wtb: 54-56cm frameset (32c clearance with short reach calipers please)
Bikes: bridgestone mb-1, rb-t, and xo-2
Quoted: 9 Post(s)
Liked 8 Times
Hi everyone, hope you've got your calipers warmed up Looking for a c&v (or neo) frameset that clears 700x32 with short reach (39-49mm) calipers. Dozens of posts on here show examples of this working out when the brake pads at the bottom of the slots. Tight spots seem to be fork crowns, brake bridges, and chainstays, so if you've got something in the 54-56cm size that you know clears 32s under those little brakes say hi! 126/130 rear spacing is fine sure
I'm tubing/brand agnostic, and understand those influence pricing in a range of zero dollars to a million bazillion, but max dimensions I can ride are 56cm top tube c-t-c and a 32.5" standover.
Currently riding a 53 RB-T on 33 somas (they run narrow though) and it feels nice minus the frame being a bit small. The build will be all superbe pro, which my short reach hidden springs clamp around a 33 jack brown on a A23 rim with good clearance in each direction (many thanks to other members on here for selling me your bits)
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I have this for sale currently. I'm happy to check if 32's will fit. It's definitely designed for short reach brakes and is a 55cm frame.
https://www.bikeforums.net/classic-v...set-300-a.html
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Quoted: 801 Post(s)
Liked 754 Times
You should think about taking into account top tube length as part of your purchasing process. Posting a budget would be good too.
I also think that holding out for a C&V frame that takes 32mm tires and short reach brakes could be a long task.
Quoted: 5888 Post(s)
Liked 3,471 Times
Is there a reason why you have to have short reach brakes? Is that because you have short reach superbe brakes that you want to use?
Short reach brakes and 32c tires will likely severely limit the the supply of frames you can use. There are lots of great frames out there that accept 32c tires if you are willing to use "long" reach brakes.
Likes For bikemig:
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times
Trek 670 from 1985
I’ve been on the fence about letting go of this, but I think my Trek 670 from 1985 can take 32mm tyres. https://vintage-trek.com/images/trek/85TrekRacing.pdf
Frame tubes are Reynolds 531cs throughout and has to be one of the nicest-riding bikes I’ve ever owned. Mine is a green 21” frame, and from my recollection: 55.5cm CTC top tube and 53.5cm CTT seat tube.
I even have a superbe brakeset I can use to test out your setup, if you’re seriously interested.
Quoted: 1873 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 429 Times
I am leaning to decommissioning a 1976 Schwinn Super LeTour 12.2 - Japanese made, lugged frame, red. Rear spacing a bit under the 126mm standard.
It will clear 700c X 32mm tires, but as mentioned before, I believe you'll need mid- / long- reach brakes. If of interest i will post photos and details. The paint is not great, but it seems that whatever they used is STILL really soft. So lots of nicks and chips.
cheers.
cheers.
Edumacator
Quoted: 2441 Post(s)
Liked 3,137 Times
The multi tracks are underrated, in my opinion, though they would be tougher to find in road frame sizing.
AD SLE? Inter 10?
bianchi Volpe?
1970s Gitanes/Bertins?
AD SLE? Inter 10?
bianchi Volpe?
Quoted: 9 Post(s)
Liked 8 Times
Wow, so many fun responses already!
Great points, edited my post. Thank you for sharing your thought about how there's not a lot of frames that fit my request. I also have had that thought!
Very helpful, thank you! Those are the brakes I'm using so that is the kind of frame I'm looking for, you're correct
Wonderful, thanks for having thoughts! Can never be too technical on a forum after all, so I've updated my post to say short reach brakes refer to 39-49mm reach as opposed to standard/mid/"normal" 47-57mm, or even long reach (57-grant-peterson-chainstay-length mm)
Much appreciated friend but yeap, woe is me, I'm lookin for a frame meant for actual short not mid just short reach brakes
Multitracks are great hybrids with very cool cantilever brakes! I've fit 700x50 on one I used as a commuter long ago. Maybe someone will be selling a road frame with short reach caliper brakes that can fit 32s and then I can buy it!
Mmmayyybeee, not thrilled about the threadless stem but the frame sure is nice lookin
Cool I'll send ya a pm
Quoted: 801 Post(s)
Liked 754 Times
I really think you ought to concern yourself with more important frame geometry attributes than short reach calipers. Trail, wheel flop, head/seat/top tube length, bottom bracket drop, chainstay length. Y'know, the usual suspects. Buying a frame specifically with 32mm tires and short reach calipers will not mean that it will ride the way you want. Good luck finding what you want!
Quoted: 502 Post(s)
Liked 466 Times
I have one of those (likely rare) frames. My ‘87 Marinoni Sports Tourer just clears true 32mm (about 3mm clearance for these Compass that measure 32.5) with short reach calipers. Pads need to be all the way down front and rear. Good luck finding something that meets those criteria. This one is NOT for sale. FWIW, l also use long-reach Tektro 556’s (559 predecessor) on this bike in it’s 650Bx38 setup (second photo; all my brakes have KS pads). I’ve been using the latter for over 1000 miles this year. Plenty of steep and long hills in Seattle for comparison, and there’s no obvious winner between them for braking.
You’ll appreciate brake levers with a second QR to clear the 32 (or 38) tires.
Likes For Dfrost:
You will need about 14.25 inches between axle and brake mounting hole on frame and fork. I may have a frame in your size that will work. I will mock it up to verify.
**edit** My frame is a no go. Front fits just fine but rear, which is 14.5" spacing, wont reach. Since the 700Cx32mm tire forces you to run the caliper at maximum reach you really dont have any range to work with. Pretty much has to be right at 14.25" both front and rear. Hope you find something!
I.C.
I.C.
if the op passes on it, i might be interested in that trek frame. looking for a frame for a set of 650b wheels i've got laying around...
Quoted: 9 Post(s)
Liked 8 Times
Your Marinoni came up more than once digging through the forums here for possible 32mm compatible bike, that it swaps to 650s made me curious if my Riv Bleriot could be a 650b-to-700c conversion. 25's will work but 32s rub under any caliper lower than the fork crown. Tinkering is almost as fun as riding!
Thanks for investigating! Where was it too tight on the rear? In this road bike thought experiment I've considered the relative ease of retorching the brake/chainstay bridges to more appropriate spots.
You have my blessing
I.C.
I.C.
Likes For dukeofearl:
