Peloton seat swapping
Randomhead
Liked 3,713 Times
My brother and his wife both ride their peloton and they probably can't use the same saddle. The stock one is causing him problems. I thought there was no hope for swapping saddles, but I finally stared at some images of the seat setup and realized that the saddle is held on by a pretty standard looking clamp like the ones on any cheap bike. Since I don't have access to a Peloton, I was hoping someone could tell me what the diameter of the post is so I can get him a clamp.
Blue arrow shows the part I want to buy and the red arrow points to what looks to me like it might be a crack at the weld.
Quoted: 144 Post(s)
Liked 119 Times
Peloton recalls 2.2 million exercise bikes over seat issue
https://www.reuters.com/business/ret...sc-2023-05-11/
Quoted: 1250 Post(s)
Liked 1,334 Times
Randomhead
Liked 3,713 Times
If you could measure the diameter of the seatpost on your bike I would really appreciate it. My brother wants a better saddle, but I doubt he and his wife can share the same one. Both he and his wife use the bike, and I am in favor of that. As far as the crack goes, I thought that was interesting enough to point out. It's not a value judgement, these things happen. While I was looking for ways to help him with swapping saddles, the first good picture of the seatpost I found on the internet apparently shows a crack. This is where they would be found, I believe. All the other shiny areas in the pic are on the other side of objects.
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
The saddle sits on what I believe are standard saddle rail clamps, so you should be able to use any regular bike saddle. However, if you want to swap back and forth more easily, you can buy an extra seat slider clamp: https://www.pelotonbikeparts.com/seatslide I think you can just slide it off the back. I'd have to go check my Peloton to make sure when I get home though.
Randomhead
Liked 3,713 Times
That's the best idea. Thanks for the link.
Out of stock though.
