Value of a Raleigh High Sports 1968
Please no snark or negativity. Just a yes or no on the price and some advice on what it might need. To save time I will disclose that I enjoy buying and trying different bikes, I don't do it to make money , god forbid, I just like buying and selling bikes so no need for anyone to screenshot my post history.
https://www.facebook.com/marketplace/item/630205202304386/?mibextid=dXMIcH
Yes, if it is your size.
Might need new tires and tubes, though I doubt from the photos that the mounted rubber is original
to the bicycle.
to the bicycle.
I don't know.
Quoted: 331 Post(s)
Liked 883 Times
seems reasonable for my area (Connecticut).
Bikes: '72 Peugeot PX-10 '78 Motobecane Le Champion '83 Motobecane Grand Jubile '85 Trek 830 '88 Merckx Team ADR Corsa Extra
Quoted: 472 Post(s)
Liked 1,216 Times
That's a fair price if the saddle and bag are in good shape. From the single photo, bike looks to be in overall good condition.
He said they were. But who knows. This is an IGH, yes? I thought I read somewhere it's harder to change a tire on an IGH but I don't know why
If by "IGH" you mean "internal gear hub"
then yes, the readjustment of the wheel in the dropouts and the reattachment
of the internal gear cable is slightly more fiddly than a derailleur-equipped
hub.
Nothing to worry about: with practice you'll be fine.
hub.
Bikes: old ones
Quoted: 26471 Post(s)
Liked 10,425 Times
...they only made and sold these in two frame sizes that I've ever seen in the US. That's the smaller 21" frame. There's also a 23" version.
I can (and did for my college years) make the 23" frame work for me. But the smaller ones feel a little cramped.
You might have trouble finding anyone who knows how to work on them, at this point in time. If that's an issue for you.
The rear flat change is not a big deal. The pull cable to the indicator rod on the hub needs to be disconnected at the end of the pull chain.
Then with the tube fixed and the wheel in place, you reconnect it by screwing the fitting back on. There's a little serrated ring nut on the rod, that tells you where it was adjusted to before.
The front wheel bearings on most of these need to be adjusted with the wheel in place, because they lack cone lock nuts. Again, not a big deal once you know about it.
A very durable city bike, that has all the stuff you need on it for wet weather riding.
Bikes: old ones
Liked 10,425 Times
Thanks for the info. I'm guessing at 5'10 the 21 inch version is going to be too small? He wasn't very forthcoming about the size. Same goes for a "I think 1985" vintage Schwinn Super leTour. People never seem to know the size of these bikes and are too lazy to measure it, it seems. If it meant $120-140 for me, I think I'd make the effort to know the size.
The other thing on these is the gearing. Mostly you find them with AW hubs, which is about set up for what you need in cruising around the city, unless it's very hilly where you live. You can adjust the gearing up or down easily, by replacing the cog on the rear hub with either more or fewer teeth. But you're still stuck with the same range jumps between the three gears. There's probably a lot of stuff on Sturmey Archer 3 speed hubs on the internet now. I learned about them just because nobody wanted them any more when I was in college, so the Raleigh 3 speeds showed up in thrift stores a lot. Derailleurs were all the rage at that point in time.
Bikes: old ones
Liked 10,425 Times
...there's this whole long thread on these, over in the C+V. Lot's of pretty good information there, if you have the time to scan through it. For the love of English 3 speeds...
Quoted: 3824 Post(s)
Liked 6,781 Times
“High Sports”? No such thing.
In my market, that’s twice the price of what these are listed for on CL:
https://boston.craigslist.org/nos/bi...612139577.html
https://boston.craigslist.org/gbs/bi...610980425.html
Bikes: old ones
Liked 10,425 Times
...I assumed it was just the remains of a decal that originally read "Raleigh Sports", with the "Rale" missing.
It's pretty impossible to assign a value to these, just from pictures. Most of them are pretty old at this point, and mechanical condition varies.
I just gave a recently overhauled Raleigh Superbe (the deluxe Sports model, in the BRG colorway) to the bike co-op here, because I didn't want to deal with selling it via CL.
It was not nearly as pristine, cosmetically, because it actually got used. But without being in the same room with one, I couldn't set a value to save my life.
Bikes: old ones
Liked 10,425 Times
Yah. I was going by the picture. Supposedly those are the original tires...so +$60 for tires and tubes at the very least. I was reading a guys blog on these and I'm not sure it's going to work for me. I have a lot of steep hills and apparently 1) These bikes are heavy AF...40 lbs or so. Plus the brakes squeal and together with the steel rims are just too risky and if I'm going to replace all that stuff I could get a Linus or Priority for that much
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,327 Times
Expect to replace tires, tubes, cables, etc, and do a tear down of all bearings and an adjustment of the shifting.
Thanks all! I love these older bikes. I love old tech, antennae tvs, etc. But it sounds like these may be miserable to ride on hills so maybe I should pass
Likes For LifeNovice1:
