Shimano Chain HYPERGLIDE - SIL-TEC coating is a pain in the rear
I have a Shimano chain that is pre-coated with HYPERGLIDE - SIL-TEC high tech, blah blah. I hate it! Here's why. I have started using Hardcore Labs Chain Butter which is amazing. Makes my chain just purr (with a lovely buttered popcorn aroma). However, the chain coating and the chain butter interact to create this ugly, brown, coating that looks like rust - but is not. When I clean the chain with dish soap and water the chain looks like crap. Over time the chain butter collects as a brown sludge.
I hate this chain!
Has anyone got a solution to this?
Cheers,
Doug
I hate this chain!
Cheers,
Doug
Expired Member
Quoted: 3674 Post(s)
Liked 5,435 Times
KMC, SRAM? Change your lube.....
Likes For shelbyfv:
Liked 2,974 Times
If the lube is reacting that way to that style chain, it would be a prime time to use a different kind of chain if that changing the lube is not an option.
I have not used that type of lube with that type of chain.
-Oh Hey!
-Oh Hey!
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Maybe follow their instructions/tips
That or use a different chain lube or chain. Honestly I like the lube I am currently using but any good bike specific lube will probably work just fine and I don't need it to smell like popcorn. In fact I really don't want my chain lube to smell of popcorn, it doesn't need a smell it is a lubricant not a sauce.
For Best Results- Using Hardcore Chain & Gear Cleaner, thoroughly clean your chain, cassette, crank, and anything else greasy and grimy. Use a brush, toothbrush, or that chain cleaning contraption to scrub the chain and drive train. Allow these parts to completely dry before lubing.
Liked 2,974 Times
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 6969 Post(s)
Liked 10,966 Times
I don’t think the chain is the real problem here.
Likes For Koyote:
Expired Member
Liked 5,435 Times
How would you strip the Sil-Tec, how would you know it was gone?
Quoted: 4413 Post(s)
Liked 4,865 Times
Likes For PeteHski:
Ok, the consensus is change my chain lube. Can someone suggest a lube that does not have this annoying interaction with Shimano SIL-TEC chain coating? Thanks.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
SIL-TEC is a treatment to the metal of the chain, it is not a lubricant or grease. I think you are confusing the tacky packing grease as being SIL-TEC, it is not. In fact, without degreasing the chain before first applying the lube, you're just wasting money....lube needs be between the pins and rollers, and if you haven't removed the packing grease, it will prevent your preferred lube from getting to where it needs to be, between the pins and rollers.
Likes For Badger6:
Hallelujah, the answer I've needed. I was confused about that all along. It's weird, I've been using WD-40 on the chain/chainring, letting it soak, before I do a proper bike wash and thorough chain cleaning, gut the backing grease never came off. Anyway, problem solved. Cheers.
Liked 10,966 Times
Expired Member
Liked 5,435 Times
I was hoping he'd run with it awhile longer....
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
Sheldon Brown disagrees with that statement:
https://www.sheldonbrown.com/chains.html
Factory Lube
New chains come pre-lubricated with a grease-type lubricant which has been installed at the factory. This is an excellent lubricant, and has been made to permeate all of the internal interstices in the chain. The chain and this lubricant need to be warmed during application.This factory lube is superior to any lube that you can apply after the fact -- well, unless...see below.
Some people make the bad mistake of deliberately removing this superior lubricant. Don't do this!
The factory lubricant all by itself is usually good for several hundred miles of service if the bike is not ridden in wet or dusty conditions. It is best not to apply any sort of lube to a new chain until it is clearly needed, because any wet lube you can apply will dilute the factory lube.
Likes For Bryan C.:
Quoted: 532 Post(s)
Liked 621 Times
Actually, the only point at which I disagree with Sheldon is the characterization of the grease on the chain. I call it packing grease, because that is what it is...he calls it a lubricant, because, grease is a lubricant. I think it is inferior, but he does not. Regardless, the OP's issue with his "buttery" lube is that it doesn't mix nicely with, or at all, the factory lube...which is NOT the (anodized?) SIL-TEC treatment to the metal surfaces of the chain.
BTW, I used to run new chains with the factory grease, and then spend 30 minutes or more cleaning up the mess they made when it was time. 10 years ago when I put on 3-4k kms in a year, and didn't ride in the rain, this event was often more than a month into a chain's life. These days, on track for ~20k kms this year so far, that event is at the end of the first week of a chain's life....and since I wax my chains, I have to clean the messy grease off at some point, might as well do it before it gets gunked up (and gunks up my drivetrain).
YMMV, but regardless, if the OP prefers a specific lube that does;t play nice with the packing grease, it's best to just clean the chain thoroughly, to include a good soak in a mineral spirt degreaser and start on a dry chain.
Yes, you have identified my challenge. When new, the chain - with factory applied lube - was fine will the mileage on the chain was low and while the chain was clean. My approach to chain cleaning is 1) apply WD-40 to chain/drivetrain and let sit while I prepare dish soap and hot water for the cleaning. 2) Clean thoroughly with soapy mixture. 3) now the issue is do I or do I not apply a lubricant? I previously used the GCN "5-minute bike clean" hack and sprayed with WD-40 - yes I know, crazy - but then stumbled across the Chain Butter. Thus my dilemma.
I just bought a new Shimano chain - which prompted this post. - and now still a bit confused about my next move.
Liked 10,966 Times
I think the sticky stuff that comes on new Shimano chains is some form of Cosmoline, or some similar substance. It might function as a lube of sorts, but it is sticky and hence will attract and hold on to dirt.
Likes For Koyote:
Liked 2,974 Times
That I've noticed. Would be nice to not have to deal with that slick50 mess.
-Oh Hey!
-Oh Hey!
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
- Thoroughly de-grease the old chain using a "real" de-greaser. Read or watch instructions to make sure you are getting a thorough cleaning. Do it 2x for good measure.
- Let dry.
- Apply your stinky popcorn lube.
- Return new chain and get your $$ back.
- Bike. Smile.
I like bike
Quoted: 267 Post(s)
Liked 283 Times
Ah. Delete 4., add a step 0. which is put the new chain on your bike. Do a thorough cleaning to remove the grease.
