) bike, fresh out of the box. It still has that eBay smell.
It needs some work, but it'll make a nice tourer.
Such a pretty paint job.
I know you guys are into drive trains...
#262
Liked 762 Times
That's a really nice 750. You'll really enjoy it; the ride is fantastic. It looks like the 19" size?
#263
Happy banana slug
Liked 1,529 Times
The great thing is that that gorgeous paint job is thrashed. I've been wanting a green bike since forever, but the other two steel bikes have beautiful paint worth preserving. This one, the more you look the worse it is, including the initials scratched into the top tube, so it's off to the powder coater sooner or later. It's currently at the mechanic having its wheels trued.
#264
Liked 762 Times
Your bike's uniquely a 1994 model. That colorway (purple-blue fade) was offered in at least 1993 and 1994, but 1993 was the last year for the lugged frame construction. By 1995, they moved to a different colorway. So yours is almost certainly a 1994 model (I don't see any lugs). If it does have frame lugs, then it's likely a 1993.
#265
Happy banana slug
Liked 1,529 Times
#266
Quoted: 318 Post(s)
Liked 149 Times
I saw in the other thread that you don't like the flat bars. What are you going to put on there?
As for me, it took me and two helpers to get the old BB out. My city doesn't have a bike coop so I drove to the nearest one three hours away. They took good care of me, and I came home with a serviced rear hub, the removed BB and a new seat which I like better because it's flatter and fits better. I'm still not riding it until everything's ready though. I just got the stem out a couple days ago, and I need to replace that with a longer one and change my riser bars to flat. Can't wait.
I kinda wish my paint were thrashed because I'll be using this bike. Having good paint and decals makes me feel like I have to baby it, and I'd rather not worry about it.
#267
Happy banana slug
Liked 1,529 Times
Oh you know that's right. Thanks for the pics. Such a lovely bike.
Not sure what bars yet; I'll have to play around. I was thinking some shallow rando-type drops, we'll see. It's weird; this bike was comfortable right out of the box, and I didn't think I liked 700c. Go figure.
Don't baby the bike, ride it! The only thing you really have to worry about is rust, and that can be dealt with as it comes up.
#268
Bikes: 82 Trek 710, 90 Trek 750, 86 Vitus, Nishiki Cervino, 1989 Bianchi CdI, 2 Nashbars, an Italian Steel MTB, Sears Spaceliner, and a 74 Schwinn Speedster. I also manage a fleet of Volcanic Patrol bikes, 83 of them.
Quoted: 109 Post(s)
Liked 234 Times
Twin (sort of) 750s
#269
Liked 762 Times
We took a little jaunt through the countryside this evening, my MultiTrack and I. This is my favorite type of ride, when the shadows get long and the pavement runs out.
Likes For hokiefyd:
#270
Bikes: Wow, where to start? A collection of 1980's and early 90's road, touring, and MTBs from the likes of Trek, Schwinn, Cannondale, Fuji, Miyata, Univega, Panasonic, and GT. It has gotten rather out of control.
Quoted: 140 Post(s)
Liked 173 Times
Found a nice one tonight. 1999 7500. USA build aluminum frame, Deore LX rear, cromoly fork with low-rider mounts.
#271
Bikes: Way to many to list
Quoted: 34 Post(s)
Liked 6 Times
Picked up this better sized 750. The 23” I had was just too big. This one wasn’t in as nice shape, but it’s perfect for my uses. The old suntour stuff was abused so I stripped it & turned it into a 1x7. More than enough for my local. Here it is on a surf check while running errands.
#272
Thanks Combover, they really are just a great all around bike. I couldn’t possibly afford a new, made in USA, lugged, wide tire fitting steel frame. But I got this one for $30. Trek hit it out of the park with these bikes in my opinion.
#273
My babies
I love the 700 series!
Long story with the black 750. I built the black 750 as a tourer. It's one of the last lugged Treks built in the US; it has one those large seatpost lugs. It was a kick-ass commuter till it got STOLEN. Fast forward a year and I saw it being ridden around! He had bought it from a really sketchy bike store. They took off all the fenders, racks, baskets, and ONE shifter.
While emotionally recovering, I turned a beat up 720 to a one-by commuter. Added racks, baskets, and a bunch of stuff from the parts bin.
Now I have two multitracks (well, three if you count one in the projects pile) and i love them all.
Likes For Kentonk:
#274
Happy banana slug
Liked 1,529 Times
Nice bikes, both of them.
Also, I feel you about MultiTracks; I just acquired a '94 750, and love how it rides, despite the too long cockpit and trashed wheels. I didn't think I'd like 700c wheels after tasting the joys of 26" (I'm short), but there's very little toeverlap, and there won't be any once I put on a 160 crank.
#275
Here is their yelp page, worth checking out the store if your bike was stolen in Bay Area/Sac area. It goes without saying i have very strong feelings about the shop.
https://www.yelp.com/biz/t-and-m-bik...vis-6?osq=bike
And I noticed their long top tube as well. That's why I opted for a size smaller than i usually get, and got some high rise handlebars. So glad I got it back.
