CO2 inflator. Which one?
#52
Quoted: 2588 Post(s)
Liked 4,824 Times
DD
Likes For Drillium Dude:
#53
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
That's the way. It would be a celebration day. Dancing days. For use over the hills and far away. To ramble on. No fool in the rain here. If it didn't work, it would be nobody's fault but mine. And if someone asked me for a pump, I could give no quarter.
Likes For SurferRosa:
#54
Quoted: 5224 Post(s)
Liked 3,581 Times
I have a couple of CO2 inflators (come in handy for night riding) and one of them is like this one. Don’t like it. The spring is stiff and you have to push on the head while the liquid flashes to gas which gets really, really cold. The Genuine Innovation Ultraflate is better insulated.
#55
Liked 3,581 Times
#56
Liked 3,581 Times
the cartridges come in diff. sizes
it was particularly useful one time when I had a slow leak. I was able to occasionally boost the inflation as I finished my ride. so convenient!
as cyccommute mentioned, the spring tension is tight. in fact, I thought my first unit got worse or wasn't fitting right, so I bought a 2nd & carry both. but they both work. they are tiny so I have to keep them in separate plastic zip bags, in my field repair bag, to be sure I don't lose them. 1 is by itself & 1 is w/ 2 cartridges
on epic rides I sometimes carry 4 cartridges in addition to my pump
on at least 1 occasion, I had 1 new cartridge be a dud. brand new, screwed it on, no gas. unscrewed it, no gas escape & it had a new hole from the inflator. I imagine new cartridge duds are quite rare but still, if you're gonna carry 1 you might as well carry 2
cartridges don't work when frozen so I keep them in my house during winter & carry them with me when I go out. they don't go in the winter bag they go in a coat pocket close to my body to stay at least a reasonable temperature
I also carry a small hand pump
you might want to test using it at home the next time you're swapping tires or something, so you have a feel for it. especially if you're using Presta valves, I think
Likes For rumrunn6:
#57
Quoted: 405 Post(s)
Liked 430 Times
--Shannon
#58
Liked 4,824 Times
Now I'm wondering which works better against an aggressive dog: a whack with a pump or a face full of CO2? Discuss
DD
DD
#59
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Length is close and, having run over a number of Zefal HP pumps because they popped out of the frame, the mount is far more secure. I bought my first Topeak Morph in 2000 and still have it. It still works and is going strong. I think it will last.
And it doesn’t rip valve stems out nor have to be pumped against a fence post or, worse, my knee to get to the proper pressure.
Stuart Black
Stuart Black
#60
Quoted: 1106 Post(s)
Liked 1,328 Times
As well, you can exert more force on the air column in the pump with it held between your hands than you can pushing down on the ground.
#61
Liked 4,218 Times
As to leaking hoses, hasn’t been a problem in 20 years of using one. Zefals, on the other hand, don’t work at all if you run over them…which I have done numerous times.
Stuart Black
Stuart Black
#62
Liked 1,328 Times
Um…no. Physics. When you push down into the ground, the maximum force is your body weight. When you push from one arm into the other, you can’t exert as much force. We don’t hold floor pumps between our hands and pump tires that way because we can exert as much force as our body weight.
Anyone who can do a pull-up is exerting more force than their body weight.
Squeezing a pump is, of course, not a pull-up; an exercise that is fairly similar to pumping is a chest-fly; average values for machine chest flys (flies?) quoted on the 'net show that any male more advanced than "novice" can exert more force than their body weight.
And if you did manage to exert more force on a floor pump than your body weight you'd be (briefly) doing a different kind of flying.
Of course, in a way this is all academic. All you need is a smidgen more than the pressure in the tyre - did you *really* need to get them up to 195 psi?
#63
Liked 4,218 Times
I don't think that's correct.
Intermediate: Stronger than 50% of lifters. An intermediate lifter has trained regularly in the technique for at least two years.
Stronger than 20% of lifters. A novice lifter has trained regularly in the technique for at least six months.
Stuart Black
Stuart Black
#65
Liked 4,218 Times
They say “average”. I assume that’s over all weight ranges. I also assume that everyone who uses one of these machines isn’t using the maximum weight all the time.
Stuart Black
Stuart Black
#66
as much as I feel like a Silca frame pump is the one true and pure way to put air into tires, I feel obliged to mention that racers were carrying compressed gas for inflating spare tires a long time ago.
These cylinders of compressed gas (just air, I think) were larger than modern CO2 cartridges, and the French term is "gonfleur". A search for this term pulls up various images, such as this one from Flickr..
Steve in Peoria (still a Silca Impero fan)
https://www.flickr.com/photos/414206...7719190382423/"FOR QUICK INFLATION"
This bottle filled with compressed air at 100 kilos allows you to largely inflate two tubulars to 4 kilos. Each bottle is tested at a pressure of 300 kilos before being put into service.
The right-angled connector, which does not change the rider's usual gesture, fits easily on all valves and has the advantage of not twisting the mechanism pins, provided of course that the connector is fully engaged on the valve. Simply screw the body on to open the bottle, and unscrew it to stop the compressed air outlet. The cylinder is provided with a centre point at each end for mounting on the bicycle frame itself.
#67
Quoted: 1829 Post(s)
Liked 3,376 Times
A few more detail's from Heiko's Rebour archives on Flickr
I'm trying to figure out what a "kilo" translates into. I'm inclined to think it might be a kilopascal (kpa), but 4kpa is only 27.6 psi. I'm not sure how big the tubulars were back then, but 27.6psi seems quite low.
Of course, translation is always difficult, and especially when different eras and cultures are part of the translation. I like the comment "The right-angled connector, which does not change the rider's usual gesture", which I think means that the rider uses the same position/posture to use it as the rider would use when operating a Silca Impero pump. In the current culture in the USA, "the rider's usual gesture" suggests some sort of body language that is intended to send a message... probably not a happy message either, when fixing a flat.
Steve in Peoria
#68
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
always nice to see another Daniel Rebour drawing! I'm slowly making my way through Heiko's flickr pages.
Steve in Peoria
Steve in Peoria
#69
Liked 4,218 Times
That’s 1400 psi. Not sure I’d want to carry around a bottle with that much pressure and an unregulated valve. It’s also going to take one hell of a compressor to fill them. CO2 cartridges are at about 800 psi.
Stuart Black
Stuart Black
#70
Liked 2,568 Times
It was my best guess. 4 kgf/cm^2 is still only 57 psi in those tubulars.
RUSA #7498
Originally Posted by noglider
Likes For ShannonM:
#72
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
CO2 is not vintage, so I would never use them. Plus, when I see spent cartridges litter the sides of the roads, I go postal.
I still have my Silca frame-fit pumps with Campy two-prong metal heads, although a couple of them have some rust. But I find myself more often than not just bringing along a mini pump. It's less vintage, but nobody is ever like, "hey, great vintage bike but where's your Silca pump?" Just sayin'.
#73
Liked 4,218 Times
My favorite dumb idea inflator is Genuine Innovations propane inflator. They call it “Big Air” probably because of the boost that the explosion gives you
Stuart Black
Stuart Black
#74
Quoted: 405 Post(s)
Liked 430 Times
Bike Pros might disagree. The picture is copywrited 1996 but inflators have been around for quite a while. There’s a patent from 1954 but I can’t say that’s the first one.
--Shannon
#75
"Kilo" does not fit into the unit system of pressures in this context. As in Europe we use "bar" or "Pascal", it would either mean 4 kilobar (58015 Psi) or 4 kiloPascal (0.58 Psi).
1 bar = 100 kPa = 100000 Pa
1 Pa = 1 N/m² (apx 0.0981 kgf / m²)
1 bar = 100000 N/m² = 10 N/cm² (apx 0.981 kgf / cm²)
I would assume that Rebour is thinking in a different category in this text, that of ambient atmospheric air pressure.
Atmospheric air pressure (weather) is given a number in Europe that is around 1000. In a high pressure weather situation it is usually above 1000, in a low pressure situation it is below. The correct unit for this is millibar (mbar) or hectopascal (hPa).
So the "4 kilos" written in the text are surely 4000 mbar = 4 bar = 58 Psi.
In those days (1950!) racing bicycle tubulars on French roads were around 700x28c to 700x32c.
Likes For HeikoS69:
