Downtube folding bike
#252
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times
Originally Posted by Crankypants
Yan,
IS the Sun Race cassetter compatable with Shimano? I don't think that I can find Sun RAce around here, unfortuneately.
Thanks,
Yan
#253
Hairy Member
Yan,
I mounted a SRAM 9 speed cassette and changed my shifter, chain, and derailleur to give me a better range for climbing steep hills. The lower gears and shifting work great, but the highest three gears seem to pull the chain to far to the right toward the derailleur causing friction and a rub on the nearby cogs. I thought that the 9 speed took the same amount of space as the 8, but maybe I needed to do something different. Any ideas? Thanks! Great bike! Also, I added a 130mm stem which gives me some room to stretch and feels great!
#254
Quoted: 282 Post(s)
Liked 24 Times
Yan,
Thanks,
Yan
#256
Quoted: 282 Post(s)
Liked 24 Times
No, I bought the cheapie. I'll try the SRAM, Thanks!
1. the derailleur is perpendicular to the ground
(parallel to the rim.)
2. then properly adjust the derailleur cable tension at the derailleur
in the second highest cog. After adjustment it should have
equal clearance on both sides of the cog. this may take a
little tweaking.
Additionally, it is imperative that the derailleur
cage also be aligned (in the vertical axis) with the fore and aft
line of the frame. This is often the cause of that problem.
Thanks,
Yan
#257
Yan, you mentioned earlier touring on a FS model. What are you going to do about luggage, just tow it? Have you found a reasonable (heavier) solution to putting a rack/panniers on the thing?
Also, can anyone recommend a decently-sized (and priced) trunk bag for the DT non-FS? I commute to work, and I'm hoping to find a solution that lets me carry my change of clothes, lunch and repair kit without using a backpack. I've seen some reasonably priced trunks around, but can't tell whether they would secure to the smaller rack or not. Examples:
https://www.bikesomewhere.com/bikesom.../275/1895/7388
https://www.bikesomewhere.com/bikesom.../275/1895/7389
https://www.nashbar.com/profile.cfm?c...eid=&pagename=
#258
Quoted: 282 Post(s)
Liked 24 Times
FYI I plan to leave on my Euro tour around the third week of May.
Thanks,
yan
#259
Hairy Member
Thanks for the info Yan, I'll try to work on the bike tommorrow. By the way, where are you planning on riding? I live in Southern France and must say that bicycle touring here is superb! My mother's boyfriend used the DT on a week long full self contained ride that we just finished.
@bookishboy: the rack that comes with the bike can actually carry a lot of gear. We stacked two small "gym" bags on top of each other, securing them onto the top of the rack with bungees. It helped to stabilize them by tying an additional cord to the bottom of the seat. They were completely full with clothing, sleeping bag, sleeping pad, tools, toiletries, and the evening goodies (chocolat, cheese, and wine).I like touring light, but I still need to haul all of my supplies for stealth camping!
#260
Hah, I suppose I grew up watching too many Monty Python episodes. I've never been bike touring myself, but would tend towards the camp-as-you-go approach; so I'd need tent, food, utensils, etc. I'm interested in seeing the luggage when it pops up on the website, I hadn't realized that you were expanding beyond just "fully specced bikes".
Cheers!
Cheers!
#261
Quoted: 282 Post(s)
Liked 24 Times
I have a cute rack tip for touring. Buy a cheap $10 Hibachi grill at a local store put the grill part on top of any standard rack attaching it with bungees. It turns your regular rack into a super large rack that can handle a rackpack, sleeping bag, tent, and much more.
Thanks,
Yan
#262
Hairy Member
DT Bike Tour tip of the day:
Try using two tarps instead of a tent. One for the bottom under your sleeping gear and another that can be stretched overhead with bungees to fend off crummy weather. Much lighter and easier to deal with (imo).
#264
Quoted: 282 Post(s)
Liked 24 Times
Thanks,
Yan
#265
too many bikes
Yan, I would go along the Rhine in the Alsace. There is a bike path along the river from Basel to NL, bike paths along the canals leading to the Rhine, and little traffic.
#266
Bicycling Gnome
Originally Posted by downtube
Great cheap idea, however for $120 retail you can get a Hennessy Hammock see https://www.hennessyhammock.com .....these are soooooo cool!
Thanks,
Yan
Thanks,
Yan
#267
Hairy Member
Yan,
Funny you should mention the Hennessy Hammock. Throughout the bike tour, my mom kept mentioning how practical a hammock would be to tour with. Now I really want to get one of these after checking out their web site!
#268
Bicycling Gnome
Yan,
Overall the route is about 340 miles, but there are a few bale out points where it passes through civilisation.
Pictures of a part of the Reiver's Way Cycle route:
#269
Radfahrer
Has anybody mounted drop bars on their DT? I would love to see some pics. I have a '05 that I love, but I need some more reach and drops for my extended tours.
If they don't show:
https://www.flickr.com/photos/46012176@N00/140801704/
https://www.flickr.com/photos/46012176@N00/140801705/
TH 1.81 (133kg*62)
TH 1.81 (133kg*62)
#270
Hairy Member
@Rincewind:Sweet ride! Clever mounting trick with the shifters! My camera conked out, so I'll post pics of mine later. Next week, I'll be putting on some butterfly bars, even though it is a hard choice between those and drops. The stem extension feels great, thanks for the tip everybody!
#271
too many bikes
The rear shock on the DT FS: anyone have any insight into adjustment? Very stiff from the factory, which decreases parasitic pedaling losses, but it seems so stiff side that it's really not doing much "suspending".
#272
Mine was fairly loose from the factory so I tightened it up. Works great. Just turn the big ring
and loosen it up. It all depends on your weight and terrain. I don't notice too much
absorption of my effort form the shock. It sure is comfortable when you get it right.
#273
Looks like downtube.com is implementing a site re-design! Looking much better, but I still say:
-Put in a better bulletin-boad software, and put a few volunteer moderaters in place to eliminate spam, section off the off-topic posts.
-Separate out "Downtube bikes, accessories upgrades and -compatible parts." Keep the brand identity strong. The site is already looking better, but it currently looks like it's for an online store that sells high-end roadbike components...Oh, and a few folding bikes too.
-The logo redesign is nice. The colors chosen for the website logo work well. I remember Rafael talking about working with you for this, Yan. Did he do the logo?
Out of curiosity, why the name "Downtube"? As far as I can tell, the bike doesn't even have a downtube.
Cheers!
Cheers!
#274
Hairy Member
I was reading over some of Sheldon Brown's articles, and I realize that the DT is equipped with the "boutique"quick release levers, that are apparently weaker and inferior to the original solid style. Yan, this sounds like another good thing to upgrade for the future models as well, especially since they are also used to secure the folding mechanism (imho).
Thanks!
Thanks!
#275
Radfahrer
Thanks!
Thanks!
Originally Posted by sheldonbrown.com
The result is that the exposed cam type provides very much less clamping force for a given amount of hand force on the lever.
The exposed-cam skewers are generally OK for vertical dropouts in back, and for forks with "lawyer lips", but should not be relied on with horizontal dropouts or plain forks.
TH 1.81 (133kg*62)
TH 1.81 (133kg*62)
