C & V front ders for triples?
I'm having trouble with shifting to my granny gear with my old standard Suntour FD. It looks like it should work, but usually it doesn't. It looks like it might not really be long enough to clear the 28-tooth chain ring that I've got. Can you recommend some classic FDs that will work? Thanks
Likes For Ex Pres:
Quoted: 1829 Post(s)
Liked 3,380 Times
SunTour Cyclone.....
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
Bikes: Bike Friday PRP, Bike Friday NWT, Bromton M6R, 1991 Miyata 914, 1991 Miyata 1000, 1986 Raleigh Portage, many more frames
Quoted: 215 Post(s)
Liked 348 Times
I've heard good things about Suntour Mountech.
Likes For philpeugeot:
Quoted: 3241 Post(s)
Liked 2,512 Times
Suntour Cyclone, BL or Mountech.
Shimano FD-620? from the 600EX group.
Deerhead and Deore FDs.
Simplex SLJ series if the bike is French.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
EDIT:
I got interrupted while posting!!
That’s a Suntour XC Pro, a first generation Suntour Mountech, a Suntour Cyclone MII and a Shimano Z206.
Other ones I’ve liked have been the XT M735 and XTR M900.
There was also a Sachs/Huret on my Trek 620 that I never had to even think about- it just worked awesome.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Liked 2,512 Times
Liked 2,512 Times
If you're going with a Suntour, get one with a true clamp instead of the endless band. Not a fan of the endless band.
Likes For seypat:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
hmmm...i had one and liked it. it especially came in handy when i help a friend set up a mid 90's trek 520. now, i don't know about other sizes of this frame, but at least with his 23" the seat tube bottle mounts are low so that the derailleur has to mount behind the cage. nothing but that endless band would fit in there. otoh, a different bottle cage could have made the difference, but that's the cage he had
Quoted: 638 Post(s)
Liked 1,297 Times
Likes For Murray Missile:
my DA 7400 can shift to the 28. it took some tweaking, but it works
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
I've had good luck with Campagnolo Record:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,869 Times
As seen above, a lot of vintage SunTour derailleurs will work. Many of them were designed for triples.
If you've got a braze-on mount, for a cheap and easy-to-find alternative you could also consider a modern MicroShift triple. It doesn't look conspicuous with vintage parts, IMO.
My Bikes
My Bikes
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Mountech on a couple of bikes, here with a 22/34/45 triple.
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Is that a homebrew granny ring? Nice!
Likes For John E:
Liked 2,512 Times
Likes For seypat:
Liked 2,446 Times
It's a SunTour Perfect 22T splined cog, the smallest with a multiple of five holes/slots (ten on this one) to make it simpler to fit this five-arm crank. A few bolts, nuts and washers and presto! In the ancient days before megarange gearing this was quite a thing. Built in '83.
Likes For thumpism:
I will add my .02 and back up what some others are saying.
Suntour Mountech and Cyclone MKII both work. The Cyclone MKII is quickly becoming my all time favorite front derailleur, it just feels so nice to me when it shifts for some reason, I believe its fairly light, and it's very handsome.
Both derailleurs shifted the 24-39-50 triple on my Centurion ProTour very well. The Mountech has a pretty long and wide cage, which could have its benefits.
I have a Mountech with a 28.6.mm band I would sell, as well as a Cyclone MKII with the endless band, 26.8mm, that I would also sell, if you're interested
I've been using the SunTour Compe-V that came stock on my Fuji S10S - with a Sakae 48/38/28 triple crank on the original double spindle for years...
