Shifter mount
Shifter mount
Anyone used one of these shifter mounts on a frame without downtube shifter brazeons?
if so, positives, negatives.
I’m wanting to put indexing shifters , that I have, on a frame without mounts.
thanks
thanks
Likes For bboy314:
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
learnt sumpn again on BF. I did not know those existed. Neat.
Likes For RB1-luvr:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 643 Times
...this. They really do not look C&V and, if I found a single-side band that I knew the shifter would fit, I'd probably abandon it.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 3811 Post(s)
Liked 6,717 Times
I have to find a pic, but at some point, I tapped a Huret or other band clamp for M5 bolts and attached modern cable stops to it for index shifting. Here's another BF-er who did something similar: https://www.bikeforums.net/22772568-post19.html
Blamester
There was a guy on Ebay selling a clamp with braze on bosses welded to it. Might look better.
PTP 28.6mm Downtube Shifters Adapter Clamp-On Index Full-Stainless USA.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,872 Times
My Bikes
My Bikes
Likes For Andy_K:
I should have been more specific with what i am trying to accomplish. I'm wanting to use the Shimano 105 index downtube shifters that I have. If could modify a vintage shifter mount , that would be preferable. But, the one that I dig up did not look like it would work.
Anyone modified a vintage mount that worked with more modern downtube index shifters?
Thanks
Thanks
Bianchi Goddess
Quoted: 2938 Post(s)
Liked 2,934 Times
Modifying an old shifter mount is hard because a lot of them didn't really have asquare base like the shipmano shifters rely on.
At one time back when Shipmano SIS was a new thing you could actually order the shifters as clamp ons and they came with nicely chaped bases/backing plates to fit over the clamp.
Sugar "Kane" Kowalczyk
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
I used a current Sunrace SLR30 28.6 mm DT mount and Shimano SL-400 index rear shifter and it works perfectly. ($13 at AMZ) The Sunrace friction FD shifting worked fine on this beater, so I didn't change it.
Likes For BTinNYC:
Quoted: 1143 Post(s)
Liked 1,757 Times
I had an old campy that had a rusted leverstop. I cut the stop off and dremeled the friction area down so the adjustable stop could be used.
Levers would work justly on this as well.
Likes For Mr. 66:
Quoted: 656 Post(s)
Liked 469 Times
I used one of these on a Raleigh Technium 420 to move the shifters from the stem to the downtube that did not have braze-ons. The one I bought was black and branded Origin8. Stripped the finish to make it polished aluminum. Some here worry about it moving on the tube and screwing up cable tension. I sold the bike before I could evaluate how well it worked long term.
Likes For plonz:
Quoted: 1952 Post(s)
Liked 2,013 Times
The problem solver or Origen 8 makes the levers sit pretty wide. I prefer the Huret and I never had to tap new threads.
Bikes: 1957 Motobecane camping bike, 1974 Manufrance Super Course STC, 1977 Peugeot camping bike, 1978 Liberia C15
Quoted: 37 Post(s)
Liked 124 Times
Sunrace shifters slr30 7s indexed
If you are looking to buy something, I support the choice for Sunrace shifters that was already mentioned. The clamp fits nicely with the C&V theme.
I have a defective Sunrace shifter and will mount my shifters to the clamp as you did here. Thank you.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 535 Post(s)
Liked 1,009 Times
Paramount Fan
Bikes: Paramounts, Raleigh Pros, Colnago, DeRosa, Gios, Masis, Pinarello, R. Sachs, Look, D. Moulton, Witcomb, Motobecane, Bianchis, Fat City, Frejus, Follis, Waterford, Litespeed, d'Autremont, others, mostly '70s-'80s
Quoted: 123 Post(s)
Liked 242 Times
I had this come up recently and searched unsuccessfully for a suitable set of Shimano 600 clamp-on indexed shifters. I finally gave up and took the clamp off a set of Suntour shifters, which worked fine, as long as you don't mind looking down at competing brand names.
