90's Specialized Crossroads-3x7 to 11 speed?
Old 03-07-24, 04:42 AM
pontius
Quoted: 12 Post(s)
Originally Posted by Duragrouch
What are the gear-inch numbers for the highest and lowest gears, for current setup, and the new 1X setup?
https://sheldonbrown.com/gear-calc.html
above numbers were ratios. Here are the gear inches.
current 99.7-25.2
1x7 83.1-25.7
pontius is offline
Old 03-07-24, 07:01 AM
Trakhak
Trakhak's Avatar
Quoted: 2485 Post(s)
Liked 2,956 Times in 1,679 Posts
current 99.7-25.2
1x7 83.1-25.7
So your current setup has a wider gear range, especially at the high end. Your proposed 1x7 gearing also likely has wider jumps between gears - i.e., you might sometimes find yourself wishing for a gear that's between your two nearest available gears. Maybe close enough will be good enough, maybe not.
Be sure to save the old parts, just in case.
Trakhak is offline
Likes For Trakhak:
Old 03-07-24, 07:14 AM
wheelreason
Quoted: 501 Post(s)
Liked 634 Times in 374 Posts
Oh boy....
wheelreason is offline
Old 03-07-24, 07:46 AM
choddo
Quoted: 682 Post(s)
Liked 453 Times in 338 Posts
If you don’t need the high end gears, and you can live with the likely clonkier changes, that seems an ok trade-off for ditching complex 3x chainrings.
choddo is offline
Likes For choddo:
Old 03-07-24, 07:56 AM
pontius
Quoted: 12 Post(s)
Originally Posted by wheelreason
Oh boy....
can you elaborate on this?
pontius is offline
Old 03-07-24, 10:03 AM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 464 Times in 365 Posts
I could see going to 10 or 11 speed, or getting a wider range, but to do this work and end up with a narrower range and lose all the in-between gears doesn't make sense just to have a 1x7 setup. Not to me anyway. Is 3x7 that complicated? My bike I upgraded above is 3x10 and it isn't difficult. The smallest ring has never been necessary for my use so it doesn't get used. Simple. The middle ring only when I'm out of shape or for a really steep hill, and there aren't any in NYC, but maybe if I do the tour I keep wanting to do. I stay in the big ring 90% of the time. I forget what my rings are, but a typical 1990s triple setup with an 11-34 rear. I've got gears galore and never wish I needed more.
zacster is offline
Likes For zacster:
Old 03-07-24, 11:31 AM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
I have a feeling the OP knows his riding and what he needs as far as top end.
if he is going to end up with 83GI that is a pretty easy 20+ mph; depending on cadence. On a hybrid that’s a good pace.
If nothing else, he’ll use that 1st position cog a lot more than most people who treat it a a downhill gear.
John
70sSanO is offline
Likes For 70sSanO:
Old 03-07-24, 01:35 PM
wheelreason
Quoted: 501 Post(s)
Sure, cyclists say and do some really funny things...
Old 03-07-24, 02:43 PM
pontius
Quoted: 12 Post(s)
Yes, you sure do!!
pontius is offline
Old 03-07-24, 02:53 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
When did a triple become "complex"? They were quite simple a few years ago.
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 03-07-24, 03:01 PM
squirtdad
squirtdad's Avatar
Quoted: 2338 Post(s)
Liked 2,827 Times in 1,543 Posts
I don't see any benefit to going 1x with the link and new cassette
1) reduced range of gearing and certainly no increase in bottom end
2) 3x works fine I don't get the "complex" argument
save the money for N+1
squirtdad is offline
Likes For squirtdad:
Old 03-07-24, 03:06 PM
choddo
Quoted: 682 Post(s)
Well maybe if you’re an expert and keep it in tiptop shifting condition but I have never been able to, always some beef with them as soon as I neglect it for a couple of weeks and no FD or cable is a lot less hassle than some.
choddo is offline
Old 03-07-24, 03:19 PM
Bill Kapaun
I'm far from an expert, but don't have trouble with triples. Once set, there shouldn't be anything to go sour unless you can't handle cables & housing either.
Duragrouch
Quoted: 747 Post(s)
Liked 417 Times in 333 Posts
current 99.7-25.2
1x7 83.1-25.7
OK, not too bad. At least you are not sacrificing any low end. My current setup, 50/34 11-30 (7-speed) on 20"/406 tires gives me 21-85 gear inches. For me, 21 is bare minimum for steep hills here (for "spinning" up and not standing, but on a rare occasion on a real steep, needing 21 AND standing, but I often walk up those), and 85 is minimum for my high, I can pedal down gentle grades, above that, I need to coast. (Note: I went FROM 1X TO 2X, because the 1X (7-speed on a folder) had a low of 32 gear inches and I desperately needed 21, and just going to a smaller chainring would not give me the high I needed.) Changing to a 1X will be close to this. I thought your current setup might have a lower-low, but not. You would definitely be sacrificing high end, but I could see you not needing more than 83. Regarding size of gear steps, perhaps not sacrificing that either; The advantage of 1X is no duplicate gears; I have 5 duplicate gears in the middle of the range with my 2X, so only 9 actual speeds out of 14 (but again, I needed those precious 2 more gears, in total range and not step size, above 7-speed). Again, gear calc allows you to easily look at the step size, either interpreting gear inches or changing to "gain ratio" which expresses steps as percentages. My guess is your current triple setup might give you a bit finer steps, especially if the "duplicate" gears don't line up exactly, this was the thinking behind an old touring setup of "half-step plus granny", the two big rings were closer than typical 52/42, to "split" into smaller steps. However, 7 steps may be fine enough for you. So here's my conclusion: If you are really pining to go 1X, don't let us stop you. A good example: When I was able to afford my first good bike, I bought a Cannondale racer, without ever riding it, from article in Bicycling magazine, I fell in love with that 2" downtube, and it was a great value on a racer, a bike which would have won the Tour de France 5 years earlier. I wanted racy. And I loved it. But over time, I became aware of the terrible ride quality, that frame was stiff. I would have been better off to try out more different bikes. And I always had the seat up high because I sized the frame in the store based purely on standover height and picked out a 54, rather than riding, where a 56 might have fit me better. So I can understand getting fixated at wanting something, especially a new trend. If you really want 1X, it's taking up a lot of your thinking, by all means do it, it's not a huge amount of money. Just be aware of what it means before going there.
One more thing: Will you be changing the crank too, or just using one position on your triple? If staying with current triple and using the middle ring, fine. But using just the inner or outer ring, your chainline (how straight the chain is going to any of the rear cogs) will be off more often, and that will wear the chain a bit more. Probably most critical if using the outer ring, because then the chainline will be off most when on the low cog, where you are pushing the hardest going up hills, higher force puts more wear on chains, especially if the chainline is off. One of the advantages of a multi-crank with duplicate gears is that you can choose the chainring for best chainline. If you are swapping out the crank for a 1X, then you should make sure you have a good chainline, aiming for the middle of the cassette (with your 7 speed, if 130mm OLD, probably 43.5mm chainline, and if 135mm OLD, might be a bit larger), but that's also an additional cost for your conversion.
I hope the above helps!
Duragrouch is offline
Likes For Duragrouch:
