What tubeless presta valves for Bontrager wheels?
Quoted: 106 Post(s)
I wonder if all tubeless presta valves (eg. mucoff, stan, etc...) should work on TLR Bontrager wheels. Or I need to but specific valves.
Quoted: 20810 Post(s)
Liked 9,456 Times
I prefer the ones with cone-shaped gaskets at the bottom of the stem, which is the majority on the market. I also prefer the ones with enough internal diameter to pass a sealant syringe "needle" all the way through the stem, so that you can add "and* remove sealant without breaking the bead. I've been getting the Muc-Off aluminum stems, but others may fill the bill, too.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I’d definitely recommend Bontrager stems. I set up my wife’s Bontrager TLR rims with their stems, and it was the easiest tubeless setup I’ve done. In an HED rim I wanted to make tubeless, I first tried a WTB stem and did not get good results. Switched to Bontrager stem, and it’s great.
Pizzaiolo Americano
If you are going to stick with the Bontrager tubeless rim strips, I'd use their valves, because the shape is designed to work with the strips. If not, any cone shaped one will work. I recommend ditching the rim strips and using normal tubeless tape like DT Swiss and then using a cone shaped valve of your choosing. I like the Muc Off ones but they all work pretty well...
Likes For Pizzaiolo Americano:
Liked 9,456 Times
Likes For WhyFi:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I’ve mixed/matched stuff for tubeless setup and sometimes had good luck, but other times wasted money and effort, only to start over again
Pizzaiolo Americano
They are shaped to conform to their tubeless rim strips. Like I said though, I feel like their rim strips are way more of a hassle than they are worth. Regular tubeless rim tape is much easier to deal with in my opinion. I have probably changed 100 of tires with the Bontrager tubeless strips at this point and I still hate them...
Quoted: 767 Post(s)
Liked 1,742 Times
https://holdfastcycling.com/product/...valve-builder/
