spoke nipples not standard?
I've always interchanged spoke nipples. I just got a DT Swiss Aero spoke and it is not accepting a standard nipple. I have no idea there are other nipple threads. What kind does this lame spoke require? Ugh!
Quoted: 4206 Post(s)
Liked 3,870 Times
Currently the ISO 2mm and 1.8 mm spoke threads are pretty much all of what you'll see (excepting certain brand specific stuff like Mavic has used). But back in the 1970s and earlier there were a few differing thread specs. I doubt you spokes are of this era. I wonder if there's either thread damage of a thread lock compound involved. Andy
AndrewRStewart
AndrewRStewart
Quoted: 18377 Post(s)
Liked 4,512 Times
Everything I see indicates the Aerolite has 2mm butts on both ends, and 0.9 x 2.3mm blades.
The DT page lists:
Thread 2.0 / FG 2.3
Ok, from the Sapim Website:
Anyway, as Andrew stated, everything looks fairly standard 2.0mm.
Is it possible you got a batch of 1.8mm nipples?
There are also 2.3mm heavy duty spokes. Relatively rare, but they do exist.
As Andrew mentioned, many major manufacturers use custom nipples. Either oversized nipples on standard spokes, or in some cases oversized spokes. I think Campagnolo uses an oversized aluminum spoke.
13 Gauge = 2.3mm
14 Gauge = 2.0mm THIS IS WHAT YOU WANT
15 Gauge = 1.8mm
The DT page lists:
Thread 2.0 / FG 2.3
Spoke thread is rolled and not cut.
Rolling the thread improve the strength.
The name of the thread on a standard
2mm spoke is called FG 2,3 mm.
13 Gauge = 2.3mm
15 Gauge = 1.8mm
Quoted: 1572 Post(s)
Liked 643 Times
The DT page lists:
Thread 2.0 / FG 2.3
13 Gauge = 2.3mm
15 Gauge = 1.8mm
The DT page lists:
Thread 2.0 / FG 2.3
13 Gauge = 2.3mm
15 Gauge = 1.8mm
Likes For Retro Grouch:
Thanks everyone! I tried some more nipples and all the others worked fine! I freaked out because i thought they were all the same.
whew, at least some of the remaining spokes are corroded. it's a Rolf Vector Pro wheel with wide bladed spokes. ...not 2.3mm blades, doesn't seem like. any good way to find the right spokes? i should get a bunch... just for fun.
Liked 4,512 Times
You might look at the spoke head stamp. A closeup photo of the head stamp might help.
Rolf Prima is a local wheel company here in Eugene.
https://rolfprima.com/
Send them a note.
They may either be able to sell you the spokes, or tell you what brand.
Send them a note.
