Solar panel on e-bike stem
Would it be worth it to equip an ebike with a small portable solar panel on the stem to recharge while sitting idle outdoors? I commute and can only lock my bike outdoors. If I were to get an e-bike, I wonder if I could forget to charge it overnight.
Quoted: 18883 Post(s)
Liked 10,646 Times
I guess it depends on a lot of things, but the amount of electricity you get from a small, stem sized solar panel for ?? minutes is unlikely to equal the amount of electricity it takes to move you and your bike.
Likes For Seattle Forrest:
Quoted: 2604 Post(s)
Liked 1,933 Times
How many weeks do you plan on leaving the bike out between rides?
Likes For pdlamb:
Quoted: 1248 Post(s)
Liked 1,323 Times
Under ideal conditions, solar panels generate approx 15 watts per square foot or .1 watt per square inch. Determine how many watt capacity your battery pack is and google will assist you with the math from there.
Now I am sure my calculations are way off but first run-through for a 1 Sq/Ft panel, you would need to have 127 peak sun hours to charge a Specialized Creo e-bike. Hopefully, there are some smart engineering types who point out how wrong I am but its a start.
Quoted: 3461 Post(s)
Liked 1,466 Times
If the one way distance for your commute to work is a distance of a half mile to one mile, reverse that at the end of the work day, do you really need an e-bike for that commute?
When I worked downtown in my community, I had to walk half a mile from my rented parking place to get to work.
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Liked 1,466 Times
Likes For Tourist in MSN:
Quoted: 1278 Post(s)
Liked 1,392 Times
it would be closer to “worth it” if you put it on or where a rear fender/rack goes. you could probably get one square foot without a massive drag penalty. maybe you can make something that unfolds to two square feet. at that point, you’re talking about 30-40 watts, which over 6-8 hours is about half of a smallish eBike battery if you had a reliable and efficient way to do DC to DC charging. unfortunately that’s not easy. there’s lots of info out there on this, but most people choose a much larger array, an inverter, and standard AC chargers. not something you want for your commute rig.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
Liked 253 Times
If you have a secure location to park your bike, which I assume you don't since you have to lock it up, but the only way you could charge the bike is to get a 4 panel portable solar charger, cost about $70 on Amazon, you could put some charge into the bike, problem is, if your bike is like my wife's, they don't make the battery compatible to be plugged into a USB port to charge it with, instead there is a large round plug that plugs into a charger, then the charger has a standard wall outlet style plug, portable solar chargers only use USB style plugs.
