Carbon vs aluminum
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
The pros are
- basically no pinch flats
- no fragile bead hook profile
- pretty much eliminates heat dissipation/ delamination issues for rim brakes
- lighter
- better safety margin for high speed punctures
- can run lower pressure
- arguably fewer flats
- bargain priced used available.
- lighter
Quoted: 18883 Post(s)
Liked 10,646 Times
Don't buy tubulars this day in age.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
For a wheelset, low rotational inertia is the #1 performance requirement, which helps you to reconnect with the wheel in front of you coming out of corners. If you are behind a group of say 10 riders, at 40kph, you are basically coasting. But if you drop 10 feet back, exposed to the wind, you have to amp up the watts to close to that of the pacemaker. As in 100 to 400 watts ASAP. If you cannot, and drop back, then you are finished: solo for the rest of the ride.
Quoted: 1528 Post(s)
Liked 718 Times
Logic says any gain in acceleration you get from lighter weight is offset by a loss of inertia; you have to work harder to maintain speed. You get a slight benefit for climbing, and maybe improved braking.
Another benefit of a lighter bike that occurs to me is less unsprung weight; every time the bike has to move over a bump, that's proportionately less energy lost from whatever fraction of the force that doesn't end up moving the rider too (rider could be unweighting, seatpost could flex). That might be approaching significance, but I haven't seen anybody talking about that, let alone trying to quantify it. The unsprung weight factor might also be relevant for grip.
But it's all pretty marginal stuff.
What isn't marginal is what a frikken beast your whip feels like when it's rocking a deep 1kg wheelset.
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
I love my tubeless setup, but no way do they have the same feel as sew-ups, especially silk sew-ups. And with tubeless, I am slightly less confident that I can get up and rolling again if there's a flat.
...every time the bike has to move over a bump, that's proportionately less energy lost from whatever fraction of the force that doesn't end up moving the rider too (rider could be unweighting, seatpost could flex). That [i]might be approaching significance, but I haven't seen anybody talking about that, let alone trying to quantify it.
https://blog.silca.cc/part-4b-rollin...-and-impedance
Liked 718 Times
Read up on impedance and rolling resistance. This has been covered.
That the break point is a function of system weight has absolutely been discussed, perhaps not in the one article I cited, but in the context of understanding the factors that determine when the breakpoint occurs. There's little point in understanding the slope of the Crr curve beyond that point as it doesn't make sense to ride there at all.
