How much slower 20" folder vs 700c?
Old 11-04-16, 08:13 AM
Abu Mahendra
Bikes: In service - FSIR Spin 3.0, Bannard Sunny minivelo, Dahon Dash Altena folder. Several others in construction or temporarily decommissioned.
Quoted: 897 Post(s)
Liked 17 Times in 17 Posts
hi...I am in Indonesia, not India...thanks. glad you like the bikes. there's more in the pipeline...
Originally Posted by zoom26
I've been seeing you a lot in the forums, and your bike/s are gorgeous! You're in India right? Kinda jealous of the folding bike market back in Asia since there are so much more choices including the fuller-sized/bigger mini-velos equipped with the lockjaw hinge or the "lighter" fnhons! Even the dahons have more variety in Asia.
Abu Mahendra is offline
Old 11-04-16, 09:01 AM
Rick Imby
Quoted: 239 Post(s)
Liked 3 Times in 3 Posts
Originally Posted by chaadster
I wasn't joking, rather illustrating the point that your effort is the key issue in this type of evaluation. Without monitoring your power output, I would not accept that the Xootr is any "slower" at 16mph. I'm not saying it isn't possible that it is "slower," only that you haven't controlled the relevant variables which would support that conclusion.
Multiple runs on both bikes with the same workout level will give a range as to the difference. I agree the results will not be perfect. There are too many factors to eliminate. However 5 runs on this ride on each bike will give a pretty good idea of the difference in efficiency----for me.
I will be doing the "course" in full race mode on both bikes also.
Well as to which bike is slower at 16 mph that is like the old question which weighs more a pound of feathers or a pound of lead. ---joke---
However my workouts are relatively consistent. I have a lot of rides under my belt with strava on my mountain bike.
I was wondering if there were guys on this forum that have a lot of comparative rides---For instance if someone rides to work everyday and it is not interupted by traffic and they have a lot of reps on each of a 20" wheel vs 700c.
Yes I have become a bit of a folding nut. I have a 451 bike coming also to compare.
Rick Imby is offline
Old 11-04-16, 09:08 AM
prathmann
Quoted: 659 Post(s)
Liked 7 Times in 6 Posts
It should give you a good idea of the relative efficiency of those two bikes, but not any general conclusion about 700c vs. 20" bikes overall. As I wrote previously, my 451mm wheeled bike is in between two of my 700c road bikes in speed when ridden with the same amount of effort. Wheel size is only one factor and others such as body positioning, tire choice, frame flex, etc. will also influence the overall efficiency.
prathmann is offline
Old 11-04-16, 09:31 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
+1, A 451-32 tire wont slow you down any more than a 622-32 will , you are just turning the wheel around more often
Per Mile, than the Bigger Wheel.. Higher gear to achieve the same speed proportional to the wheel size..
acceleration will feel Quicker with the Smaller wheel..
Bike Friday's Pocket Rocket is Quite like it is called..
Biggest source of drag is the rider's body air resistance, .. a constant, if the same guy is on the saddle, pedaling,
which you all should have memorized by now.. Air Resistance goes up 4X as the speed goes up 2X ..
fietsbob is offline
Old 11-04-16, 11:42 AM
mirfi
mirfi's Avatar
Bikes: Vilano Urbana, DownTube FS9, Montaque paratrooper, Nano mini-velo, Motobecane CX, Raleigh 20, MIFA folder, ROG Pony, Iverson Grand Touring folder, Exclusiv German folder
Quoted: 168 Post(s)
Liked 191 Times in 119 Posts
I'm a small wheel guy. Numerous bikes. Upgraded gear inches (Sheldon Brown) to theoretically go as fast as the 700c people. 100psi tires, etc. But always felt I was working too hard and it never felt 'right' or safe at speed, especially descending. Never could keep up with my crew. Bought a $600 700c road bike from BD. Now when riding with the crew, I just roll, it just glides better. It's like the tall wheels are long legs. Just my experience.
mirfi is offline
Old 11-04-16, 12:17 PM
danduva1
danduva1's Avatar
Bikes: Retrospec Spec SS folder, Cannondale SR 500, Lemond Tourmalet, Cannondale R900, Bianchi Sport SX, Mercier Nano Mini Velo, 1978 Univega TriStar fixie/SS
Subjective Effects?
The Tioga Powerblock tires on my 20” Mercier Nano make more noise than the Continental GrandPrix 700C on my Cannondale SR 500 and I think that this subjective effect somehow makes it mentally harder for me to work as hard. I think that since I feel like I am going faster due to the sound effect that I don't work hard enough to actually go faster. I am about 1 1/2 MPH slower on the 20” wheeled bike over similar routes (10-50 miles hilly but not mountainous) as the 700C as measured by Cyclemeter on an Iphone in my pocket. I have done the same route a few times using the same gear inches on each bike and still come up slower on the little bike. I could maybe try putting the phone where I can see it on the handlebars and see if I can maintain a faster average MPH.
The components on the Mercier Nano are cheaper and surely much less efficient than those on the Cannondale which probably contributes to some of the slowness as well. There are too many variables for me to correct for. I give up and will continue reading this thread with interest.
danduva1 is offline
Old 11-04-16, 02:21 PM
fietsbob
Bikes: 8
Have 2 R'off, 16t standard Cogs; 20" wheel- 53t chainring; 26" wheel- 38t chain ring... the gear range is similar with Both ..
Neither have a speedometer and the Owner is not in a Hurry.
Air resistance which pushes back, 4X , when speed goes up 2X is a constant issue.
now back to the parts shopping discussion..
fietsbob is offline
Old 11-04-16, 08:15 PM
Schwinnsta
Schwinnasaur
Schwinnsta's Avatar
Quoted: 459 Post(s)
Liked 184 Times in 122 Posts
I was looking at the Schwalbe Shredda. Available in 404 40 and 44. However, the pricing of the the Folding bead, Liteskin, is three times as much as the wire bead, Performance line. $67 vs $22. Is that justified in terms of performance? I would prefer the Folding, it is lighter, and can fold, but still.
Schwinnsta is offline
Old 11-04-16, 08:19 PM
Abu Mahendra
Quoted: 897 Post(s)
I think the folding Shredda is outrageously overpriced. Wire may be worth a try, though a Maxxis DTH folding is probably the same price and probably lighter.
Old 11-04-16, 08:22 PM
Abu Mahendra
Quoted: 897 Post(s)
Looking at NVO's website, i think the stem is about 300grams which, while twice as heavy as a normal stem, is not too bad for the increased functionality. I think a new Cane Creek headset is in the cards before a new stem. Cheers...
Abu,
That is a really good looking build. I don't understand using an Adjustable stem with all the extra weight. With the ability to move the stem up and down the stalk a little. I am not a complete weight nut but that adjustable stem is probably 1/2 a pound heavier.
Old 11-05-16, 06:41 AM
12boy
12boy's Avatar
Bikes: brompton sl, surly steamroller, fuji track, gary fisher bmx minivelo etc
Quoted: 156 Post(s)
Liked 16 Times in 12 Posts
Jan Heine in Bicycle Quarterly has a method that could work for you. Find a long hill and coast down it without pedaling with two bikes and time the run. I would think one steep enough to go over 20 mph would handle the air drag issue fairly well. Give each bike the same pedal stroke to get going. Mr Heine uses this more to test tires, I believe,than bikes but it should work for both. Be interesting to know if Schwalbe Marathon Pluses,for example, compare to Primo Comets or the cheap 100 lb Kenda Kwests. of course wind or the lack of thereof would be a factor. i was thinking that to be fair you would have to have similar types of tires, handlebars (for wind resistance etc ) but maybe not. At the end of the day I would want to know how the bikes as I had them set up would compare.
12boy is offline
Old 11-05-16, 12:27 PM
Rick Imby
Quoted: 239 Post(s)
Interesting, thanks
Old 11-05-16, 12:31 PM
Rick Imby
Quoted: 239 Post(s)
Originally Posted by danduva1
Subjective Effects?
Interesting comment about the perception of speed. This is really true with full suspension vs hardtails in mountain biking. Our perception of speed while mountain biking is to a large part the vibration we feel through the bike. Hence even though faster on full suspension we feel faster on a hard tail..
Old 11-05-16, 12:34 PM
Rick Imby
Quoted: 239 Post(s)
I am headed out to race my folding swift to try to beat my 700c time---recorded at workout speed. I just added bar ends to stretch me a little on the swift. Swapping my clipless pedals on also.
I love strava...
Old 11-05-16, 04:27 PM
Paul Braithwait
Paul Braithwait's Avatar
Location: Carlisle, in England's Lake District, just a few miles south of the border with Scotland.
Bikes: A Bianchi C2C road bike, a steel framed touring bike and a Xootr Swift folder which has made the rest redundant!
Quoted: 23 Post(s)
I have a Xootr Swift with 20" wheels and a Bianchi road bike with 700c wheels and I don't think there is much difference in speed between them. I use a Garmin GPS computer to log my rides and my average speed for both bikes is pretty much the same with the Bianchi being a mile or two quicker.
It may be that the Bianchi is lighter than the Swift, has more gears and encourages 'sportier' riding; as someone else has mentioned, riding position can affect speed more than the size of the wheels. The Swift is a great all round machine while the Bianchi is more sports orientated so it is, perhaps, unfair to judge speed simply on the size of a bike's wheels.
Paul Braithwait is offline
Old 11-05-16, 04:58 PM
fietsbob
Bikes: 8
Think You could Go Head to Head with all those guys in the Olympic Motos, on your 700c bike and win?
fietsbob is offline
Old 11-05-16, 07:54 PM
Rick Imby
Quoted: 239 Post(s)
So I put the max air pressure 65psi in my Swift, added a set of bar ends to give a little better position, put clipless pedals on and went on a "race" ride. I did my route at 16.9 MPH up from just over 14 mph before on the swift. In just normal workout mode on my 700 c bike I averaged 16.1 mph. Now to do a "Race" ride on my 700c bike to compare. I think I have 23mm front and 28mm rear tires on my 700c. I am going to order some lighter narrower 20 tires for my Swift to play with also. It is hard for me to take tires off a bike that have maybe 400 miles on them and are not even starting to wear. But they will end up in my exess pile and get sold on ebay probably.
Old 11-05-16, 08:06 PM
Rick Imby
Quoted: 239 Post(s)
It kinda depends on how expensive money is to you. I don't wear out a lot of tires with several bikes and about 2k miles a year in riding spread over all of them. I only buy folding bead tires and try for the lightest with the tread design I am after. Tire, tube and rim weight have the most leverage against you for accelleration. Taking 4 ounces off the tires has way more impact than 4 ounces off the frame.
Old 11-06-16, 09:40 PM
mirfi
mirfi's Avatar
Quoted: 168 Post(s)
If 406's were faster than 700's then the professionals would be using 406's.
mirfi is offline
Old 11-06-16, 10:58 PM
prathmann
Quoted: 659 Post(s)
Professionals racing under UCI rules are restricted to the range of wheel sizes given by those rules (55 - 70cm diameter).
Old 11-07-16, 12:06 AM
jur
Quoted: 321 Post(s)
When Moultons were allowed in racing in the early days, they proved almost unbeatable. The smaller wheels allowed closer draughting which conferred an advantage to those using them. They were banned as a result. If smaller wheels were slower then they would not have had much advantage.
Also, in speed record velomobiles, smaller wheels are used from build convenience point of view. If they were really significantly slower, they would not be used.
jur is offline
Old 11-07-16, 05:00 AM
mirfi
mirfi's Avatar
Quoted: 168 Post(s)
Thank you, that is something I never knew. Puts a whole new light on things from my point of view.
Now gonna read up on Moultons.
mirfi is offline
Old 11-07-16, 06:48 AM
Rick Imby
Quoted: 239 Post(s)
Great info Jur, I did not know that. It seems the 20" wheels accelerate more easily in sprints also. The combo of better drafting and better acceleration in a sprint puts them off the front in a lot of races.
I have no scientific verification on the 20" wheel accelerating better. Just my feeling and many others have stated the same.
The other advantage to smaller wheels is they are normally stronger.
Old 11-07-16, 06:57 AM
Rick Imby
Quoted: 239 Post(s)
In road racing there are many limitation put on the bike by the sanctioning body in Europe. They want the Race bike to "look" a certain way. Aero tubing is significantly limited and for many years the top tube had to be level. "They did not like the Look" of sloping top tubes. In Triathalons it is kinda like if it has two wheels (I think 3 are legal too) and it rolls under the power of the rider then it is legal. Drafting is illegal in Triathalons so the small wheel benefit there is not relevant.
Old 11-07-16, 10:02 AM
ttakata73
Bikes: *1998 GT Forte Ti 700c, Totem KDS-D 26" fatbike, BirdyGT 18", Brompton M2LX 16"
Quoted: 88 Post(s)
Liked 5 Times in 4 Posts
https://www.moultonbicycles.co.uk/heritage.html
Check out the Records and Racing section.
The UCI has held back the progress of the road bike for decades to keep competition even. Think how long MTBs have had disc brakes and they are still only testing them in UCI road races. Luckily the manufacturers sell the smarter buying public more progressive bikes with disc brakes, fatter tires, or lower weights than the UCI dictates. It's sort of ridiculous that you can buy a lighter and or safer to ride bike than what the UCI pros ride. A UCI race is becoming a competitive vintage rally.
ttakata73 is offline
