Bike rack for road bike?
need to buy a rear rack for a panasonic dx-5000 road bike. must play nice with panniers. no mounts on bike. any suggestions would be appreciated
yes i realize this is not the ideal bike for touring but that's what i got and as patton said "a bad plan executed today is better then a good plan tomorrow"
thks
i probably should have put this in the touring forum. doing so now
thks
Quoted: 1438 Post(s)
Liked 1,092 Times
You could make mounting points by putting Adel clamps around the stays. I would suggest the stainless band over the aluminum, definitely NOT plastic P-clamps. I would suggest putting them down where the stay meets the dropout so that they cannot slide down further. They are available many places, here is one: https://www.mcmaster.com/adel-clamps/
Quoted: 645 Post(s)
Liked 797 Times
If expense isn't a consideration, you could invest in a Tailfin system - beautiful but pricey. One day....
In the meantime, I fitted a standard Blackburn rack to my De Bernardi road frame, which I built into a single-speed runabout. The frame had no rack fittings, but the rear dropouts have small triangular cutouts above the horizontal dropouts themselves. I fabricated small Al inserts that fitted into the cutouts, shaped inner and outer Al plates then drilled a hole for a mounting bolt through the Outer Plate-Insert-Inner Plate "sandwich" - rock solid and completely reversible (ie no damage to the frame). I attached the front of the rack to the seat stays using steel P-clamps supplied with the rack. In this instance, it was a little finicky fitting these around the rear brake, but it worked out. When I have some time, I may figure out attaching the front of the rack higher up on the stays, but it's OK for now. One thing to be aware of with a road bike, which tends to have shorter chain stays, is the issue of heel strike with panniers. I use a top-mounted bag so it's not as issue for me, but I'm pretty sure a pannier mounted on my rack would snag my heel. I would suggest mounting your rack as far aft as possible to ensure that your panniers are sufficiently back for your heels
Quoted: 839 Post(s)
Liked 1,062 Times
Another option is the Tubus quick release lower rack mount https://www.tubus.com/en/products/ac...-axle-mounting And for the upper rack stays a seat tube collar rack mount. https://www.google.com/search?q=seat...hrome&ie=UTF-8
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
Blackburn used to make adapters that filled the triangle section of your dropout which
you then bolted a rack to. might be able to find some on ebay
2 examples of rack built to mount without eyelets or braze ons. There are probably more:
https://www.amazon.com/Dirza-Bicycle...language=en_US
https://www.amazon.com/Thule-Pack-Pe...language=en_US
There's also this seat post adaptor which could be combined with the already mentioned adel clamps:
https://www.amazon.com/M-Wave-Seatpo...language=en_US
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
I've used something like one of these with a small trunk bag on my Litespeed. I forget what brand mine is but I've had it for at least twnety years.
https://www.rei.com/product/697096/t...B&gclsrc=aw.ds
I've seen ones that have the panier arms on them too.
