Questions on Shimano 100GS
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
A couple of days ago, my wife dropped by the local transfer station (aka, county dump) and comes home with a GT Passage (21 speed hybrid/city bike) complete and seemingly in good condition despite the usual rust on the fasteners, etc. It's condition was proven to me by my promptly pumping up the tyres and taking it for a mile ride. This is the first bike that I've ever gotten from the dump in (almost) ridable condition.
It's obviously their low line (although it came from a local bike shop) model as evidenced by no quick release on the rear axle and Shimano 100GS components throughout. I've never messed with this line, and they're obviously cheap although they seem to do their jobs nicely. Now, I've yet to start tearing into the bike, and it's going to get a complete work over before it replaces my Raleigh Sports at work as the lunchtime errand runner. I've got a couple of questions in the meantime:
1. The shifters are sticky. The rear one works half the time, always works on going down the cluster, hangs up half the time when I try to get the derailleur to climb the freewheel. Obviously it needs cleaned out. Anyone have any favorite method, chemicals, etc. on doing so?
2. The front shifter climbs the freewheel perfectly. Going down, it immediately snaps from third to first on one push of the button. Am I correct in assuming we're talking cleaning, or was this a cheap and dirty deliberate design on the part of Shimano?
Otherwise, this looks like one of the easiest jobs I've had in ages. Wire brush the rust off the fasteners, disassemble, grease, polish, reassemble. I'm amazed how nice the frame paint is.
Thanks for the assistance.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Shimano 100GS group (xx-M100) was made 1991-2. I know of no on-line docs for the group.
1) Wash out/soak the shifter with something like WD-40 until it works, then spray in a light lube if you have one. Exact procedures vary.
2) It's probably a matter of adjustment of the FD, but giving the left shifter the same treatment couldn't hurt.
Also check that the cables are smooth in the housings.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Quoted: 221 Post(s)
Liked 237 Times
I also had a funny feeling that this 100GS line was not exactly one of Shimano's majors when I did a search on eBay and came up with NOTHING . By the way, thanks, you've also dated the bike for me. I was wondering what era they would have combined 100GS with BioPace chainwheels (which I thought had disappeared in the late 80's).
Syke
Syke
Elitist Troglodyte
Biopace is alive and well! Check eBay. If the rings are in good shape you might consider selling them.
Looks like 100GS was a low-end mountain group. No reason to keep it intact if something needs replacing.
Be aware that WD-40 is a lousy lubricant. It's main asset is that it drys, then mostly goes away.
- Will Rogers
- Will Rogers
Really Old Senior Member
"2. The front shifter climbs the freewheel perfectly. Going down, it immediately snaps from third to first on one push of the button."
I had an Altus front shifter that wouldn't "catch" the middle when going up or down. WD-40 did the trick!
After a couple "flush cycles", when SLOWLY easing the shifter down from BIG, I could start getting it to catch the MIDDLE. Progress was pretty quick from that point, with another flush.
Edit-
This link helps identify the era of some components.
https://www.fa-technik.adfc.de/Herste...o/Gruppen.html
Edit-
I just got a Trek 800 with Shimano 100GS shifters and the front one was doing the same thing. Yes flushing with WD40 will almsot certainly do the trick, but I prefer to take the cover off. It makes it easier to clean.
Below is the shifter with the cover removed (one phillips screw holds the cover in place)
The arrows point to the cam which is the culprit. As the factory grease thickens with age, it dampenss the cam's movement, causing it not to "catch". I find it easiest to use a solvent such as brake-kleen, and physically move the cam up and down many times to get the old grease out. Then I re-lube with WD40.
You can tell at once, with the shifter in your hand that it is working properly before re-installing. I have yet to see a shifter that has failed due to mechanical flaw or wear. They all just seem to become gummed up in the old grease.
Hope this helps!
Quoted: 1528 Post(s)
Liked 718 Times
That right there, as simple as you'll ever see it, is what goes wrong with STI most of the time.
I just stumbled into this forum today looking for help with a similar bike. My 91 era GT Passage's rear derailler fell off. I am looking for a replacement or the proper nut to re attach. Any thoughts? THX in advance
Location: England, currently dividing my time between university in Guildford and home just outside Reading
Bikes: Too many to list here!
A picture would help - there are a number of potential failure points, but it's not common for a rear derailleur to simply fall off.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
Yeah, I have never seen an entire derailleur 'fall off.' I would like to see a picture too.
