Weird fork eyelet - Mounting a front rack
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Well, these folks have spherical washers (maybe not really ideal for the curved surface) that go down to M6.
I've worked with this company for over 30 years. They have everything metric, and they know their product.
https://belmetric.com/washers/spherical-washers/
Likes For JoeTBM:
Quoted: 576 Post(s)
Liked 1,002 Times
Boy, that bike sure isn't made for closeups.
Liked 2,971 Times
Kind of… Kind of not…
Part of the purpose of a washer is to distribute the forces of fasteners over a larger area. Because the face of the eyelet is curved, even a bevel washer would concentrate the forces over two smaller areas. It would create two hot-spots. This could be partly alleviated with a nylon washer. So maybe an option would be a nylon washer against the fork, then a bevel washer, then a spacer/standoff, then a flat washer against the rack's mounting flange.
https://www.amazon.com/AMF-AMF-188-T...ts_id=16410941
-Oh Hey!
-Oh Hey!
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
I'm not expecting it to be the world's best bike. The plan is to get 10+ years out of it as a city commuter and grocery bike.
I don't have too much invested in it, yet, so I'm open to suggestions for other aluminium frame/fork bikes that would lend themselves to being built up as a 700c, flat-bar, city commuter and grocery bike, with a 3x10 drive-train.
As of now, my only disappointment with this is the lower eyelets on the fork.
Careful us of a counterbore would create a flat surface for a washer: https://www.mcmaster.com/spot-facers/ . By the pictures, it doesn't appear it would take that much material. A hand filing wouldn't be as neat but might also work.
Likes For mitchmellow62:
Vegan on a bicycle
Without getting too much into a "steel is real" debate… Here in Wellington, seawater spray and mist is a thing. I like the idea of a bike that can gets its paint scratched, without leading to terminal failure. I like the weight of aluminium bikes. For a city commuter that's often used for short rides and often locked up for a few hours, keeping it under $1000 helps keep it mine.
Everything is compromise, and aluminium frames are part of the bicycle compromise that I'm happy with, based on my daily use. YMMV.
Vegan on a bicycle
There's a local guy who does frame-building. I might want to check with him about getting that done.
I wonder if that piece of dropout below the weld is solid. Or how solid is it?
Vegan on a bicycle
What it might help with would be allowing the use of a spacer/standoff, and allowing that to rest parallel with the bolt, and distribute forces in parallel with the bolt.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Plenty of 20 - 30 year old aluminium bikes out there running every day, not to mention cranks, wheels, etc
Likes For dedhed:
Vegan on a bicycle
Another gotcha with this fork… On the Tubus Tara, I drew a red circle around the point where this would mount. From the edge of that mounting hole to the outer edge of the flange is 5mm at the smallest point. On the fork, the space between the bolt and the QR-nut is 5mm. A different nut could easily be different, for better or worse. That mounting hole is "generously" sized for an M5 bolt, so gravity would reduce that clearance, and push the rack flange down onto the QR-nut. Similar on the opposite end of the skewer.
This is kind of stupid.
Now I'm wondering if a frame-builder can install a braze-on eyelet at the base of the weld, above the dropouts. I'm wondering it that would be a good idea, and solve all of these problems.
Liked 2,971 Times
just grind the area flat enough for the rack hardware. #sendit.
-Oh Hey!
-Oh Hey!
Quoted: 2482 Post(s)
Liked 2,955 Times
Why not email Giant's tech support and ask them how to mount the rack?
Vegan on a bicycle
Liked 2,955 Times
I haven't tried it. But I once emailed Felt for support and got a helpful response the next day. I would hope Giant would do the same.
Here's their customer support page. Live chat is offered, among other options, although chat might be merely automated responses. They also offer a contact form to fill out.
https://www.giant-bicycles.com/us/contact
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
place the metal "dome" to the inside, place the Cup outside, flat side towards the rack flange.. bolt that sucker up and quit overthinking it.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Subject to what Giant might have to say about it, I think I would use some plastic spacers/standoffs and try to "sculpt" out one end to sort of match the contour of the mounting surface of that fork end...so the through hole of the spacer is aligned and coincident with the threaded hole in the fork end. You could do this with a small rotary tool or even a grinder. Rack and fender kits sometimes have these parts, so you may indeed have some floating around already, but you can also get them in varying lengths at hardware stores, and M5 bolts to match.
No, it won't be perfect, but it would probably work.
Likes For hokiefyd:
Vegan on a bicycle
Update from Giant. It kind of leaves me SOL. Seems like the front-racks are only properly compatible with steel fork versions of this bike.
Sucks for me, because I bought this bike with the intention of turning it into a city/grocery bike, with front and rear racks. After putting some time, effort, and money into customising it, it looks like I may be back to the drawing board, either (a) starting from scratch with another bike, or (b) having braze-on eyelets installed on the fork. Either way, this is a disapointment.
Ok wait, this fork has mid-fork braze-ons for a low-rider rack but isn't supposed to use one??
Vegan on a bicycle
Still, the threaded eyelet near the dropouts seems unable to serve any useful purpose properly. It bears repeating: What where they thinking???
One of the weird things is that the mid-fork eyelets protrude from the fork just enough that the top mounting flange of the Giant branded Rack-It low-rider front-rack mates against it, leaving just enough room to slide a few sheets of paper between the fork and the top rail of the rack. It seems kind of beautiful in its design. It's almost like that was carefully considered. Then there's that bottom eyelet… Which only laughs at me and my hopes of turning this into a city/grocery bike.
And… The bike's specs state: Fork - Alloy, rack mount, disc
I certainly bought this bike with the understanding that it's properly compatible with a front rack, and I had every intention of installing one.
That bottom eyelet…
Liked 2,971 Times
could you swap out the fork with one that will allow for a rack?
-Oh Hey!
-Oh Hey!
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
I think OP should change everything on this bike but the paint job, in order to accommodate the chosen rack in the manner he sees fit.
I mean, what else can you do, since neither the rack or the bike manufacturer considered this combination and created The Part That Does.
Liked 2,955 Times
Yes, and apparently the mfgr also designed a rack specifically for this bike, but didn’t consider that the OP might choose to use a different rack, and also include specific mounting hardware for it.
Likes For Trakhak:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Guess I’ll have to give up on fitting that old Blackburn on to the front of my townie, since no one makes a hardware kit specifically for a 1976 Bridgestone.
Seriously, though, this is not a Mars lander or a Deepwater drilling rig; it’s a bicycle. This isn’t that hard.
I know we all want everything perfect, but sometimes the solution isn’t packaged, labeled and hanging on a peg behind the sales counter.
Likes For Ironfish653:
