FlyKly Charger 6 Pin Connector
Just wondering if anyone knows where I can get a charger with the 6 pin male connector for a FlyKly wheel? I got one from Italy and it doesn't have the proper charger to wheel 6 pin connector.
Thanks
Thanks
Searching for a Zehus charger
Quoted: 883 Post(s)
Liked 823 Times
If they're not readily available, do what I did in another instance, find the connector (ebay) and splice it to a charger. Just make sure the polarity is correct since the charger may not have "red & black" wire casing. It may even be possible to locate an electrical connector from your charger to the battery.
Also in search of the 6 pin charger
Any chance you gems or anyone else have this 6 pin charger available for a sale? I have tried to locate the connector itself but they also seem to be out of stock also at binder....
