SRAM Red Front Shifter Rebuild
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
I've recently begun having some issues w/ my SRAM Red front shifter. The shifter is approximately 2012 (maybe 2010?) vintage. Front shifter is a 2x.
Issue:
It will occasionally pop out of the inner trim position and into the small ring. Upshifts always work fine, and the outer trim position always holds just fine. I assume that the gear/teeth that hold it in the inner position have begun to wear.
So, does anyone know if rebuild parts for the shifter mechanism are available? I can find replacement levers (both shift and brake), but haven't been successful in finding actual mechanism parts.
Issue:
Bikes: CUBE Acid 29er, Salsa El Mariachi SSGT Avalanche X 2009, MMVZ Minsk 1980, Trek 4300 custom, HVZ Ukraina 111-411, Cannondale Trail 5
Quoted: 22 Post(s)
try spilling it inside a WD 40 or similar lube. such shifters are eternal. it is unlikely to be broken. most likely the grease has dried up .
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
White lithium grease spray, if needed. I usually just depend on what's in the WD-40 for my cheaper shifters. (By the way, this is the only place WD-40 ever goes near my bike.)
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Any lightweight mineral oil ought to be good enough. WD-40, Tri-Flow, sewing machine oil, etc...The shifters may need an occasional refresh.
Most greases are too heavy, hard to install where it is actually needed & can often weaken or embrittle many plastics depending on compatibility.
It should be noted that WD-40 is a good "solvent" for many other lubricants. That's why it works so good for unsticking shifters.
