Widest Handlebars other than Zinn/Nitto?
Quoted: 96 Post(s)
Liked 30 Times
Depends on where you measure and what you want. Some bar models/makers (Salsa to name one but others as well) measure width at the lever hoods, so with the 12* (or so) flair on the drops they measure well over 50cm(example 46cm Salsa cow chipper). Shims are also available for fitting a smaller diameter bar into a 31.6 stem
Brian
Brian
Brian
Brian
Slacker
Bikes: 1986 Peugeot Orient Express, 1987 Trek 560 Pro, 1983 SR Semi Pro, 2010 Motobecane Le Champion Titanium, 2011 Trek Fuel EX8
Quoted: 97 Post(s)
Liked 6 Times
Quoted: 18465 Post(s)
Liked 4,568 Times
Are you looking for drop bars or upright bars?
There are quite a few options for wide upright bars. I've got a set on a frame that I bought that is about 30" wide, but alas, for a 26mm stem, I think.
