View Poll Results: Do You Have a Dork Disk or Not? (Go with FAVORITE Bike)
Yes-I believe in them
16
21.92%
No. It broke and fell off-good riddance
3
4.11%
No. Bike didn't come with one-thankfully
17
23.29%
Heck NO-I removed it
37
50.68%
Voters: 73. You may not vote on this poll
A Dorky Question/Poll
Just Pedaling
Bikes: YEP!
Quoted: 336 Post(s)
Liked 529 Times
I'm kinda curious about the dork disk since watching a Utube video that showed the uselessness of having one. Break out the popcorn and share your thoughts (please).
Quoted: 567 Post(s)
Liked 660 Times
Never in my life have I ever cared if another cyclist on the trail has a Spoke Protector or not.
Yes, it's a "Spoke Protector"
No one should care... ever.
Get on with your silly little lives and stop winging about such tripe!
Likes For CrimsonEclipse:
Bikes: Way too many
Quoted: 915 Post(s)
Liked 608 Times
You can't see it whilst the bike is moving, and barely see it if it's not either. It has a purpose - to prevent a misadjusted shift off the bottom gear in a cassette and into the spokes, which would certainly have more serious consequences than being seen with a dork disc. I know my MTB has one because I had to adjust it a bit, but I couldn't tell you without looking if my gravel or road bikes have them. I assume so but I can't say I've ever had any cause to care.
If you really care, then just remove it but at least make sure your limit screws are set correctly and try to avoid damaging the rear mech on a ride and you'll be fine.
I have one bike with, and one without. I never even think about or notice it.
We have a forum member here named Dork Disk; hopefully he'll come in and post!
Likes For Reflector Guy:
Bikes: There is always room for one more.
Quoted: 185 Post(s)
Liked 391 Times
Big Bicycle may be trying combat the easy removal of the spoke protector. I've noticed some entry level bikes now have freewheels with the spoke protectors cleverly disguised as disc rotors manufactured onto them. This will necessitate the use of dremel tools, angle grinders or such for quick removal.
Don
Don
Pennylane Splitter
Bikes: Yes
Quoted: 1814 Post(s)
Liked 1,456 Times
They're more useful than not, so if I got a bicycle with one that didn't need any rear hub work I wouldn't make an effort to remove it. I have one bicycle that still has one on it, the other bicycles don't have them (most are rebuilds). Similar to the reflectors you get on the wheels of new bicycles, I would not even know if they are sold on any of the internet bike shops I've patronized over the years.
Quoted: 2609 Post(s)
Liked 1,946 Times
In an ideal world with a well maintained bike, dork discs are not needed.
In my real world, **** happens. Bike falls over; chain links somehow get stiff. At most before riding a bike, I'll do the ABC check. I don't check derailer hanger alignment before each ride, I don't verify every chain link swings freely, and I don't have a mechanic on staff to do that sort of thing for me. So after a chain somehow dove into my spokes, and I ended up replacing all 9 outer drive-side spokes on that wheel, I've started re-installing spoke protectors as cassettes wear out.
Likes For pdlamb:
Quoted: 1084 Post(s)
Liked 688 Times
Quoted: 18446 Post(s)
Liked 15,678 Times
I cannot remember that last time I bought a bie that came with one. Maybe early '90s? I am thinking my Trek 930 MTB might have had one. Bought that in '92.
Thread Killer
Quoted: 3166 Post(s)
Liked 1,724 Times
I dislike them, largely because they’re useless, but also because the old, common style of clipped on clear plastic ones would usually crack, rattle, get discolored and be generally both useless and annoying.
I cannot recall anytime in my nearly 40 years of cycling when I wished I had a spoke protector, and can only remember once in my very early years when I had a chain go off the large cog into the spokes, something I attributed to my lack of skills in derailleur adjustment as a newbie.
Nowadays, with abundant educational resources available and much improved equipment, the spoke protector— believe it or not— is even more unnecessary today than it was in the ‘80s.
Likes For chaadster:
Quoted: 427 Post(s)
Liked 703 Times
I had to go out to the garage to see if our bikes have one. Our road bikes have one--but it's not large, is black and unless you were looking, would not notice it. Our mtn.bikes do not have one. Doesn't matter to me, but I see no drawback to a spoke protector, other than adding an ounce or so to weight, and I could take a tool out of the seat bag to offset that! EDIT:--I guess if the disc was plastic or was very noticeable, I'd remove it. On our road bikes, it is thin black metal, unnoticeable, so I'll leave it be. So guess it does somewhat matter to me.
Quoted: 4454 Post(s)
Liked 4,918 Times
I always considered them to be a throwaway shipping item for when bikes are sat in a shop and may not have been checked over before riding. They certainly don't look like a permanent, quality solution to me the way they are usually fitted with flimsy plastic tabs. The one and only time I left one on my bike was on a new Specialized Enduro mtb and it literally fell to pieces on the first hammering down the local trails. I was lucky it didn't damage my drivetrain. So cutting them off is the first thing I do after checking the limit screws before the first proper ride.
I am potato.
Quoted: 1793 Post(s)
Liked 1,634 Times
On bikes with freewheels, it also acts as a dust shield keeping dirt, dust, grime, debris, etc...from entering the exposed bearings on the inboard side. So, at least you've got that goin' for ya. Which is nice.
Car dependency is a tax.
Quoted: 185 Post(s)
Liked 391 Times
I don't know if it's the same as what we're looking at in your photo, but the last Shimano freewheel I bought had a spoke protector like that one. It's just a plastic piece that snaps on and off -- no dremel tool required. It's not very conspicuous but I removed it anyway for ease of cleaning.
Don
Don
Clark W. Griswold
Quoted: 4404 Post(s)
Liked 4,043 Times
If you adjust your derailleur and hanger properly you will be fine and if you get into a crash likely that cheap piece of plastic isn't going to save you. In quite a few times I have had them cause problems and need to be removed beyond just the normal breakage that happens. I don't think I have had a new bike with one, I think it is possible my old trek hybrid may have had one but I cannot remember that far back.
Some of the vintage metal ones look cool and are probably slightly more functional but again if everything is properly adjusted it is not needed. It might help during a crash that pushes things inward so much that it would cause a problem but in that situation it won't help your derailleur or chain or anything it may help the spokes maybe.
Liked 15,678 Times
Quoted: 4227 Post(s)
Liked 2,488 Times
None of my bikes came with dork disc.
Quoted: 7033 Post(s)
Liked 11,067 Times
Likes For Koyote:
Quoted: 3966 Post(s)
Liked 7,383 Times
Likes For tomato coupe:
Liked 11,067 Times
Likes For Koyote:
Liked 7,383 Times
I like pizza.
