Schwinn Worldsport questions
I just bought a vintage 18 speed 27" Schwinn Worldsport.
I would like to know if these parts are original...
Super maxy cranks
Suntour V derailleur
Also, what is different from the Supersport vs. Worldsport, vs. a basic Schwinn.
There is a decal that says Cro Moly 4130 double butted main tubes. What does that refer to?
I attached some pics. Any idea what year this is?
Thanks.
Super maxy cranks
Thanks.
Likes For Jerry12302:
Bikes: 1981 Schwinn (Panasonic) Le Tour Tourist 10 speed, 1972? Hiawatha 10 Speed, 1981 Schwinn (Giant) World Tourist w/Shimano FF System, 1984 Miyata 710 (work in progress), 1985 Miyata 90 (mint condition but too small for me),1971 Schwinn Super Sport
Quoted: 17 Post(s)
Liked 10 Times
Jerry: If you look at the top of the headstock/steerer tube you'll see two letters followed by 5 or 6 numbers. This is the serial number of that frame. The 2 letters will tell you the month and year that frame was built
Some pics would help identifying your bike better. Because you have less than 10 posts you can't attach pics to a post or insert them directly into a post. Go to the gallery and create an album under your user name. High res pics in lieu of fuzzy phone pics are greatly appreciated. 10 megapxels or higher res is great. Then board members can help with the questions you have. BTW 4130 is a grade of steel that the frame tubing is made from. Double butted refers to the fact that the 3 main frame tubes have heavier wall thickness at each end where they are welded in to lugs and a lighter wall thickness in the middle of the tube.
OK....a little more research shows that the WorldSport was introduced in 1979 as an "Approved" model, probably made in Japan by Panasonic. So, the serial number is probably on the bottom
of the bottom bearing bracket, although it might be on one of the rear droputs, too.
Some more research shows that those mid-80s World Sports were all 12 speeds. So someone has probably changed the the front cogs up to a 3 ring to make it into an 18 speed. As well, that Sun Tour V rear der is ancient like from the early 70s so that's been changed out, too. It seems that the World Sports were all equipped with Shimano group ders.
Quoted: 604 Post(s)
Liked 1,064 Times
In the late 80s, you didn’t give us a time frame, the WorldSport was one of Schwinns middle of the road bikes, made in the Greenville plant in Mississippi, whilst the Supersport was one of Schwinns higher end model made by Panasonic in Japan. Basic Schwinns were built by Giant in Taiwan, or the China bicycle Co in China, the Chicago factory was shutdown by then.
This is what I recall from just finishing the, No Hands book, covering the history of Schwinn. Of course being old, my recall isn’t what it used to be, but I’m sure the knowledgeable collective here will corroborate, or correct me on my facts.
Tim
Tim
Bianchi Goddess
Quoted: 2937 Post(s)
Liked 2,934 Times
Super maxy cranks
Suntour V derailleur THese are probably original parts and I believe the V derailleur dates the bike to the early '80 maybe late '70s
Also, what is different from the Supersport vs. Worldsport, vs. a basic Schwinn. the simplest explination I can think of is, a 'basic' Schwinn is a bike you ride around the cul de sac for funa dn with the kids. A World sport is a bike you ride if your going for longer rides or maybe a weekend trip. The Supersport is the biek you would want if want to go on a day long ride but need to do it fast and be home by noon.
There is a decal that says Cro Moly 4130 double butted main tubes. What does that refer to? It means the seattube, downtube and the toprube are made of Chro Moly steel, a fairly common good quality material for bikes. The rest of the frame and fork are made of lesser grad Chro Moly or perhaps a Maganese steel.
I attached some pics. Any idea what year this is? I'm trying to find your pics. Can you tell us more about the bike?
Thanks.
Super maxy cranks
Thanks.
Sugar "Kane" Kowalczyk
Quoted: 792 Post(s)
Liked 1,786 Times
Based on description the OP's Worldsport is likely a early 80's model built in Asia fairly low end basic sports, about the lowest model sold in bike shops at the time. That has been upgraded changed some these would have had a fairly cheap basic 10 or 12 speed friction drive train OEM. As far as Schwinns go the Wolrdsports were a slight step above the basic 60's and 70's and well below the Supersports which were upper mid to high end models just a step or two below the Paramounts depending on year. As for narrowing down the year and quality of the bike it would help to know if the wheels are steel or allow rimmed.
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 241 Post(s)
Liked 187 Times
Hello Jerry12302,
welcome to the forum and thank-you for posting the information about your bicycle.
Your album is here: https://www.bikeforums.net/g/user/574072
Picture assist:
Your World sport appears to be a 1987 model. The frame was made by Giant of Taiwan.
From my data the World Sport model was first made in Chicago and then made by Giant starting in 1978. The World Sport model was never manufactured in Japan.
Picture assist:
Quoted: 792 Post(s)
Liked 1,786 Times
Pretty sure it's a 85 based on the fork crown pretty old school 84/85 or older and the red gold graphics started 83 ended 87. 85-86 makes sense could be a 87 as said with a year before frame or fork pretty common for a bike to be made a year or two before it was sold and have parts up to 4-5 older doesn't effect value at all still pretty much a $100-150 bike in good order.
Quoted: 241 Post(s)
Liked 187 Times
here is the 1987 catalogue:
https://bikecatalogs.org/SCHWINN/198...rt_Sprint.html
Here is the 1984 catalogue:
https://bikecatalogs.org/SCHWINN/198...rld_Sport.html
