What the heck, Ernie C?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1100 Post(s)
Liked 1,865 Times
Those brakes are backwards
or, you are brilliant and how come others don’t do this?
Quoted: 4521 Post(s)
Liked 6,413 Times
Liked 6,413 Times
Quoted: 3547 Post(s)
Liked 2,962 Times
I think this was popular for about 5 minutes BITD.
Likes For smd4:
Replica of Rene Vietto's ride, 1952
Vélo René VIETTO 1952 - Le blog de velosvintage.over-blog.com
Brakes mounted on the front of the seat stays makes good sense for a bike with a rear rack because it makes it easier to do maintenance with panniers mounted and reduces potential interference.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,704 Times
"Popular" is kind of overselling it- but yeah. And it'll come around again pretty soon.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Liked 6,413 Times
Jim stripped the canti's off when he sold the frame.
Sellwood cycles said "a Merz without the racks mounted?",
Not on our watch, and they put the brake on the front side.
I'm lucky the racks stayed with the frame for years without being attached to it.
Quoted: 801 Post(s)
Liked 754 Times
I've done this before, it's obviously easier on a bike without recessed brake mounts. For a bike that does have recessed brake mounts, what I did was fit a schrader-to-presta adapter to take up the void, and using a recessed brake mount front brake on the rear. The bolt length is just right. Did that make sense?
In my use it did actually end up improving braking. I also found it helpful to get the cables out of the way of a large saddlebag. If you've got a bike you feel like tinkering on I say go for it, I found zero negatives beyond needing the parts in question.
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
Modolo Kronos brakes have to be done that way because the pads can only be put in one way. There isn't a front and rear brake caliper. They are both "front" so to speak.
Dale, NL4T
Dale, NL4T
Likes For Dylansbob:
Quoted: 3464 Post(s)
Liked 2,831 Times
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 988 Post(s)
Liked 656 Times
Hmm, does that look like an awkward cable routing?
Other than that, I see no reason why not.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Bikes: many
Quoted: 1452 Post(s)
Liked 1,402 Times
Randy Smolenski preferred that style. If the half dozen or so I've seen, all had rear brakes mounted that way.
I mounted the rear brake on my Schwinn Super Sport ahead off the brake bridge because of the placement of three rear brake cable stops. It was likely originally built for "different handed" side pulls.
Quoted: 4722 Post(s)
Liked 3,040 Times
I can think of a couple of reasons why this hasn't caught on:
1. Positioning the brake in front of the stays requires a longer reach brakeset.This means more weight. However, even if you could just adjust the pads lower in your current caliper, the longer effective reach reduces the braking efficiency.
2. It makes maintenance more difficult, as the brake is in a more confined space. This is not a big deal for maintenance conducted at home or in the shop but it's significant for race situations. You've all seen the photos of the race mechanic hanging out the car window trying to perform a rear brake adjustment, with the rider on the bicycle. Imagine doing that with the caliper mounted in front of the stay. It would be much harder.
About the only mounting position that's worse, from a maintenance perspective, are the chainstay mounted brakes. They can be a pain even in a shop environment. The crankset results in an even more confined space and they just get caked with dirt, grime and mud thrown up by the front wheel.
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 391 Post(s)
Liked 813 Times
...About the only mounting position that's worse, from a maintenance perspective, are the chainstay mounted brakes. They can be a pain even in a shop environment. The crankset results in an even more confined space and they just get caked with dirt, grime and mud thrown up by the front wheel.
Quoted: 391 Post(s)
Liked 813 Times
And if we are there, lets tick out the other side of the anomaly..... the brake caliper behind the fork on the Takhion TT bikes... where the unusual placement of the handlebars made it necessary..
Liked 3,040 Times
Aand in a good 10 years or so the "then" classic lovers might re-quote to top this this with the addition of fork and chainstay integrated..... or if we want to stick to the current group, take a minute of silence and adore Luciano Paletti well before the pro peloton of the 2010s.... obviously was not made this way for easier maintenance when using panniers..
Quoted: 391 Post(s)
Liked 813 Times
Similar was discussed recently in a thread which started based on classic cars or rather the interest towards them and in parallel the classic bike topic was on tap for sure..
I think, there will always be a group interested in C&V, and obviously the bigger part of that group will always be on the "closer to today but classic" side...
Without brands and some unique instant classic models, the newer bikes (almost) always brought in some factors which makes them usable as well, not just collectible. And yes, I don't forget, that we are more than enough people on this forum actually riding our bikes but we shouldn't forget as well the most of were born in a mostly mechanical world whereas today's kids not (I'm not talking families but the whole world around them).
Bianchi Goddess
Quoted: 2942 Post(s)
Liked 2,944 Times
The bridge on my Ugly Betty is recessed on both sides so the brake can be in or out
Sugar "Kane" Kowalczyk
blahblahblah chrome moly
Quoted: 1182 Post(s)
Liked 2,580 Times
Mark B
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Quoted: 268 Post(s)
Liked 326 Times
According to a faintly-remembered Bicycling review, Havnoonian claimed that if there was any tilt/flare to the rim walls, the brake bolt flexing would drive the pads down and lower and lose power, while his reversed orientation would have the flex drive the pads up and higher and gain power.
Of course, now that we have machined side walls for rims, I'm not sure it makes any sense any more. And even with concave sidewalls, the benefit is ... untested, shall we say.
