Marathon 420 tire width
Old 06-14-21, 02:42 PM
Freerojo
Bikes: 1997 Specialized Hardrock GX, 2008 Specialized Roubaix Triple 105, 1996 Cannondale RT2000 tandem
Quoted: 48 Post(s)
Liked 19 Times in 14 Posts
Due to a broken spoke and crack in rim I needed to replace the OE wheel with a Velocity Dyda. I use Schwalbe Marathon 420 700c x 35mm. My frame clearance with that tire and rim is now minimal. I can see daylight between tire and frame but that feels too close for comfort if the rim should warp due to pot hole, broken spoke etc. I measure the inflated tire and it’s 35mm wide. Are the 32mm version of same tire just as accurate in size width wise. Does anyone know? I don’t have many options.
The tandem is a 1996 Cannondale RT2000.
Freerojo is offline
Old 06-14-21, 04:40 PM
Rick
Quoted: 624 Post(s)
Liked 396 Times in 274 Posts
Schwalbe tires are accurate.
Rick is offline
Old 06-17-21, 10:08 AM
diabloridr
diabloridr's Avatar
Bikes: Co-Motion Macchiato, Calfee Dragonfly, Ancient Sun Fixie, Trek 5900
Quoted: 49 Post(s)
Liked 13 Times in 11 Posts
Accurate on what width rim?
diabloridr is offline
Old 06-17-21, 01:31 PM
Freerojo
Quoted: 48 Post(s)
The Dyad under discussion has internal rim width of 19.
Freerojo is offline
Old 06-18-21, 11:37 AM
Freerojo
Quoted: 48 Post(s)
And the answer is: At its 95lb limit on the Dyad 700c 19 interior rim ( I actually measured 18.46) the Schwalbe 420 Marathon 700c x 32mm is 32.5mm wide. This will give my tandem much needed breathing room between the chain stays. I have mounted but not yet ridden. I will check in when I do.
Freerojo is offline
