Why am I faster on gravel w/ hybrid than road on road bike?
Bikes: Giant Defy 5, Giant Escape 1, Windsor Wellington 1.0
So I have noticed a trend via Strava that I am generally 1 mph+ faster on a limestone trail than on the road? For the gravel trail I ride a Giant Escape 1 and on the pavement I ride a Giant Defy 5 (both 2015). On average I am around 16-16.5 on the pavement and 16.5-17.5 on the limestone trail? Any input into why this might be? Certainly if I have been too vague let me know.
Quoted: 9 Post(s)
Quoted: 4560 Post(s)
Liked 2,802 Times
Your favorite gravel trail might be sheltered from winds by trees, while your pavement route may have just enough wind to slow you down. Happens routinely on one of my favorite semi-rural routes, where I feel faster on the rougher residential gravel and asphalt pavement than on the smoother highway shoulders. But the east/west highway is very subject to a steady wind, often shifting from day to day and with time of day, so I'm often slower going home because the headwinds are just strong enough to make it a chore even on the gradual downslope. Meanwhile the rougher gravel and pavement roads are heavily sheltered by trees.
I do notice my watt output is higher on gravel. Elevation wise it is fairly similar or even has a bit of a higher elevation climb on the trail. I do know the trail rather well as it starts a block from my house and runs roughly 40 miles. Perhaps since I only have to make a few intersection stops plays into it. But I have also noticed that I am faster on my hybrid riding on pavement than my road bike. Perhaps a fit issue?
Quoted: 550 Post(s)
Liked 325 Times
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Because wider tires are faster. Duh.
Bikes: 90's Bianchi Premio, Raleigh-framed fixed gear, Trek 3500, Centurion hybrid, Dunelt 3-spd, Trek 800
Quoted: 2167 Post(s)
I had an all-steel "10-speed" in the 1980's that I thought ran great. However, I was razzed by people who said things like: "I wouldn't be caught dead on a bike with cottered cranks." So I bought a sharp-looking road bike with double-butted tubing and alloy everything else. Nothing wrong with it, but I remember the immediate disappointment when it seemed to have less "drive" or momentum. Just a vivid impression, I never did measured comparisons of speed. However, I had the necessary street-cred.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Some engines are better for sports cars; some engines are better for SUVs.
Quoted: 86 Post(s)
Quoted: 9 Post(s)
That could be? Though the trail runs through quite a bit of farmland with little shelter from the wind/crosswinds. I do know the trail inch by inch versus when I ride on the road. The other mystery I am trying to solve is why I am also faster on a cheapie Windsor Wellington I got off CL compared to my newer, more expensive Giant Defy? Perhaps I need to cough up the cash for the fitting on the newer road bike?
Yes, I have noticed the handlebar position on the Windsor is a better fit, I did have the stem on the new bike replaced which made a bit of a difference. But I still can't really ride the drops comfortably. The watts are based on the measurements of my last few rides on each bike.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Quoted: 9 Post(s)
Liked 2,802 Times
The Giant probably weighs closer to 30 lbs with the stock tires, which may be slower in exchange for the puncture resistance.
Windsor specs and user reports indicate that bike weighs around 24 lbs, depending on tires. That's pretty light for a very affordable bike. And the Continental Ultra Sports may just be a very good match for that bike and your riding style. That combination sounds like a good value.
Oh wow, I would have thought the Giant weighed less than that? I put the same tires on the Giant. The only downside with the Windsor is I do not have much of a granny gear that makes climbs difficult and not a gear high enough to pedal all the way down descends. In my hardest gear I generally cannot pedal all the way down. The Defy's compact gears give me much better range.
Bikes: A hauler, a commuter, and a steamroller.
Quoted: 15 Post(s)
My 2014 escape 2 weighs between 30 and 35 lbs, but that's with a rear rack, panniers, rear top bag, and a pair of Schwalbe Big Bens.
The Escape 1's since at least 2015 have had a carbon fork, so a stock one should be in the mid-20's.
