Sport tourers with cantilever brakes?
Quoted: 753 Post(s)
Liked 737 Times
The "Sport Touring Bike" taxonomy has been thoroughly work over here, and touring bikes get gradated from heavy to light.
I'm wondering about bikes that have cantilever brakes, but are realy "lighter than light", but not quite Cyclocross bikes and certainly not Hybrids.
I've seen the Bridgestone RBT described in these terms, and maybe the Bianchi Volpe, and perhaps even the later model Miyata 1000's.
My own experience with a triple butted splined tube Koga Miyata supports this, but I am Not A Small Person....
So what other touring bikes judged too light and noodley are out there between niches?
" A perfect Sports Touring bike but for those dammed posts...."
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times
The first few versions of the Cannondale ST400 had caliper brakes, while the ST600 and ST1000 had cantilevers. The frames are essentially the same, except for the cantilever posts. They all have a full complement of rack, fender, and water bottle mounts. In 1990, the ST400 got cantilevers. The downside is that that limits you to 27 inch wheels. I have a 1990 ST400 and, to me, it seems like what a good sport touring bike should be, light and stiff. I have never tried it with a full load.
1990 Cannondale ST400
Likes For Pompiere:
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Found it
Nice bike.
Tektro 539's will get you to 700c wheels, but no larger than 30mm tires as mounted...without fenders.
For 650b, you'll need Tektro 559's, and likely better brake levers. Limit there is likely 42's. Again, no fenders.
Either way you'll get into HG freehubs, which is good. And brake pad holders that can accept upscale pads, also good.
I like the sweet spot of 700 X 28, maybe Conti GP's. Match the 539's with some Tektro levers. Good ride, durable, flat resistant, fast...and you can run fenders with them.
Quoted: 838 Post(s)
Liked 1,082 Times
Whats your definition of light? For me its anything 24lb or less sans accessories depending on what the bike is to be used for.
It's hard to imagine many, if any, production, steel, sport tourers with cantis to come in at under 24/23 lbs.
You mention the later M1000's, is the geometry of throe such that they could be considered sport tourers rather than full tourers?
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Hunh, funny you should dig this up. Just the other day rode my 88 Cannondale ST with Tektro 539’s and Tektro brake levers, Conti GP 28’s.
It’s still a pretty terrific ride.
Likes For rccardr:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Norco/Nishiki/Trek made nice ones as well as some mid 80's Bianchi's with 022 frames. I've always been a Clyde but I've never had a canti bike fail under me.
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
The Lotus Odyssey was typically billed as a full tourer, but from personal experience, I can tell you they're more in between full and sport. Depending on the year, they have cantis. I have quite a few more custom/boutique sports tourers with cantis.
Likes For KonAaron Snake:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Early Centurion Pro Tour frames were light and yes sporty, but actually had direct-mount centerpull brakes.
It's the best sport-tourer I've ridden, subs ably for a road bike yet handles off-roading with it's moderate chainstay length affording traction on steeper dirt trails.
Likes For dddd:
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I've developed the thought that a sport tourer with light tubing, 43-ish chainstays, tire clearance for 38+ and cantis would be a dominant bike.
*by "light tubing" I mean 531/Ishiwata022/Columbus SP/Champion #3 neighborhood*
Sport tourers were "also ran" bikes, the "jack of all trades, master of none" and just "bikes." Because an "enthusiast" is going to want performance at some end of their investment- a racer is going to want a bike that has inherent traits of a racing bike- lightweight, nimble... while a tourer isn't so concerned about weight (to an extent) and prize stability over twitchy. An in-between bike is just "a bike" for a person who wants "a bike" and as such, it didn't get the nice tubing, it didn't get the fancy components... it just got **** done.
Around 1983 or so Trek built the 700 and Specialized had the Sequoia- those were bikes with a triple, rack mounts, but with a tighter geometry, quality tubing and caliper brakes. Later on, a lot of the hybrid bikes came with lighter frames than ATBs, but heavier than a comparable sport tourer and flat bars. The "cross" bikes I think of have pretty tight geometry- and no consideration for wider tires. The RB-T was totally in the "sport tourer with cantis" category, but I think the Miyata 1000 was always full-on tourer. The latest I saw was still a 45cm chain stay... my 1990 M1000LT is full-on tourer- nothing "touring lite" about it.
I always yap about my 1986 Trek 400 Elance- it's a 531 main frame with CrMo stays and fork- it's a classy bike, but it was hampered by low/mid components. I've built mine up with a bunch of top end parts- if it only had cantis...
Old bikes are going to have that "product of their time" thing going on- tires were meant to be 28s but could take a 32- the 650B conversions are happy accidents, bikes that had a broad platform of usability either weighed more because they were meant to carry more, or they were more lower/mid level bikes, and cantis didn't go on regular road bikes. A couple of years ago I tried to get a Rivendell A. Homer Hilsen built for me with the old geometry and canti posts. That's pretty much exactly what I was looking for, but something you won't see on much of any vintage bikes.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Bikes: 48 Alleluia, 52 Blondin, 57 Cattaneo, 68 CNC, 55 Dujay, 46 Herse, 76 Singer, 48 LeGreves, 55 Metropole, 62 Holdsworth Cyclone, 49 Carpenter, 55 Condor, 65 Masi Special, 81 Sequoia, 76 Eisentraut, 72 Proteus, 60 Paramount, 77 Trek TX700, 82 Ross
Quoted: 79 Post(s)
Liked 137 Times
French bikes with lightweight frames and cantilevers were not uncommon back in the 40s and 50s. These 650B frames are made from butted Vitus, and are about the same weight as butted 531 or SL.
Late 40s Alleluia:
50s Dujay:
Late 40s Alleluia:
50s Dujay:
Likes For Duke7777:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,605 Times
I'm still unsure about the exact definition of 'sports tourer', but I suppose it is fairly close to that of a 'randonneur' or an 'audax bike'.
And I presume 'ridiculed by the modern touring crowd' also helps.
From the latter category:
25" Roy Thame. Reynolds 531 butted frame tubes and fork blades, 25", 26 lbs as pictured:
And in a similar vein my current winter project, this 63cm Peugeot P 531 W "Normandie". Catalog weight was 29 lbs, including fenders, lights, racks and pump. As found:
Likes For non-fixie:
Quoted: 3514 Post(s)
Liked 2,927 Times
I’d never consider a bike with cantilevers a “sport tourer.”
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
A couple observations about the later Miyata 1000LT that Golden Boy has, and my 1000LT from 1989. Perhaps by that at date Miyata wasn’t really trying to compete with the real purpose built heavy duty tourers. I think I saw that the LT was for “light tourer”.
Comparing 1988 to the later LT from 1989, the fork offset decreased from 65 to 60mm. Specs list a tall 11” bb height too. My 89 measures 11 1/4” with 35 Paselas. I’m not saying it’s sporty, but without a bunch of accessories on it, I was a bit surprised that the ride wasn’t boatish as I was expecting. Was Miyata aiming for a wider audience?
Liked 1,703 Times
Quoted: 583 Post(s)
Liked 699 Times
I stand corrected on the Luxe. I did find it curious on the higher bb and lesser fork rake. One of these though could be in order for the op if he is indeed not a small person. The 1000 certainly isn’t light either so should hold up well.
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
Additionally, you weren’t limited to 27” wheels with cantilevers. Most cantilevers of that era (and even later) were slotted so that they could be converted to 700C. The brake pads only need to be moved 2mm (thickness of a nickel) to go from 630mm diameter of the 27” to the 622mm diameter of a 700C.
Stuart Black
Stuart Black
Liked 4,221 Times
Stuart Black
Stuart Black
Quoted: 533 Post(s)
Liked 1,007 Times
The Cannondale ST400 was not a “sport tour” bike. It has classic touring geometry with long chainstays and relaxed geometry. Sport tour was a designation for road bikes with a more relaxed geometry but short chainstays. It was supposed to be a bike that you could ride fast but still carry stuff. That usually meant that you were going to constantly clipping rear panniers if you used them.
Quoted: 2486 Post(s)
Liked 2,956 Times
Another vote for Cannondale's touring bikes. Many tourists in the U.S. (unlike many or maybe most European tourists) dismiss the idea of an aluminum touring bike out of hand, but if you're not one of them and if you're looking for a lightweight touring bike capable of both sport touring and grand touring, a lot of people consider them the best choice. The stiff frame provides a confidence-inspiring ride where you can actually pedal out of the saddle on climbs without the bike wallowing around the way lightweight steel tourers do. And, of course, they're just as comfortable to ride as any long-wheelbase steel bike, just as Cannondale short-wheelbase racing bikes are as hard-riding as equivalent steel bikes.
Likes For Trakhak:
Liked 2,927 Times
Bicycling magazine spotlighted the mid-1980s Centurion Lemans RS as the quintessential Sport Tourer. Sport Tourer chainstays are short, but longer than what would be found on a true racing bike (For example, 420mm on a 23" Lemans RS, vs. 406mm on a 58cm Prestige). And...eyelets.
Quoted: 1143 Post(s)
Liked 1,752 Times
I'm pretty happy with the '88 Miyata 615 GT, I think it advertised as sport touring. It's race geometry up front and long chain stays. If it were a haircut it would be a mullet.
Likes For Mr. 66:
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
I know it's not a canti bike, but the Klein Performance seemed to be one of these odd birds in the middle. Around 20lbs or less. 74* seat tube, 72.5* head tube, and 457mm chainstays. I'd use one for light touring myself if it wasn't limited on tire size. It seems some 700x28 fit but not any larger.
Likes For theblackbullet:
Liked 2,927 Times
Quoted: 1873 Post(s)
Liked 692 Times
The Volpe is NOT light. I was shocked at how heavy it was. My Schwinn Voyageur was light years better in every regard and it's a touring bike.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 753 Post(s)
Liked 737 Times
I picked the Miyata 1000 and the Bianchi Volpe as the extreme's, to bracket the Bridgestone RBT in the "middle"
I tried to test ride a Volpe, but it was to small, the seller hadn't put any air in the tires, and I got a shard of metal in my hand from the handlebar tape, So it was a "nope, no and hell no" test ride. I should have bought it anyway, as the command shifters were worth the cost of admission.
I've never ridden a Miyata 1000, but I have taken a Koga Miyata City Liner touring, and it was too noodly for me and a full load. I have ridden it extensively unloaded and like the ride enough that its going to get drop bars and eventually lighter wheels and tires, but its still going to be a Hybrid with a jacked up bottom bracket and very high trail. As I remember it has the same tubing specified on its sticker as the Miyata 1000.
I think Mr. non-fixie cut to the chase though. What I'm asking about are Audax bikes.
