Fixed Gear Conversion w/ Vertical Dropouts & Rear Hub Spacing
So on ebay, I purchased a Masi Coltello Road Frame w/ an Alpha Q carbon fork for only $235. Such a good deal, couldn't turn it down. But now I realize that the thing is, I ride fixed and the frame has vertical dropouts. How would I make sure the chain tension is tight? Would I have to somehow find the right ratio and chain length to make sure the tension remains tight? And also, I didn't even think about it when I bought it, do you think the spacing for the rear hub would be too large to insert my rear wheel into the dropouts as my rear wheel is a single gear? The frameset arrives next Wednesday and I want to get some of my answers clarified before it arrives so I know what to do. Thanks!
I posted this in Bike Mechanics too, but wasn't sure if that was the right spot so I'm posting it here too
By the way, I can either run a 46x16 or 46x18
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Chain tension would be an issue; but it can be solved in many different ways; for the most proper and most aesthetically appealing way, you can use a special white industries eno eccentric hub. But there are also cheaper ways, such as a half link (tedious), finding the magic gear ratio (lots of guess work), and a rear derailleur type tensioner (singlespeed only; the chain would otherwise jump if you ran fixed).
OASAASLLS
Bikes: Pake, Surly Pacer, Kilo TT, Giant XTC, SE Stout, 853 Ritchey MTB
Bikes: 80"s Raleigh Comp 48X18
Bicycle Repair Man !!!
Repeating what was said here and in the mech's forum... the eccentric hub is the way to go.
Quoted: 2952 Post(s)
Liked 3,106 Times
Magic gear calculator: https://www.eehouse.org/fixin/formfmu.php
Bikes: 1979 Bianchi Rekord 748, 2009 Fuji Track Pro, 2012 Leader 722
howeeee
Singlespeed & Fixed Gear
6
08-18-14 10:10 AM
hopyaboy
Bicycle Mechanics
20
08-13-11 09:14 PM
