Triple crank bolt woes
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1086 Post(s)
Liked 1,822 Times
The small ring bolts should be solid and the back should poke through to the front like this:
but I ordered a set, with the right part number according to the 1973 campy catalogue and I got these:
what is really going on?
are these meant for some sort of Willowizer triple or something?
aged to perfection
Quoted: 839 Post(s)
Liked 1,259 Times
THOSE are some seriously rare bolts. The are for the Campy triple with the smallest ring of 42T
Part #830-831-832 See first pic below.
what you want is the Campagnolo inner ring adapter and bolt part # 818 - 761 - see Pic #2
Apparently there are Avocet and possibly Spiedel parts that also fit.
Jim Merz can make you some real spiffy ones out of stainless or titanium
good luck.
/markp
good luck.
/markp
Liked 1,822 Times
I guess I've only seen 42 as the smaller chain ring.
The "RARE" set I have then is meant for a double and turn it into a triple. Can you give me an example of the three tooth count one should use?
"Leave the gun. Take the Colnagos."
Quoted: 4513 Post(s)
Liked 6,389 Times
42-48-54?
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
I geared my bikes 48-45-42 / 13-16-19-23-26, which makes a really nice 14-speed (no large-large cross-chaining) setup, with a range of 44 to 100 gear-inches. (Think of it as 1/3 step, instead of 1/2 step.) One of my Bikecology customers in 1973 converted his 54-47 double to a 54-50-47 triple, keeping the original 5-speed 14-18-22-27-34 freewheel.
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
single chain ring sandwiched with 2 chain guards for cyclocross
https://velobase.com/ViewComponent.a...29f79&Enum=115
Quoted: 4806 Post(s)
Liked 3,932 Times
good luck.
/markp
good luck.
/markp
Those cranks did a 20 year hibernation in a box. Pulled them out to get a new-to-me frame up and running. Three rides in, the crank broke through the pedal threads (with me at that same hefty weight).
Likes For 79pmooney:
Bikes: a few that I can't recall
Quoted: 347 Post(s)
Liked 302 Times
I have the answer. I will find it for you. Very tricky, but someone has come up with a McMaster Carr solution that I have tweaked. Will take about a day.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Likes For JohnDThompson:
Liked 1,822 Times
Hey John. I have the campy parts 830, 831 and 832 as shown in the catalogue pic posted by Mark P of the Pacific NW.
They turn any campy Strada double cranks into a triple as long as the smallest chainring you use is a 42 tooth (which is crazy in my book, because every stock campy crankset I've ever bought, including new in the box always came with 52t and 42t).
To me, these solve a problem that doesn't exist. I've never really wished I had a 52, 48, 42 combo since that math can be pretty much created with the rear cluster.
That said, I still need what I need; parts #818 and 761. If anybody wants to trade. Please let me know.
Likes For Robvolz:
Likes For Reynolds 531:
Liked 6,389 Times
If you have to have the real deal, buckle up buttercup.
They can easily go for $150 when you can find them, Jim may make them for less but I doubt it.
They still only get you down to 36T with out a special ring so the benefit is low IMO.
Likes For merziac:
feros ferio
Liked 1,329 Times
Back in the 1970s I kept two inner rings for my 2x5 Sugino Mighty setup, so that I could easily switch between 50-47 / 14-16-18-20-23-26 for flatlands half-step and 50-42 / 14-16-18-20-23-26 for hills.
With the long stack bolts I could have done 53-50-42, using the outer and middle chainrings for half-step, and the middle and inner for alpine (1.5-step). I tried to do 53-50-39 with Campag. Veloce, but the spider was too thick to accommodate a 3-tooth drop between the two outers, without the chain snagging between them. I settled for a 53-42-39 half-step-plus-overdrive setup, which worked OK.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Having the 144 on the outside kind of limits your options for lower gearing- after a while I found some other rings- IIRC something like 48 and 42 and a 28 granny.
1986 Trek 400 Elance by Dave The Golden Boy, on Flickr
Avocet.Stronglight_zpsxp6csyr4 by Dave The Golden Boy, on Flickr
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Liked 1,822 Times
Golden Boy….That is a very attractive set-up!!
I love the options the pre-drilled spider gives you.
My triple campy crank is pre-drilled to accept a campy 36 tooth granny chain-ring.
I'm just seeking a method to attach. I really like the McMaster-Carr answer. I owe that guy a nice bottle!!
Likes For Robvolz:
Bikes: 1946 Holdsworth Cyclone, 1969 Cinelli SC, 1972 Raleigh Pro, 1973 Merz road bike, 1974 Alex Singer Sportif, 1974 Merz track bike, 1975 Teledyne Titan, 1976 Ritchey road bike, 1977 DiNucci built Merz track bike, 1977 (?) Exxon Graftek, many more!
Quoted: 139 Post(s)
Liked 1,432 Times
I have genuine Campagnolo inner chainring stand off mounts. I'll have to dig them out to make sure. Jim
Likes For Portlandjim:
Cantilever believer
Quoted: 536 Post(s)
Liked 1,844 Times
I was in need of some 8 mm ID spacers for the inner chainring for a triple crank on one of my bikes. I have a bunch of Wheels Mfg 10 mm ID spacers in various thicknesses, but they're too big for the 8 mm triple bolts alone. I finally found something that would work at an affordable price - 5/16" ID AN960 stainless narrow flat washers. The OD is small enough to not interfere with the chain, the ID is a near-perfect fit for 8 mm, and the 1.5 mm thickness makes it easy to stack them for the desired offset. I purchased them from Copper State Bolt & Nut, as they're a great in-town source for specialty fasteners, but may be available from other vendors.
https://copperstate.com/shop/5637158...cts#15AW3-031/
Cantilever believer
Quoted: 536 Post(s)
Liked 1,844 Times
Likes For RCMoeur:
Quoted: 139 Post(s)
Liked 1,432 Times
Two genuine Campagnolo triple crank stand off boss sets. The first photo shows 5 NOS bosses, $125 per set as shown. The 2nd photo shows a set with 2 bosses that have been removed from a crank using a vise grip plier, the other 3 look to be NOS. This set is perfectly serviceable, the only issue is outer surface is marred on 2 bosses as shown. The mounting bolts are not included, you need Pista bolts. Road bolts from any Campy copy cranks will fit, but need to be shortened. This set is $85. Shipping inside the USA will be about $5. PM me.
Cantilever believer
Quoted: 536 Post(s)
Liked 1,844 Times
Oh. (smacks head)
The Campagnolo cranks use a smaller M6 thread in the crankarm, and the usual M8 for the chainring. I missed that earlier.
I'd stand corrected, but I just got comfortable...
Liked 1,703 Times
This is why I argue that although TA pioneered small-chainring triples (OK, Stronglight too), and Avocet optimized them, it was the Sugino Aero Tour and its combination of 110 mm outer BCD and 74 mm inner BCD that blew open the triple market to the masses. The Avocet was groundbreaking and prettier than the predecessors, but as you note still only allows a 42 tooth middle. The Sugino's use of the common BMX 110 BCD really opened up options.
That Avocet crank is really cool and the arms are so gracile- but as 79pmooney mentioned- it's not particularly uncommon to hear of the arms breaking by the pedal threads. I'm not a strong rider, and I've packed on some pounds since I built this- but I do keep an eye on that area for any abnormalities.
The Sugino AT is the cat's pyjamas. I think that's *THE* triple; although the Shimano FC6206 is really nice- the AT was cold forged and had those relatively gracile arms- by the time the XT cranks come, they have those wide arms that don't look as sleek.
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
Thank you!
Likes For 52telecaster:
Old fart
Liked 3,401 Times
One problem with a 41T ring on a 144mm BCD arm is that the chain can bump up against the spider. Avocet/Ofmega machined their arms to provide a little extra clearance for a 41T ring:
