She's a bit rusty...
I found an ad for used bicycles being sold cheap locally, figured it would be worth a look. I planned on looking for parts and ended up buying a bike for the Misses, a Huffy Bay Pointe 3 speed (Hopefully counts as a Classic). Nothing fancy, and a bit rusty but rides like a dream. My spouse has struggled with (box store) bicycles, but doesn't ride enough to buy a "good" bike (her words, not mine).
I got it home, pumped up the tires only to 30 psi (needs tires badly), did a brake check and took it for a spin. The Shimano 3 speed works but needs adjustment, and only the front brakes work proper, but rides a hundred times better than her old mountain bike. I went inside and told her she's got something outside. She took it for a spin and was thrilled. She's not a fan of derailers, and never rode a IGH 3 speed, which she thinks is brilliant. Luckily the rims turn true, no wobble. She's looking forward to riding more often now.
Now for the bad. The bike is showing its age, the handlebars and rims are a bit rusty (everything chrome plated), and cables need replacement. The new 26 x 1 3/8 tires, tubes and rim bands cost more than the bike. After the cables are replaced and brakes are sorted I'll still be well under $100, so not expensive. I'm not familiar with this bikes bottom bracket and crank set up, but luckily everything seems fine for now. I plan on re-greasing everything in time to make sure things remain smooth. Any suggestions are welcome, as I'm not totally familiar with this bicycles maintenance.
I'm not trying to put lipstick on a pig, but would like for my wife to enjoy this bike as long as possible. Is there anyone making 26 x 1 3/8 rims new? Or should I just clean up the originals and prevent them from further rusting?(they seem solid, just surface rust) It doesn't need to be pretty, just remain functional.
Also if anyone found "rummage" bikes cheap/free please share your experience and things to look out for.
Thanks for reading, take care.
Quoted: 566 Post(s)
Liked 1,051 Times
26 x 1 3/8 rims/wheels were widely used in the 60s and 70s and new rims are available from Sun and often labeled as 650(A). (Someone may correct me so feed back is always welcome!) There are tires available and Google is your friend.
The Shimano hub, likely a 333, is okay but not stellar. I have one on a Nishiki and it is fine for leisurely rides around the neighborhood but YMMV. I am also a fan of IGHs so my opinions are biased.
As always, ride and enjoy. Things on old bikes can be persnickety but I enjoy that part of it.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
My gf road many miles on a 333 hub with no issues. I have a set of sun 650a rims that are doing real well on a triumph three speed. Not easy to find but nice rims. As for tires, modern bike has Kenda 650a or 26x1and 3/8 tires. The tubes are available at Walmart.
Excellent grocery getter with 3 speeds and sun rims.
Since your spoke count should be the usual 36, new rims if available will be possible. Supply being the key word...
This 72 ish Sears made by Murray with a Shimano 333 has served me well for many miles. Almost all original and only want a few sips of oil now and again.
Likes For 3speedslow:
Bikes: 50s, 60s, 70s Nottingham/Worksop bikes, becanes, Gitane, Bertin, Lion of Sochaux
Quoted: 145 Post(s)
Liked 120 Times
Use wd40 and a brass bristled brush to remove rust from rims. Once rust removed you can wax them to prevent from rusting again.
Thanks for all the replies.
I started cleaning up the bike yesterday, but still have the rims to do. Thanks for the tip on WD-40 and brush. I can confirm it has a Shimano 333 hub. It's a sweet bike for what it is and the Misses likes it (that's the important thing). Just waiting on the new tires, tubes and rim bands to arrive. I think the current tires are original and the bike wasn't ridden much. Just wish it was stored better.
That grocery getter and Sears are nice bikes, thanks for sharing it. I haven't seen many 3 speed bicycles around, but I haven't been looking either. After taking my wife's Huffy for a spin, I'm thinking about getting a 3 speed myself or having a wheel (with 3 speed hub) built for my single speed.
Likes For PapaEZ:
ambulatory senior
Liked 3,661 Times
Quoted: 1609 Post(s)
Liked 2,590 Times
Bikes: 1991 Centurion Oxygen, 1997 Centurion Invincible, 1995+- Fondriest Wind, 1982 Grand Master Nissan Pro 2000, 1992 Olmo Racing (The racing part of the name HAS to be a joke).
Quoted: 34 Post(s)
Liked 30 Times
Quoted: 637 Post(s)
Liked 1,285 Times
I use #0000 steel wool and WD-40 to remove surface rust, including painted surfaces.
As to the bottom bracket. I can't tell you how many I've had that felt silky smooth with the crank arms attached but when I remove the arms and turned the spindle without them..... They felt like the bearings were square and packed with gravel! Pulled them apart and the grease was the conistency of tar. Repack the bottom bracket, head set and hubs.
Wow, thanks for all the tips.
I used a mix aluminum foil/water, 0000 steel wool, chrome polish and cleaned things up with water/soap and a wool rag. I'll have to pick up some WD-40 for rims and turtle wax to finish things off. Luckily the handlebars are solid, just surface rust spotting. But I do have new handlebars I may use just in case. As for the bottom bracket, I'll check it out. I'll have to look up disassembly. I have plenty of various greases, as long as the bearings are good I should be set. If they're not, ordering some isn't an issue.
Hopefully I responded to all. I'll have to check out the link later on, but very cool stuff. Take it easy and be safe.
Likes For PapaEZ:
Quoted: 634 Post(s)
Liked 444 Times
Likes For tricky:
