Enve G23 & tire compatibility? (Pirelli Cinturato Gravel H)
Quoted: 23 Post(s)
Liked 13 Times
Anyone run into issues with subject combo? Only had time to mount up the front tire/wheel thus far, but it was easy-peasy & held air & sealant just fine. Pumped up to about 50 psi & did a 3 mile test loop. Two days later I saw that it was totally deflated. Pumped it up to 40 psi and an overnight it was totally deflated again. Rim tape is factory Enve & I’m am using their valves (per Enve recommendation) with Orange Seal Endurance.
Any and all info is appreciated.
Old guy on a bike
What width tires? I’m assuming they are wide and that’s why you went with the 650b, so 50 sounds high
have you tried this:
https://silca.cc/pages/sppc-form
ETA: measure your inflated tire width to use the calculator, it has a huge impact
