The fixed cup of mt French threaded BB is not threading back in...
Quoted: 293 Post(s)
Liked 218 Times
I have worked on a few French bikes now and know the differences yet I have never encountered this issue prior to tonight. I am building up a UO8 as a townie and stripped it down completely. No issues. Cotters came out in a jiffy and the BB cups came out pretty easily. I used Sheldon's tool for the fixed cup and it worked as always. Cleaned out the BB and tried to thread in a new set of Action French threaded cups. The non drive cup goes in perfectly. The fixed cup not so much. I have tried every which way to thread it in but it stops about two turns in and looks as though the from part of the cup is out of the BB a tiny bit more than the rear. I tried to thread in the original fixed cup and had the same problem. What could be the problem and how can I overcome it? I have used these cups on another UO8 and they work perfectly after over 1500 miles. I can take photos also if that helps but I am stumped.
Still learning
Use the old cup with some grease to clean the threads.
Copious grease on the new cup. Fixed cup installed first obviously.
Quoted: 3822 Post(s)
Liked 3,368 Times
a) could be manufacturing tolerances.
b) could be swiss, there have been periods where some Peugeot models were swiss threaded.
c) one can use and old cup to make a thread chaser by grinding grooves in the threaded area perpendicular to the threads. sort of a poor man's bottom bracket tap.
Quoted: 293 Post(s)
Liked 218 Times
I am almost positive that it is French thread. It is about a 76 UO8. I should take a picture in the morning. The old cup went in maybe another turn more but it still didn't thread all the way. I am hesitant to apply too much force. Should I avoid forcing it?
@juvela I am a little confused about c. Do you mean I should force in the old fixed cup as a tap if nothing else works. Thanks guys I appreciate any help. I dropped the tools and walked away frustrated after an hour of trying.
Liked 3,368 Times
not suggesting force in cup. c) is instruction as to how to easily and cheaply make a thread chaser. cups turned into thread chasers are tools to be kept around.
Quoted: 293 Post(s)
Liked 218 Times
It is definitely between a 76-78 UO8. The decals are of that style. The thread of the BB look fine. I believe this was the first time evert that the fixed cup was removed from its orinal position.
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
Find the beginning of the cup's thread and mark it with a sharpie. Find the beginning of the bb thread a mark it. Clean up the beginning if needed. Hold the cup against the bb and rotate it backwards until you feel the beginnings click over each other then carefully rotate forward to pick up the first thread without cross threading.
Old fart
Quoted: 3597 Post(s)
Liked 3,421 Times
Quoted: 4522 Post(s)
Liked 6,415 Times
Take a right angle pick, 45 degree and chase the threads from the inside out with the sharp point. Use good pressure and be very careful to feel your way through it. You will probably find the cross thread and be able to correct it somewhat with the pick point. Then use anti seize reseat the cup and clean out the anti seize before final assembly.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Would a Swiss cup thread in at all? I haven't tried, but it seems to me it would never even start.
If the frame has French threads, a French adjustable cup should thread in.
www.rhmsaddles.com.
www.rhmsaddles.com.
bentrider
Bikes: Trek R200, Bike Friday NWT, Radius Hornet 2, Cruzbike Sofrider, Vision R-40 BF/ R-42, Actionbent Litespeed/ Jetstream, Bacchetta Giro (20 and 26), Tern Verge P9, Ryan Vanguard, Burley Limbo, Rans Stratus/ Wave/ V-Rex, Dahon Helios, others...
Quoted: 14 Post(s)
If it is French threads, it is counter clockwise to loosen and clockwise to tighten on both sides. The reverse of British.. on the fixed drive side.
Quoted: 556 Post(s)
Liked 132 Times
If the original fixed cup came out of there, it will go back in. I suspect you're just experiencing a bit of binding. That you didn't feel so much upon removing the cup. Shell could be ever-so-slightly out of round. Clean out the threads with a wire brush best you can, coat the threads with oil and install...in and out. It should clean up the entry and exit using oil. If it works, then use grease.
Quoted: 293 Post(s)
Liked 218 Times
@rhm, @juvela and @hatrack71 It is definitely French threaded and threads on a couple of turns but it feels like there is a block after that. It sounds like chasing the threads to clean them out might remedy the matter but I do not have a tool to grind out a groove in the old fixed cup. @merziac I may have to try your suggestion. So this may be a cross thread not just foreign particles that are blocking the threading path?
Quoted: 293 Post(s)
Liked 218 Times
@rootboy That sounds doable. I wondered about a wire brush but was reluctant because I did not know if I would damage the threads with the brush. You know better than I so I will try this first. Is WD40 or Anti-Seize appropriate to use as the oil?
bentrider
Quoted: 14 Post(s)
I somehow overlooked this. You are cross threaded. You'll need to get it started right and it can be a pain. I sometimes will turn the cup in the loosening direction and wiggle it until it comfortable finds the right seat square to the shell. Hold it as square as you can while turning it. However, since it was threaded two turns already.. even loosely.. in a cross threaded fashion.. this could be tough.
Bikes: Schwinn Paramount P15, Fisher Montare, Proteus, Rivendell Quickbeam
Quoted: 12 Post(s)
I have had that issue before with older bikes. Fixed cup threads out, but won't go back in. Chasing the threads fixed the situation.
Quoted: 556 Post(s)
Liked 132 Times
The home-made thread chaser with the notches cut into the threads is a cool one. The notches in the thread circumference act as gaps to take up the "chips", or any debris, like a tap, or chaser. Which keeps them from lodging between the cup and the BB shell threads, which may cause binding. Great idea.
Liked 3,368 Times
Threading (tapping) in always the first choice. When unfeasible chasing is the second choice. When chasing not possible a wire wheel is the next best option.
McMaster-Carr
Readily available at any hardware store.
McMaster-Carr
Have you tried threading the adjustable cup into the fixed side? If it goes in OK I would oil it up and thread it in/out a couple times but without fully removing it, then take it out and try the fixed cup.
Quoted: 140 Post(s)
Liked 13 Times
I recently worked on 2 ~1973 PX-10s that had Shimano French cups installed and both drive side cups were really hard to get out, I mean really hard.
The threads looked ok (although 1 of them was a bit buggered where the chain stay is brazed into the bottom bracket - on the PX, there are only a couple threads on that segment of the bb before jumping over the chain stay - although it may have been the brazing itself that was tapped through and has come off).
However, the non drive side floating cup threads in with a lot less effort (on the drive side) than the drive side fixed cup - I have not dug further into this matter (measurements, etc ) but seems on the Shimano cups, the drive side fixed cup may be slightly larger (tighter) than the non drive side cup.
Just a thought....
Just a thought....
Quoted: 293 Post(s)
Liked 218 Times
@due ruote No I haven't tried. I am going to have at it again after work later today and if that doesn't work try again this weekend. I hope that something works, everything was going so smoothly until this. If these threads are shot is the only option a threadless cartridge?
Bikes: 1938 Raleigh Record Ace (2), 1938 Schwinn Paramount, 1961 Torpado, 1964? Frejus, 1980 Raleigh 753 Team Pro, Moulton, other stuff...
Quoted: 26 Post(s)
Liked 11 Times
Somewhere, a long, long time ago, probably in a galaxy far, far away, I saw a bottom bracket that had been tapped straight through, one side to the other. If this one is like that, you could try running the adjustable cup all the way thru from the left side.
A 'chaser' can be easily made with an adjustable cup, using a triangular file to create notches perpendicular to the threads. Fancier, but more difficult, is to cut 'V' shaped pieces out of the cup, to create a saw-tooth profile.
Good luck!
Good luck!
Liked 3,368 Times
Just a thought....
Just a thought....
There are manufacturing tolerances/variations on these, even Campg.
Back in the mid-'70s I spoke with Don Millberger, the person behind Bicycle Research Products of Concord California. He said that at the Schwinn Paramount facility they had a bin of Campag NR BSC cups which were too large for the bb shells on the bikes, even though they were using Campag bb taps. So he intentionally made the Bicycle Research bb taps several thousandths oversize to accommodate.
Liked 6,415 Times
