How remove brake studs
I'm modifying my old 96ish Trek 830 XC into a gravel like Geezer Bike. It now has 700 wheels with a 8x cassette and drop bars. I want to remove the brake studs [posts] from the forks and seat stays, but there are no wrench flats on the posts. How do I do it? I hate to scar the posts up with Vice Grips in case I want to use them again. I hope I'm using the correct terminology here. See the attached pnoto.
I don't mind having the brazed on bases.
Quoted: 336 Post(s)
Liked 309 Times
My guess is that if there are no wrench flats, the entire post is one piece that is brazed on.
The tool to remove them is a torch, but then you need to repaint.
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
If they are threaded you can do 2 jam nuts and wrenches on the bolt.
Quoted: 321 Post(s)
Liked 263 Times
I would use an angle grinder. Cut as much off with a cutting disk as you feel safe doing without the disk touching anything you want to keep. Then switch to a flap disk and get as close as you safely can to the surface of the fork which should be almost the whole way. A little bit of 80 grit emery tape by hand at the end. Repaint and you won't know the posts were there.
Likes For guy153:
Thanks for the responses.
I'll put tubing over the shafts and not worry about them.
Thanks,
Fred
Thanks,
Fred
Likes For Blues:
Quoted: 2026 Post(s)
Liked 1,096 Times
Do you really want them gone permanently and what type of brake are you going to replace them with? Be certain The world is full of bikes that have been permanently altered and then, after it's too late, owner then decides they should have left the (fill in the blank) in place as they really want to go back to the old configuration.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Not that I'm one for Porteur racks, but the idea of having extra/redundant/unnecessary components does rub me the wrong way. Combine that with the need to always carry more water & or more food or a more complete fix-it kit for long days 30 miles from civilization or cell coverage...Leads me to this: Sunlite brake boss mounted front rack.
I have one. It's small, lightweight, & would fit a small trunk bag or a pair or water bottles secured with a bungie cord. It may not be much, but at least the studs would have a purpose.
Car dependency is a tax.
Likes For base2:
This is a great idea makes me start thinking of other uses.
Quoted: 194 Post(s)
Liked 204 Times
I too am not clear on what you want removed.
The painted parts are unlikely to come off - where else on the bike does that happen? The unpainted section simply needs removing with a hexagon/torx key and then something fitted into the threaded holes to stop them filling with dirt, like short mushroom headed bolts or plastic inserts.
Quoted: 321 Post(s)
Liked 263 Times
Quoted: 194 Post(s)
Liked 204 Times
The unpainted bits don't come off either. They're only not painted because you're supposed to put grease on them followed by a brake arm. Everything except the bolt that's already screwed in there is a single casting welded onto the fork and needs to be sawn and then sanded off.
If they cannot be removed, then maybe the answer is to make them a feature, such as by painting them a cream colour?
Quoted: 321 Post(s)
Liked 263 Times
Good idea. I was thinking mount something on them and thought of a custom rack. Apparently reading the rest of the thread these are already a thing and you can actually get them. You could also mount lights on them.
Quoted: 839 Post(s)
Liked 1,061 Times
I was just going to say that you could cut off the studs and thread the mounts to take threaded bosses later on if needed. A little work and needs to be done accurately so everything is straight but it's another option.
Likes For Crankycrank:
I now think the painted part, I'll call the stud, is one piece and is welded to the fork. The weld puddles can be seen in the attached front view. The 5mm hex head screw that holds on the brake arm is threaded into the stud. The screw was not removed in the previous photo.
If I need some extra work sometime I may cut the studs off and thread them for removable brake studs, but that's way down a list I'll probably never finish. I'm not sure it's really on the list. I do not want to destroy the mounting for the 26" wheels. I may want to go back to them some day.
I like the idea of attaching the fore mentioned rack or fastening lights or reflectors on the studs.
The studs would be a great place for a pair of front reflectors.
Thanks for all the brain storming. It always helps with new ideas.
Fred
Fred
