When is it time to replace a Di2 battery?
Bikes: Gunnar Sport 105/UDi2, previous: Lambert, Giant FCR3, Cannondale Synapse Carbon 105, Specialized Roubaix SL4 Comp UDi2
Quoted: 30 Post(s)
Liked 19 Times
The internal battery on my Di2 bike is almost 5 years old. It works fine and holds a charge. But I am wondering what is its life expectancy?
I think it depends on a lot of factors such as how hot it gets (do you ride in Phoenix with 110F weather)? Is it stored in a garage with sub zero temperatures? I have first gen Ultegra Di2 on my 2012 BMC and am still using the original battery. I never ride below freezing, it's stored at room temperature and rarely ride when it's over 90F. I put about 5k miles a year on it and charge it 4-5 times annually. So it probably only has 28-35 charge cycles. If batteries last 300 charge cycles I think it still has a bit of life left.
I got the first gen di2 (7900 series) in 2010. Rode it for seven years. The junction box went out so I didn't ride it for three years, but I replaced the junction box this year. I kept the bike the whole ten years in my garage which gets very hot in the summer and fairly cold in the winter (East TN winters are usually mild, but we have single digit temps sometimes). Battery life is good and it still holds a charge.
Quoted: 303 Post(s)
Liked 137 Times
My two Di2 systems are both external batteries, one dates from 2013 and the other from 2015. Both are doing fine though I probably didn't do either
any favors by charging once/month for 2-4 yrs. Now typically every 2.5-3 months when one bike with a battery readout falls to 40% charge, both are
charged. They are stored in a garage which goes to 90-100F in summer. Li battery failure is manifest by failure to hold a charge, ie a full charge only
lasts a few weeks or few hundred miles. Considering the significant price increases in Di2 batteries and chargers I would be in no hurry,
ie ext batteries were $45 in 2016, now $80. Considering price drops in Li flashlights over the same time frame......
Di2 fanatic
Quoted: 54 Post(s)
Liked 68 Times
Shimano claim that it'll last (at least) 300 (or was it 500?) full charge cycles.
(obviously some fail before then, but that's what Shimano say)
ignominious poltroon
Quoted: 2275 Post(s)
Liked 3,499 Times
(I finally developed upgrade-itis, but hate the idea of tossing/mothballing a perfectly good battery, unless it is near EOL.)
Apologies for the necro-post.
Quoted: 3298 Post(s)
Liked 2,130 Times
I have a similar question, so found this in a search. The difference is my battery is nearly 10 years old, but it works fine and holds a charge for 4-6 months, still.
don't try this at home.
Quoted: 986 Post(s)
Liked 526 Times
After 5-6 years, my original 2014 Di2 seatpost battery was getting to blinking green after 10-15 hours (around two weeks approx). So I replaced it. The new one is a newer model number, and so far, I'm not noticing shortened hours.
I shift "all the time" on the local rolling hills and variable headwinds. I charge when I notice blinking green (under 50% charge), and check every few rides of approx 3 hours each.
Liked 3,499 Times
Clark W. Griswold
Quoted: 4437 Post(s)
Liked 4,089 Times
In the end I am sure synchro shift is probably great and I just had a bit of bad luck thanks to my generally poor shifting sometimes and having used E-tube on my phone for other bikes it is great. However I don't think in my position I was better off for them.
Likes For veganbikes:
Liked 3,499 Times
I was going to start off with a very conservative semi-syncro program, but you are making me think that if everything worked fine for 10 years, why change a winning game?
This was mostly motivated by my new AXS mountain bike that I have barely ridden. It is nice looking at the bluetooth display of gearing. But I can always look down to see what gear I am in, and I shift by feel anyway.
Thanks! You saved me $250 (or divorce court, if I swapped batteries with my wife).
Likes For Polaris OBark:
Liked 3,499 Times
I've got about 55,000 km on mine (or about 35,000 miles, i.e., about 3,500 miles per year for 10 years), shift a lot (steep hills where I live), I use it off road frequently, etc. Mine still seems to work as it did new. It is the older, 2014 non-bluetooth version.
Liked 3,499 Times
I wonder if he has gone through 3 or 4 more in the intervening 4 years since that post?
[The thread bump is my fault.]
Quoted: 30 Post(s)
Liked 19 Times
Almost 4 years after the original post, my Di2 internal battery from 2016 is still going strong. I plan to keep riding with it.
Likes For flanso:
Quoted: 303 Post(s)
Liked 137 Times
4 yr update: the 2013 battery has 20k miles on it and still holds a charge for 3 mo and ~600-800 miles of riding. I rotate
between 3 bikes and get roughly equal mileage on them annually. The 2015 battery ditto at about the same total mileage.
Miles per charge at least 800.
Likes For sch:
Liked 3,499 Times
Thanks for the update. I don't feel as guilty now for bumping this thread.
BTW flashing green means 75% to 50% charge, and then flashing red is 50% to 25% charge, and solid red is the last quarter. I charge mine only when it gets into the flashing red zone. I can't say that is why mine has lasted as long as it has, but it might be part of it. I suspect the other part is it is not got bluetooth capability, so potentially fewer demands are placed upon it.
