Types of trainers
Road Runner
Types of trainers
I've been thinking of getting a trainer for some indoor workouts this winter. I guess the two technologies are magnetic and fluid. When I visited the LBS, the kid who waited on me sort of sneered at the magnetic model and said that I "had to have" a fluid trainer. Thing is, there is about a $100 difference to go to the fluid style; I can buy a new CycleOps Magneto for about $180, with the equivalent fluid model more like $280 (and the LBS was trying to steer me to the yet more expensive Kurt Kinetic).
So I thought I'd put this before the "voice of reason" that I usually find in this forum. Are there really any major disadvantages to going with a decent-quality mag trainer for someone our age who is looking to stay in shape and get a good workout, as opposed to being on a serious training schedule? I'd probably just ride for maybe an hour at a time, and just hard enough to work up a good, but not dripping, sweat (or so I say at this time).
Bikes: confidential infromation that I don't even share with my wife
What??? Only 2 wheels?
Liked 658 Times
I assume there must be a difference between the drag vs. speed behavior of mag and fluid. what is it?
Real cyclists use toe clips.
jimmuller
jimmuller
https://www.cycleops.cz/files/trainers.pdf
Doug,
I don't have any experience with fluid trainers, but have used a magnetic one for several years. It will do what you want it to do. What you might look at is the noise factor. I used to use a wind trainer prior to the magnetic and the noise was deafening. I couldn't hear the radio or anything else for that matter. The magnetic does make some noise, but it is acceptable. I don't know if all magnetics are equal in the noise department, but it might be worth asking about.
Liked 671 Times
Fluid trainers use oil to provide resistance. It has the same speed/force curve as air, so it provides the same resistance at the same wheelspeed as you would experience on the road. But not creating gale force winds, it's as quiet as magnetic.
Liked 671 Times
Of the two mainly available fluid trainers, Cyclops and Kurt, the Kurt is quieter and smoother.
