HiTen stays. Should I upgrade my mtb?
Old 11-25-22, 11:46 AM
  #51
Schweinhund
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times in 456 Posts
Originally Posted by Schweinhund
V's and canti's mount at the same point, 990's mount different.
And 990 mounts are interchangeable between cam brakes ands u brakes.
Schweinhund is offline
Likes For Schweinhund:
Old 11-25-22, 03:16 PM
  #52
kommisar
Quoted: 69 Post(s)
Liked 66 Times in 33 Posts
Originally Posted by Soody
I would also upgrade the front arms while you're at it. The ones i like are the shimano medium profile ones (like below), from altus to xt for about 5 years all basically the same, just different finishes, always seem to work really well. It's hard to say why different arms are good or not aside from flex and play and some say the wide-profile ones are stronger but i haven't found that and i would put it down to 'magic' and recommend you find some of these out of a parts bin and clean them and put new pads on and you will get good braking.
I found these cantilevers in my parts bin. Better I assume?
@Schweinhund @oldbobcat @wrk101
kommisar is offline
Likes For kommisar:
Old 11-25-22, 03:53 PM
  #53
Schweinhund
Bikes: a couple
Quoted: 563 Post(s)
Perfect, but a bit harder to source brake pads. internet required, most LBS's only have garbage ones.
Old 11-25-22, 04:03 PM
  #54
kommisar
Quoted: 69 Post(s)
What do I search for to find to correct pads on this internet you speak of?
kommisar is offline
Old 11-25-22, 04:09 PM
  #55
Schweinhund
Bikes: a couple
Quoted: 563 Post(s)
Want another pair? tell you what, you can have a pair of each. see which you like better.
v brake next to cantilever. notice the pivot location and pad fixing location.
Old 11-25-22, 04:13 PM
  #56
Schweinhund
Bikes: a couple
Quoted: 563 Post(s)
these are pretty wonderful.
https://www.amazon.com/Kool-Stop-Eag...4HO?th=1&psc=1
Old 11-25-22, 09:57 PM
  #57
oldbobcat
oldbobcat's Avatar
Quoted: 514 Post(s)
Liked 448 Times in 337 Posts
By all means. As for pads, they are available. The two shops where I worked had Avid or Jagwire in stock.
oldbobcat is offline
Old 11-26-22, 08:34 AM
  #58
kommisar
Quoted: 69 Post(s)
Thanks everybody for the helpful suggestions. I will be putting new pads on the bike today and during the next major overhaul I will be switching in the cantilevers from my parts bin onto the bike. I will not pursue a better frame since it would not make much of a difference in ride or braking. It is hard enough to find a step through in a 21" size and a fully cromo frame is probably unobtainium at this point.
kommisar is offline
Likes For kommisar:
Old 11-28-22, 12:53 PM
  #59
tricky
Quoted: 634 Post(s)
Liked 444 Times in 298 Posts
Update us on how it goes! We're all invested now. haha
And post to this board if you ever need help sourcing a larger step-through frame. 26" might be hard but there's a lot of folks here that love step through frames and probably could help you out with finding a mixte or other step-through. Here's a thread of good looking mixtes for your perusal https://www.bikeforums.net/classic-v...ispreloading=1
tricky is offline
