Front derailleur clamp band adapter question.
Is there any reason why Shimano's SM-AD67-L (34.9mm) clamp band adapter would not be compatible with a Shimano's Ultegra FD-6700 direct mount front derailleur?
The SM-AD67 is promoted to be used with Shimano's Ultegra FD-6800 direct mount front derailleurs. From what I've read, this clamp band adapter accommodates the support bolt and plate of the newer derailleurs. Does anyone have knowledge or experience of this adapter's backward compatibility with an older direct mount derailleur - particularly an FD-6700?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
It'll work. They're not 'direct mount', they're referred to as 'braze-on'.
Likes For cxwrench:
Thank you "cxwrench".
I appears that there is such a thing as a direct mount front derailleur but as "cxwrench" correctly pointed out, what I am referring to is a 'braze-on' front derailleur.
Liked 2,972 Times
CF frames tend to use direct mount. Steel & Titanium can use braze. Aluminum would more likely use a clamp.
-Oh Hey!
-Oh Hey!
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Liked 2,972 Times
Brazing an item is joining together [fusing] metal by melting & flowing a filler metal into the joint. Direct mount using hardware to affix the part to its component.
-Oh Hey!
-Oh Hey!
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
And, if the mount is a clamp, it’s not “brazed” in place.
Frankly, “direct mount” is a better description for the mounting than “braze-on”, considering the relatively few frames that will actually use a brazing technique to attach the mount to the frame.
Stuart Black
Stuart Black
Friendship is Magic
Bikes: old ones
Quoted: 26421 Post(s)
Liked 10,380 Times
...subscribing.
...subscribing.
Bikes: lots
Liked 2,932 Times
Doesn't matter what material the frame is made with and whether the mount is actually brazed on, riveted on, or bonded. It's called a braze-on.
Since you like to get hyper-technical about this stuff, they are incorrectly referred to as “braze-on”. Whether or not the mount is “brazed on” would depend on the material. Steel could be have the mount brazed onto the frame. Aluminum and titanium and some steel frames are going to welded. Carbon is going to have the mount glued or riveted in place.
Then Google braze on front derailleur
Liked 2,972 Times
No matter what the FD requires for installing on to the seat tube, it will always require a certain mounting style for it to be held in place on the seat tube. As long as the need is known & achieved, the terminology is a YMMV.
-Oh Hey!
-Oh Hey!
Bikes: lots
Liked 2,932 Times
True, but if you go into a bike shop and ask for a front derailleur for a braze on mount they'll immediately know what you need. Same if you ask for a direct mount front derailleur, they'll know it's for a mtb. I'm not making this up, it's always been this way. The industry sets the standard for terminology in cases like this, not what some random guy thinks it should be called.
Quoted: 1109 Post(s)
Liked 1,200 Times
Yeah, as a long term amateur, I've never heard any other terms but braze on for that type of road FDs. Shops, riders, mechanics, websites, what have you use that term and no other that I've seen. It's the proper and universally accepted and understood term, period.
As a maybe interesting aside, is it becoming more uncommon to see clamp on FDs with various clamp diameter options? Seems like they're defaulting to braze on derailleurs and clamp adapters of various sizes.
Likes For Camilo:
Liked 4,218 Times
My post was more about yanking your chain about your need for hyper-accuracy about bicycle terms.
Stuart Black
Stuart Black
Liked 2,972 Times
if a random female calls it the dookickey that goes with "it" , the shop will also likely know what to do.
The sky isn't a cold color today, but it's grey.
-Oh Hey!
-Oh Hey!
Quoted: 4806 Post(s)
Liked 3,929 Times
Yup. This is the bike world. Where a thread-on steel block with a freewheel mechanism inside is a "freewheel" but that term no longer applies if you put the freewheel mechanism inside the hub. (If then becomes a "cassette" hub. If you call it a "freewheel hub" you will be corrected even if you are differentiating it from a fix gear hub.)
Good thing is that my ti bike has no FD mount so it has to run clamped and cannot be saddled with braze-ons. (Also good in that being a 31.8 OD seattube. I could use an asymmetrical shim, a 34.0 (I think that is right) clamp and bring the FD further inboard to achieve good shifting with a triple using a crankset setup to a low Q-factor.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12774 Post(s)
Liked 7,692 Times
For a second there I started wondering if they'd started making direct mount front derailleurs for road bikes.
Likes For LesterOfPuppets:
Liked 4,218 Times
Let’s not be sexist, okay? I’ve had numerous XY chromosome individuals at my local co-op who are clueless about the various doohickeys on a bicycle. I’ve also worked with numerous XX chromosome volunteers and paid mechanics who know what all the various doohickeys on a bicycle are called and can help any one find the proper part. Some even go so far as teaching other people how to fix their bikes.
Stuart Black
Stuart Black
Liked 2,972 Times
Lets not assume it was directed at a LBS business. Could be a dress shop for males. Don't read beyond the point to make yourself overly sensitive.
-Oh Hey!
-Oh Hey!
Liked 4,218 Times
Then why not say “a random person”? Don’t post in a manner that can be interpreted as being sexist. I read nothing into your post other than what you put there.
Stuart Black
Stuart Black
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
...so are "whatsit", "thingamabob", and "thingy" also to be considered unacceptable ? This is where I come to learn this stuff.
Bikes: lots
Liked 2,932 Times
Not absolutely sure but I think 'dimdogger' might be ok.
Likes For cxwrench:
Liked 2,972 Times
Simply not reading my post, not responding to my post is just as effective as not assuming. Do not direct my way of language because you are not willing to accept a different culture.
-Oh Hey!
-Oh Hey!
Liked 4,218 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 2,972 Times
you're choosing to interpret my words with how they align to your feelings. I have no problem in you doing so as long as you do not infringe to my harmless intent. Do take me the wrong way, I'll still waive at ya when out riding.
-Oh Hey!
-Oh Hey!
Liked 4,218 Times
Here’s a test: read your exact words to any given female in your life and see how they feel about your “harmless intent”.
Stuart Black
Stuart Black
