problems with new old 1993 Alan CX
Quoted: 8 Post(s)
Hi there,
I've been looking for a classic CX Aluminium Alan bike in my size (60) and at last found one. the bike is ok, it's been used but the frame and lugs are fine.
I started taking it apart, and encountered 3 issues:
the stem is blocked in the fork
the seat post is blocked in the frame
the Cranck axle is blocked. this must come out to fit a new one. one side is already damaged (prior to me). the tool doesn't fit very well.
My obvious question is how to get everything our and not damage the fragile construction.
what thread is the Cranck Axle? Left or Right?
I am ready to put quite some work and some budget in, because I did not pay a lot for the bike and I've already fallen in love with it.
any other suggestion is welcome. (except "throw it away and buy a new one")
Greets and thanks
Lars
Greets and thanks
Lars
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
1) Flip the frame over and spray penetrating fluid down into the opening of the steerer in the fork crown. Let it soak overnight or however much longer it takes to loosen the stem. Be careful trying to wrench the stem loose so as not to strip the head of the bolt, assuming it's a quill stem
2)What kind of bottom bracket do you have? A cup and cone style or cartridge? Getting the bottom bracket out will be necessary to start soaking the seat post to get it loose. Were the bottom bracket out, you can spray penetrating fluid down into the seat tube....or some freeze off (google that one) that works sometimes as well
Quoted: 8 Post(s)
Hi Thook,
thanks for the reply.
I've done the penetrating oil thing for the stem yesterday. I'll put some more today and see what happens. I've also heard about doing it with ammonia, which would dissolve the oxidation of the aluminium between stem and fork. any ideas on this?
The bottom bracket, don't know what type. I see the typical bolt/screw with inside teeth, to be used with the typical Shimano tool with outside teeth (like freewheel remover but bigger size). This is identical at both sides. Not sure if its left or right threaded.
I think it's the original Shimano equipment, since all of the group is Shimano except the brakes.
I can't post a picture yet, need to do 10 posts first.
greets and thanks
Lars
greets and thanks
Lars
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Quoted: 4236 Post(s)
Liked 2,949 Times
Yeah, seems like a lot of effort. On the other hand, if you've been fixated on getting one of these frames for a while (and are not likely to find another soon), go for it. I'm in the midst of a PB Blaster soak to hopefully get out a siezed BB on a frame I really like - it's also Italian thread and I'm hoping someone just overtightened it because they didn't know which way to turn and didn't damage the threads and that there's no galling between the alloy bb threads and the Ti frame.
Old fart
Liked 3,400 Times
Quoted: 8 Post(s)
aha! got the BB out. I used a 70cm pipe to get more leverage, pressed the Shimano tool in as hars as I could, took a deep breath and it cracked loose and started turning.
now I 've put WD40in so soak the seat post. Is there a better chemical for the aluminium post?
greets
L
greets
L
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Sheldon Brown's "14 ways to unstick a seatpost" might be helpful if you haven't already read it: https://www.sheldonbrown.com/stuck-seatposts.html
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
greets
L
greets
L
Oh, and some have used auto tranny fluid mixed with acetone with excellent results. I don't remember the mix percentage, so you'll have to google that
Quoted: 839 Post(s)
Liked 1,061 Times
I"m assuming you're not in the US, so not sure what's available to you. But, if PB Blaster, Kroil, or WD40 "specialist" penetrant are available, then those work well for ferrous metals. Aluminum is not ferrous, so perhaps try "Freeze Off". It's not a penetrant. It freezes the components to cause expansion and "attempt" to break loose the surface tension. I've used it before with success. BTW, regular WD40 isn't the best of penetrants. It doesn't creep into the parts like other products.
Liked 2,949 Times
Huh, so that might explain why a 3 day soak in PB Blaster didn't help free up my alloy BB cup stuck to my Ti frame. I'm hoping the bike shop I dropped it off at has more luck.
Quoted: 8 Post(s)
It seems hard to get a decent grip on the fork without damaging it. I'll get back to it tomorrow.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
got a freezing oil penetrant thing... and it worked well for the seat post. I got it out with a lot of force and stress. I now have a new blister on my handpalm. started using the glove when it was too late evidently. but hey, 2 of 3 stuck things are out. next is the stem. I've turned the bike upside-down and sprayed lots of penetrant oil in the hole of the fork.
btw, is the steerer tube aluminum or steel?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
edit: yes...at o'reilly. crc is the brand name. about $7.50 a can
Quoted: 8 Post(s)
Hi,
it's a regular quill stem, yes. I got the bolt out, so that's fine. I put deblock oil on both sides yesterday evening, so i't been soaking all night.
I think the threaded tube of the fork is steel.
should I apply the freeze-off ont the stem, the part that comes out of the frame? or inside, through the hole of the bolt? seems more logical to get the cold inside the stem and wedge.
I really appreciate you help. I got 2 of 3 problems solved without breaking anything.
greets
Lars
greets
Lars
Quoted: 8 Post(s)
I found something else though, put ice where you spray.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 194 Post(s)
Liked 204 Times
If it is a quill I first loosen the bolt about half a turn and then tap it smartly with a weighted rubber mallet, copper hammer, or a standard hammer and a brass drift / piece of oak.
(and if I am working in someone's barn then just a sharp tap with just a hammer, because if I don't then then they will - generally with much less precision
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Hi,
greets
Lars
greets
Lars
so, the bolt came out but not the wedge? how far down into the steerer is the stem? iow's, how much stem is exposed outside/above the steerer tube? if you have plenty, soak the wedge and tap some more with the oil. then, go to the top side of the stem with a wood block and tap on that. that wedge will eventually come out. and, the stem should begin to loosen so you can grab and twist it out with the handlebar installed...hopefully without marring the stem up
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
https://www.crcindustries.com/produc...-oz-05002.html
Liked 2,949 Times
I'll keep a look out for that stuff so the next time I get a stuck bolt I can try it.
I did a 1 day soak with PB Blaster after removing the NDS cup (so I could spray from that side and down from the seat tube), then used the Pedro's tool to secure the BB tool to the DS axle/cup, grabbed it with a 16" pipe wrench, tapped it with a mallet, had no movement from that or from really leaning on the wrench, sprayed in more PB Blaster, waited 2 more days, then repeated the wrenching and whacking.
