Quick move..Should I buy this? Campagnolo
I have about 24 hours to decide
Come with Cinelli Stem and handlebars
100 km or less on the gearset
$360 in USD dollars for it all. I was going to put it on a 1987 Bianchi Limited In Celeste green Metallic
Ive researched and - Well Its Campy but not the greatest.
Need to know ASAP
I will go buy Thursday Morning
I kinda feel I can buy a classic bike for $200 with Shimano 600 gear for $150 and id be better off.
Excellent condition classic Campagnolo bicycle groupset with Italian 700C wheelset for sale. The groupset is the Campagnolo “Victory Corsa” gruppo from ~1985 based on the logos and markings. Victory groupset was created to replace the legendary Campagnolo Nuovo Record with a more updated modern styling. It was originally intended for a 12-speed (2*6) drivetrain, but can be used these with 7 and 8-speed cassettes as well without issue. Everything is in incredible shape and functions beautifully. Brake hoods are in decent shape, Campagnolo brakepads have seen very little use and are near new, chainrings have plenty of life left. The chain is SRAM and includes a master link, pretty much new with less than 200km on it. The wheelset is Italian made with 700c Nisi rims laced to Ofmega hubs. The hubs are Ofmega Master; top of the line from the Ofmega hierarchy. Spin perfectly and have grease ports for easy top ups. Hub spacing is 100mm front and 126mm rear OLD, and both are 36H. Hubs are laced to 700C Nisi HR22 Moncalieri 36 hole rims (622x15 ISO size). The freewheel spins and engages perfectly. Rims are true, and brake tracks have plenty of life left in them. Shimano 6 speed freewheel on there currently. Campagnolo internal cam QR skewers included as well. Pretty much everything you need to build up a frame, upgrade a vintage bike, or complete a new road or commuter retro build! Everything is in great shape and ready to go, just no longer going forward with the project. Would prefer to sell complete, but can part out if there are specific things you need. Detailed parts list: Groupset (All Campy): Downtube shift levers, front and rear brakes, rear derailleur, front derailleur (band-on style), bottom bracket (70mm/Italian threading), crankset (170mm cranks w/ 52/42 chainrings). SRAM chain. Wheelset: 700C Nisi HR22 Moncalieri rims / Ofmega Master hubs, Campagnolo QR skewers, Shimano 6-speed freewheel cassette.
Need to know ASAP
Likes For longhitv:
Quoted: 930 Post(s)
Liked 1,292 Times
Personally I would say no because the price is too high. The Victory group is pretty, but has a weird BCD and was not around for very long, making it virtually impossible to buy chainrings and other parts. For this reason it's not really in demand IMHO. I helped a friend of mine buy a bike that had the same group and I think the entire bike (with Reynolds 531 frame) cost him less than $200. At that price it is probably worth getting, but $360 for just the components I think not.
Also,those Ofmega Master hubs are freewheel hubs, and certainly cannot use an 8-speed cassette as wrongly stated in the ad.
Furthermore, with the amount of scuffing on the crank arms and wear on the teeth I would say that the <100 km statement is BS.
Likes For davester:
Not lost wanderer.
Quoted: 885 Post(s)
Liked 992 Times
Pieces parts group, used more than 100km or stored in a dirty place.
Nah!
Nah!
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Likes For bwilli88:
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
100% agree with @davester and @bwilli88.
Also look at bottom of RD - scrapes all over it. Look at the screw holes and you can see screwdriver scrapes.
If only rode "100 kms" , why did the previous owner have to adjust the RD so much? Inside of the FD is scraped., consistent with lots of shifting.
Rust under top tube at head tube.
Look at the chain stays. Those scrapes are not consistent with a little ridden bike. They look to me like PO had a loose rear wheel and it drifter over and rubbed - and rubbed bad!
"Brake hoods in decent shape"? Look at them, they are starting to tear, at least one on left is.
It may be that seller is saying you could install a wheel that takes a 7 or 8 speed cassette and you this drive train but then it'll be friction shifting, not indexing.
I don't think you'd want to try to mount a 7 - let alone 8 speed freewheel on an hub that takes a 6 speed now....
Curious that a bike with very low km's now has a Shimano 6 speed FW and the chain was switched out for a used SRAM chain with 200km's under it's belt.
AT minimum I would email seller and say:
1) the bike has not been minimally ridden. It has scrapes to the cranks consistent with many miles with shoes rubbing.
2) the parts don't match. You have SRAM/Shimano and Campagnolo playing together, which probably explains the scrapped derailleurs - especially the rear around the adjusting screws. Also that RD looks like the bike was dropped, at least once.
3) those decent shape brake hoods are tearing and new ones will be at least $30 + shipping.
4) those aren't storage scratches on the frame and forks! Especially not on the rear triangle.
Lastly, why the sense of urgency? Be careful of sellers who are in a rush. If you google "signs of a scam", artificial urgency is one you will always see listed.
You can find better elsewhere - that is not a $360 bike.
Should also say - check out the thread below and see if anything nearer to you
https://www.bikeforums.net/classic-v...e-part-ii.html
Likes For WGB:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Make sure that the Victory rear derailleur has the little toothed do-dad to set the angle of the dangle. Without it, the derailleur is a paperweight.
Likes For JohnDThompson:
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
My opinion is that Victory is a great group if you are honest about your expectations. Victory is old school and may feel very unrefined compared to Shimano groups from around that same period or shortly after.
I like Victory and Triomphe because of the groups simplicity and ruggedness. That also puts more responsibility on the rider in regards to shifting accuracy and stopping in moist conditions. Part of the fun in old bikes. No indexing or duel pivot brakes here.
Likes For embankmentlb:
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
(Second best change was replace the original 52-42/13-23 gearing with 46-38/13-26 "geezer gears."
Likes For John E:
Quoted: 1607 Post(s)
Liked 2,216 Times
@John E - Have you tried Superbe Pro hidden springs with the mating levers? I have this set up on the 760 with surprisingly good performance.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
The seller's claimed i15mm rim width sounds very optimistic to me.
The Cinelli bars/stem have little value unless of the right dimensions.
Note about this package deal; the Japanese-made Bianchi frame is the OP's frame, not part of the sale!
The selling price is almost double what I would pay on a good day.
I'm not sure what these parts would be worth in the future(?).
Quoted: 1248 Post(s)
Liked 1,323 Times
Need to know ASAP
Need to know ASAP
Liked 1,296 Times
Well stated.
The claim that Victory was created to replace Record is in itself a pretty wild exaggeration.
Mileage on these parts looks more like a few thousand miles to my eye from these photos.
The condition of the rims would seem to be a big factor in this ensemble's actual value, so would need to be carefully evaluated in person.
One could build up a very nice Bianchi Limited using these parts IF the rims are in great shape and IF the bar/stem dimensions and gearing ratios suit the rider's fit, terrain and fitness level. Oh, and saddle, tires, tubes, tapes, cables, headset etc. not included. Will that chain even be long enough?
Its just sitting in my corner of my Garage!
The Campy Gear is a separate buy that I was going to purchase to put on this Limited Celeste green metallic bike. But sounds like I am going to shy away based on above.
Likes For longhitv:
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,599 Times
Thread moved from C&V to C&V Appraisals.
Quoted: 159 Post(s)
Liked 375 Times
The purists will kill me for saying this, but by far the best thing I ever did to my Bianchi was to replace the single-pivot Modolo or Campag. sidepull calipers and Modolo levers with dual-pivot Shimano calipers, KoolStop pads, modern cables and housings, and Shimano aero levers. Now I actually feel safe riding it.
Just to clarify, The Frame is mine.
I paid little in my opinion for it $100
Its just sitting in my garage and I thought Id outfit it with this groupset
So the Campy gear alone is $360
Which makes it even worse.
I was going to touch up the frame and use it now and then.
Likes For longhitv:
You can buy a complete bicycle with more appropriate parts for comparable dollars.
Patience and persistence will be your allies.
