Does Head Tube Length matter if it's included in the Stack?
Quoted: 18 Post(s)
I keep reading that Stack & Reach measurements are a good barometer of how a bike will fit. I was curious about Head Tube length, it seems that this measurement is included in the Stack. So my question: are there any reasons I should pay attention to that measurement when comparing bikes?
I'm looking for the most upright position hence why I'm paying attention to the Stack.
Thanks!
Thanks!
Thanks!
Thanks!
Likes For Plainsman:
Quoted: 6199 Post(s)
Liked 4,816 Times
Stack alone isn't the only thing to look at. You have to figure out where your hands are going to be on the bars when your butt is in the saddle. Not easy to do by the geometry specs given by some.
And don't rule out low stack altogether if you are able to try them in person. Some bikes come new with a lot of spacers under the stem just for those that don't want to be as low as can be. So one might have some shorter top tube, stem length, bar reach and seat tube angle that might let you sit more comfortably than a bike with higher stack.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
More or less. If you know the stack, head tube length doesn't give you much more useful information.
Quoted: 3450 Post(s)
Liked 420 Times
Stack and Reach are standardised measurements within the cycling industry that are measured from the centre of the bottom bracket which removes a range of variables which makes a direct comparison possible.
Two bicycles could have exactly the same head tube length yet different bottom bracket heights, different head tube angles, different fork lengths and different wheels sizes that could lead to different Stack heights.
If what you want to do is compare two bikes fits to each other then this is where you do use Stack and you do also ignore head tube lengths.
Thanks!
Thanks!
Ideally you want to find a frame with enough stack so you don't have to run a bunch of spacers e.g. 30mm below the stem.
Stack and reach is the best place to start. From there you get into other things like bb drop, chainstay, trail, seat tube angle etc.
Quoted: 18 Post(s)
Thank you for all who replied, your feedback definitely cleared up a few things for me.
So just so I'm clear, I understand that I can always play with stem lengths and angles when it comes to reaching the handlebars but the only way to "artificially raise" the Stack would be to use spacers correct?
Liked 420 Times
Liked 4,816 Times
At some point in the future, when I'm certain of where I want the stem to be cut, it'll no longer be something that can be adjusted by stem height. There are adapters, I've never seen them first hand. I'd think a better way would be to buy a stem that has more rise or angle to it that will also give you higher handlebar position.
All my first post was trying to convey to you is if you can try a bike out in person, you shouldn't ignore any just based on stack. They might feel better for reasons other than stack. And because initially they have so many spacers under the stem, the factory spec for stack doesn't tell you anything for certain except how low you can go. Not how low it is.
If you do buy a new bike from a local shop, you might want to tell them to leave as much steerer tube as reasonable and safe. I don't know how standard the practice is of leaving a lot of space under the stem. Some might wack it to minimum when they build it out after it's shipped to them. I don't know though...... I just got my first new bike in 41 years a couple months ago.
how does it stack up?
Traditionally, for mechanics, the headset stack is the total height of all the headset parts,
excluding the parts of the cups that go inside the frames headtube.
Perhaps you want a new fork with an un cut steering tube?
On modern bikes that means a good sized collection of Spacers under the stem..
that can be done..
that can be done..
