Di2 E-Tube issues
Di2 E-Tube issues
Old 06-12-21, 09:07 AM
ZHVelo
Quoted: 528 Post(s)
Liked 230 Times in 161 Posts
Di2 E-Tube issues
Hi all,
I have two issues with e-tube
1. For synchro shift for the coming down selection I can only select 2nd to 4th cogs to perform the shift to the small ring up front. I would like to try the 5th cog to do so but it will not allow that. Coming up one can select also just three, the 4th to 6th smallest and here I have the 5th smallest selected. Is this normal?
2. Under Maintenance, I cannot select the derailleur adjustment tabs, it is as if they are greyed out, they are not selectable. What can I do?
Thanks.
ZHVelo is offline
Old 06-13-21, 07:55 PM
Barry2
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times in 694 Posts
My old Win 7 Pro pc won’t allow me to adjust the Derailleurs with the USB connection.
I can see all the components, and do updates.
I use my iPad over Bluetooth for derailleur adjustments.
Barry
Barry2 is offline
Old 06-13-21, 11:57 PM
Kimmo
Kimmo's Avatar
Quoted: 1529 Post(s)
Liked 718 Times in 510 Posts
You could try the older version of e-tube.
And the restrictions on syncro depend on what chainrings and cogs it thinks you're running; you could try lying to it.
Kimmo is offline
Likes For Kimmo:
Old 06-14-21, 01:04 AM
TerryDi2C
Di2 fanatic
TerryDi2C's Avatar
Quoted: 53 Post(s)
Liked 65 Times in 42 Posts
Regarding (1): if you're using FD-6870 or FD-9070, this could be correct. For some reason these front derailleurs limit the freedom you have setting up synchronized shift:
There are also some 'rules' on setting it up and the limits for shifting up change depending on how the shifting down limits are set (same the other way around) and also the chain rings / cassette.
Like Kimmo said, the older version of E-Tube (3.4.5 vs 4.0.4) is always a good idea if you're using the charger to connect to the bike. Version 4 isn't all that great when used with the charger.
(the white boxes on the right of each window below show where you can put the top=>low shift point. Yes, the chain rings are different, but in this case that made absolutely no difference)
TerryDi2C is offline
Likes For TerryDi2C:
Old 06-14-21, 04:51 AM
ZHVelo
Quoted: 528 Post(s)
Thank you for the replies!
ZHVelo is offline
Likes For ZHVelo:
