Question on Respacing a Rear Hub, 135mm to 126mm
Hello folks, I have a rear wheel with a hub that has a 135mm over locknut distance. I'd like to use this wheel on a frame that has 126mm rear dropout spacing, and would like to do so without cold setting the frame if possible (just because I've done that before and it was kinda a lot of work to keep the frame and dropouts aligned). The axle on the wheel currently has a spacer in it, about 1cm wide, on the non-drive side. If I remove this spacer (and replace the axle with one that isn't so wide as to prevent the QR skewer ends from clamping the dropouts), can I just run the wheel as is, or would I need to redish it? I'm pretty sure the answer is that I will have to redish the wheel, but I'm asking here because although I searched here and some other places, I didn't find any similar questions, and I'd like to have someone else's opinion just to be sure. Besides needing to redish the wheel, are there any other concerns to be had about doing this?
Quoted: 6193 Post(s)
Liked 4,809 Times
I've done that with 130 OLD hubs on a 126 mm spaced drops. But might be a little much with a 135 mm OLD hub. If you have it, try it. But personally I wouldn't buy a 135 hub expecting it to happen. Even if the stays have that much spring in them, the possibility is that the cog or chain will rub the stays.
But like I said, if you have them both there with you today, give it a try. It's a plus if you can remove a small spacer from the axle. But new fangled stuff I've got now doesn't use spacers.
Quoted: 18376 Post(s)
Liked 4,511 Times
It depends on the hub. Some Shimano hubs have two 5mm spacers on the left side which can be discarded and the axle cut to length.
As far as the wheel... yes for redishing... well maybe.
Is this an 8/9/10s (or even 11s) freehub?
I would only use an 8/9/10s hub with an off-center or asymmetric rim. And even with that the spoke angle is mighty steep.
On the other hand, with 6s or 7s, you're probably OK.
You may be able to source Shimano 7s freehubs that will work on most old style 8/9/10s hubs.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
...besides the spacing itself, as already mentioned you will need to do something about the freehub, and the axle length (if you want to continue using a QR skewer. Sometimes you can respace a hub a little bit, by removing equal stuff on both sides of the cones, so you can avoid re-dishing the wheel. But it's not all that often. So it sounds like a lot of work, with no guaranteed result. Me, I'd look for a used wheel with a more appropriate hub, or build one on a 126 hub.
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
Based on measurement, I'm pretty sure it's a 7 speed freehub (32mm from the outer edge of the taller portion of the splines to the end of the freehub body, as described here). I guess maybe the best thing to do is just to take the spacer out of the axle, stick a 7 speed cassette on, and see how it goes.
Quoted: 1944 Post(s)
Liked 2,164 Times
The issue you have is the flange-to-flange spacing. 30 years ago the flange-to-flange width was different on 130mm and 135mm mtb freehubs; i.e. XT FH-m732 7 speed.
In the past year or so I’ve swapped out Shimano freehubs with non-spec’d Shimano freehubs, including fitting into 126mm dropouts.
It does not sound promising if you are already running a 7 speed freehub at 135mm. You might pick up a couple of mm’s on the DS to move the 1st position cog closer to the dropout, but the rest is a coming off the NDS. It isn’t just severe dishing, there may be spoke length issues trying to move a rim that much.
John
John
Quoted: 883 Post(s)
Liked 823 Times
I solved the issue by procuring a 1984 Schwinn Mesa Runner with 126 spacing. The wheel (Joy Tech hub and Weimann rim manufactured in Belgium) was perfect. Bonus: found two and used the parts from one and the frame from the other to construct my granddaughter's first MTB.
Likes For 2old:
Liked 2,164 Times
Good job!
John
John
Likes For 70sSanO:
Likes For davidad:
Quoted: 883 Post(s)
Liked 823 Times
For anyone with a similar challenge, I found only one used hub on ebay that was feasible price-wise ($25); still would have cost about $75 for a wheel if I built it myself. This was a much more economical solution.
