Front Derailleur Rubs Crank Arm
Quoted: 7 Post(s)
Liked 5 Times
When I shift from the smaller chain ring to the bigger the front deraileur rubs the crank arm. I have to stop, get off and push it in to stop the rub.
Is there an adjustment I can make so it doesn't get out of alignment when going from the smaller to bigger chain ring?
TIA
TIA
Quoted: 839 Post(s)
Liked 1,064 Times
Here you go. Sounds like just a "limit screw" and possibly a cable adjustment. Front Derailleur Adjustment | Park Tool
Quoted: 4806 Post(s)
Liked 3,932 Times
Sick joke here - the rub is only temporary. Won't tale long to wear a groove in either aluminum or carbon fiber cranks.
And seriously - you know you can adjust how far the derailleur cage moves outboard with the limit screw. There are two screws on the top or front of the FD, side by side, that limit how far the derailleur swings in and out. It isn't always obvious which screw does which. (Some derailleurs mark them with H (high) and L (low) but not all.) You can look at the derailleur from the rear and see a little arm that rocks when you move the cage in or out. The screw it hits when moved out is the one. Tighten it until the cage clears your crank.
You may now have issues getting the derailleur to shift to the big ring. If so, welcome to the world of front derailleurs! Report back here, with pictures if possible. In my bike shop days of a past millennium, we used to cal FDs bumblebees; that like bumblebees, they theoretically shouldn't work but somehow do. They are not a precise mechanism like almost everything else on the bike.
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
TIA
TIA
You can check the cable without removing it by shifting to the large chainring and then downshifting without pedaling. This releases cable tension and allows you to slip the cable out of the frame stop. Look and see if the cable is rusted or has any corrosion on it. You might run a bit of grease down the wire between your thumb and forefinger. Then slide the cable back into the stop.
Before you go grabbing that screwdriver, do another check first. Look at your derailer in the highest gear. “C” in the picture below illustrates how your front derailer should be aligned. The outer plate should be parallel to the chainwheel. If the derailer clamp is loose, it can allow the derailer to twist and cause the tail to hit the crank arm. If the arm is not aligned, loosen the clamp, and straighten it out. You only need to loosen the clamp enough to move the derailer. You don’t want it loose enough to move downward.
Stuart Black
Stuart Black
Quoted: 839 Post(s)
Liked 1,064 Times
Limit screw adjustment should be the very last thing done to solve problems…like before you throw it in the recycle bin last thing. Unless someone grabbed a screwdriver and started adjusting the limit screws as the first level of problem solving, limit screws never need adjusting.
Likes For Crankycrank:
Quoted: 2486 Post(s)
Liked 2,956 Times
Limit screws never need adjusting??? They can go out of adjustment for any number of reasons such as someone tried to do some misguided adjusting at some time. OP mentioned a problem that sounds like it could be the limit screw and he has the Park Tool tutorial to check everything else but let's not tell the OP that it will never go out of adjustment.
Yes, for a particular combination of drive train parts, correctly set limit screws never need adjusting, unless one or more of those parts are replaced or damaged.
Likes For Trakhak:
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...I find it ineffably sad, that the mechanical advice forum has degenerated to this extent. The first instinct in here now seems to be making declarative pronouncements on what should never be done, instead of asking a few simple questions to elicit more information, in order to provide a more helpful response, to someone who is a little less knowledgeable. I am reluctant to participate any more. The "my wrench is bigger than your wrench" trolls have won.
Enjoy.
Enjoy.
Likes For 3alarmer:
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
Enjoy.
Enjoy.
Likes For ridelikeaturtle:
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
Likes For 3alarmer:
Liked 3,932 Times
OP, I've had bikes where the FD cage and crank were very close. (The old cranksets had much straighter arms in the days when the outer FD cage plate was dead flat. Cages were narrower and it was expected you might have to play with FD shifter a touch to not rub the chain depending on the cog used in back. I seek out those cranksets for their very low Q-factors (the distance the pedals are apart). On some of those setups I have to live with rub as I shift on to the big ring. I then move the (downtube) shift lever forward touch to eliminate repeated rubbing. (Aluminum cranks and as I joked in my first post, the rub is lessening with usage. Yes, yes, all "wrong" but so much cheaper than replacement knees.)
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Maybe the mods could step in and remove posts that are irrelevant to this OP....
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I think it's funny when people get super upset about the way others post. It's the internet, it'll never be 100% nice. Just deal with it, it's not like there's someone actually in your face being a dick. If it bothers someone that much just put the 'bad guy' on the ole ignore list.
ETA: I agree that if not touched by someone trying to be a mechanic limit screws will NEVER go out of adjustment by themselves. I will admit that there are some things that can happen that often end up in them being adjusted for the wrong reason.
Likes For cxwrench:
Liked 4,221 Times
If the crankset has been removed and reinstalled just touch more snugly and the FD was set up properly to begin with, the OP might see a rub; a rub that is quite properly fixed with just the limiting screw. Now, needing to push the cage in suggests another issue like cable/housing/lube but that's a separate issue in this case.
I’ve removed and installed thousands of crank arms without needing to change the limit screw settings as long as the same crank is used.
Stuart Black
Stuart Black
Enjoy.
Enjoy.
For whatever it's worth, I don't think what cycocommute said was necessarily all that bad, and it did seem like a helpful response regardless of the tone, but the fact is there are at least a few people whose purpose in logging on to this forum just seems to be antagonistic. I know I've had a few respond to my questions that way.
Anyway, this guy's bike could be new to him and have come from someone who messed with the screws. Maybe while he was poking around he turned one a quarter turn not realizing what he'd done. And it doesn't seem hard to believe that if you were constantly banging on the derailleur or pushing it or trying to mess with it that you could have backed out a limit screw ever so slightly. There are plausible scenario wherein the limit screws are the first thing that need to be adjusted. Lord knows I've done it.
I'm not an experienced enough bike mechanic to be cocky or to have lost my sense of humility about the whole enterprise, but I am experienced in other things in my private life, and I find it helps to take three deep breaths and, above all, be nice.
Likes For cyrano138:
Liked 4,221 Times
Just another plus one on this post. Well said. There's no reason in the world this forum can't be a nice place -- other than that some people seem incapable of regulating their own behavior, and those are always the same people that will tell you that there's just nothing that can be done about it. Well, there is: don't be a dick.
As for starting with limit screws to solve problems, the only time that it would be the first place to start is if someone told you that they had “adjusted” them. Even then, that’s on the operator because they started there.
Stuart Black
Stuart Black
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
We have no reason to believe that the bike was properly set up in the first place. It could have come into the OP's possession with the limit screws set wrong, the outer cage plate misaligned, etc. Given the information we have, any of the previous responses could be appropriate.
Likes For JohnDThompson:
For whatever it's worth, cyco, you seem helpful enough, and you've offered some helpful responses to some of my questions in the past.
The broader point I was trying to make was about the general tenor of maybe 5% of responses on this forum (in my experience).
The specific point of my comment is that we don't know what the situation is (op didn't offer too much info), and it seems less than constructive to be so self-assured about what the solution would be. The reason I say that is because I fixed the exact same issue on my wife's Peugeot (after installing a replacement front derailleur that didn't fit well), by adjusting the limit screw to keep it from rubbing the crank.
I haven't fixed 15,000 bikes so maybe it was a stupid thing to do, but the bike works fine now and that was a solution.
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
we have no reason to believe that the bike was properly set up in the first place. It could have come into the op's possession with the limit screws set wrong, the outer cage plate misaligned, etc. Given the information we have, any of the previous responses could be appropriate.
...+1
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
Frankly, I don’t see a “tone” to what I posted. I’m really trying to save CoyDawg some hassle down the road by addressing the most likely issues before the least likely ones. In 10 years of co-op experience (and laying hands on north of 15,000 bikes), a large percentage of what I have to fix (actually refix) is due to some one thinking that those two screws on a derailer are meant to “fix” shifting problems. The vast majority of solutions to rubbing, jumping gears, bad shifting, etc. are due to cable issues. Close to zero are due to a misadjusted limit screw. And, in the instances where it was the limit screw, it was user caused.
Sorry but no amount of banging on a derailer is going to cause the limit screws to go out of adjustment. The screws in every derailer I’ve worked on have locking compound on them and/or are tight. They don’t rattle loose in thousands of miles of riding where the vibration is more likely to make them move than any amount of banging.
I can think of no situation where a crank that is undamaged would go on “more snugly” than the original installation. Even for square taper, there is a limit to how much the crank arm can slide onto the spindle. If someone over tightened (and damaged) the arm, that would change but just removing and reinstalling a crank will not change the location of the chainwheels.
If you've ever worked in a paid position in the mechanical trades, I'd like to hear about it. Otherwise, I have plenty of experience riding herd on a bunch of volunteer mechanics on Saturdays, at the bike co-op here. I know that some of them I had to watch more closely than others. And I know what it is to do mechanical repairs for money...in an environment where "bringbacks" were logged and recorded. And if you got enough of them, someone spoke to you about it.
It's not asking too much to request that you temper your sharing of wisdom here with some humility. And to approach your responses in a manner that is not an attempt to remedy your own insecurities, by choosing someone else to single out for your absolute mechanical wisdom. You'd suffer less embarrassment in the long run, and it would make it easier to address the problems that people are asking about. Try to think of it as playing for the team, instead of swinging for the fences.
Quoted: 4210 Post(s)
Liked 3,875 Times
"...oh please, Stewart" 3alarmer
Miss spelling Stuart's name on purpose? I hope it's not a reach out to me, for whatever reason). At least both of us bother to sing off with our real names.
To the OP's questions. Limit screws can become loose for a few reasons. Other then a reason that has a screw driver in their hand, the loosening will generally take some time and shoddy maintenance. Low grade hardware, poor thread cutting in the der body, missing nylok or thread locking compound all are valid happenings. I've even seen rocks and such picked up by the tire to whack the der. The other rarely mentioned reason that limit screws might need readjusting from the correct first set up is that the contact points on the der links, that the screws get pressed against, can wear and some small impression can result. But in general I agree that with a well adjusted front der any future limit screw adjustments will be very small if at all, excepting incidents.
My own experiences suggest that cage condition is a common cause of poor shifting. I've seen so many ft ders with a bent cage that checking cage realignment before further adjustments is part of my approach. The cage can be twisted/bent up in it's tail from a pant leg. The outer plate can be bent outward and up in the front from jamming an upshift and the chain acts as the pry tool. These days cages are usually well sculpted with shapes to help lift/push/clear the chain as needed. But the cheaper units and all the old examples (usually with the over used words "classic" "vintage") of my youth had cages with straight/flat plates. We often would bent in the front ends of the cage to better move the chain and then catch the chain from going too far. So checking the cage's condition is in my blood.
Besides cable friction there's also the der pivots that can bind up. Here in the rust belt we see more then a few ft ders that are frozen from corrosion, road salt and/or sweat and put away wet. I have to say that cable friction is far less an issue with bikes that don't have a section of housing curving around the BB, and acting like a catch basin for water dripping down the exposed inner cable. Bikes that get left out in the elements will sometimes even show corrosion inside the housing leading to the levers.
I also agree that we would need more info on the OP's bike to do more then talk generalities. Andy.
AndrewRStewart
AndrewRStewart
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
If you are singing your name, though, every time you post in here, I approve.
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
...we could use more singing in the mechanics forum. More singing would eventually lead to less bickering. Except for the inevitable critiques over quality and choice of material. Everyone's a critic.
Liked 4,221 Times
...none of us knows enough to help the poor OP yet, with his issue. Which was my original point.
...this is where you continue to go astray, if your real purpose is assistance.
...again, not enough information, but nonetheless doubling down on the absolute.
...oh please, Stewart. Tell me again about the thousands of crank arms you have pulled and reinstalled at your co-op.
See, the idea that you might have pulled them to install a new or different sealed unit BB, with the resulting minor differences possible in crank position, because many of the spindle lengths and tapers are not standardized...well that never occurs to you. At least, not before you've dictated another absolute.
No one has had to “speak to me” about the quality of my repairs because I’m the one who checks the other volunteers’ work. The paid mechanics at the co-op often consult with me because they are unfamiliar with a bit of old tech. I know you think I’m an incompetent boob but they trust me enough to allow me to teach wheel building and the 6 week Master Mechanic’s class about 6 times per year (do the math). Not only do they allow me to teach the class but I redesigned the curriculum and developed a very comprehensive series of handouts that the other classes also use (we have 3 classes running at the same time). These are classes that people actually pay for (about $250 a student).
Where have you posted any advice to CoyDawg on his problem? All you’ve done is to drag this thread into your own twisted vendetta against me. You’ve done far more to degenerate the mechanical advice forum than I have ever done. How about doing something productive for a change rather then just chase me around telling me (and everyone) how much of a stupid liar I am?
Stuart Black
Stuart Black
Expired Member
Liked 5,441 Times
Seems as if your post #7 was the one that derailed this thread. Not sure why you are posting in "Mechanics" anyway.
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
Glad to see your suggestion about removing stuff. Maybe someone can work on getting rid of the elephant in the room.
