Made disc mount on frame and fork Comanche
Bikes: CUBE Acid 29er, Salsa El Mariachi SSGT Avalanche X 2009, MMVZ Minsk 1980, Trek 4300 custom, HVZ Ukraina 111-411, Cannondale Trail 5
Quoted: 22 Post(s)
Made disc brakcet on frame and fork Comanche
First i make example on PVC. Next made steel blank. After i cut bracket with help angle grinder and drill make from bracket. Next welding and painting.
Quoted: 22 Post(s)
Make mount from drill
+2 for a good fab job.
Next time you will be laser cutting your part.
-SP
-SP
Quoted: 22 Post(s)
Quoted: 22 Post(s)
Fork. Leg fork i warm on oven and slightly bent in a vise, because rotor rub on her. Next again cutting and bracket is ready
Quoted: 22 Post(s)
Quoted: 4210 Post(s)
Liked 3,875 Times
My only real concern is the chance of the fork's bending/twisting from the leverage and force that a hub brake puts into it. We hear stories about this when hub brakes are added to a fork not initially designed for them.
That color looks to be surplus army stock. Andy.
Quoted: 18378 Post(s)
Liked 4,512 Times
Perhaps that would be a reason to use a straight tube fork (which should be common in MTB sizes).
Anyway, I like the drill and grind method. Very effective.
Quoted: 22 Post(s)
Quoted: 22 Post(s)
Lots of ways to skin a cat. I don't think laser cutters that can handle that thick of stock are that common here either. Plasma is a bit more common. A vertical mill could also do the work, but I've found doing anything other than straight lines is a bit of a pain. CNC? Still expensive.
Painting acryl paint cost $ 25.
